Check Radius extension error
Using Check mk [2.2.0p5.cee]
I am getting an error when activating the changes after disabling and removing the Check Radius extension Checkmk Exchange
I never thought a buggy extension would be there.
Please help.
Hi Suman,
could it be, that there is a leftover configured rule " Check RADIUS service" ?
It seems that one of the hosts still has the active check configured, whereas the mkp is already removed.
Hi Andre,
Is there way to clear these leftovers? All the hosts have Radius Service still intact with them as unknown. The mkp was disabled and removed. I can’t activate the changes in the site right now. Please advise.
Thanks.
can you try to install the extension package again ? Maybe that resolves the error. After that you need to delete the ruleset and then the mkp package.
