Check script vbs with mrpe error - Unable to execute - plugin may be missing
CMK version:
2.2.0
OS version:
Rocky Linux 8.9
I’m trying to add a vbs script via mrpe but I get the following error
If I run the script from command prompt it works correctly
I have enabled execute in global
execute: [exe, bat, vbs, cmd, ps1] # Supported: vbs, ps1, py, pl, exe, cmd, bat
In the mrpe entry I configured the check like this
mrpe:
enabled: yes
## Timeout value (seconds) - Defaults to 60, which can be considered a safe choice,
## as legacy Nagios checks usually execute fastly.
timeout: 60
config:
    ## MRPE check entries:
    ## check = SERVICE_DESCRIPTION [(interval=INTERVAL)] COMMAND
    ## If specified, the check result will be cached for INTERVAL seconds
    ## before executing it again.
    ## Relative path are supported for checks and includes.
    ## The path below is equal to '$CUSTOM_AGENT_PATH$\plugins\your_check.com'
    - check = TEST3 '$CUSTOM_AGENT_PATH$\plugins\name_check_.vbs'
    # - check = Console 'c:\windows\system32\mode.com' WITH CP /STATUS
    # - check = Checker (interval=100) 'c:\windows\system32\mode.com'
    ## Include entries:
    ## include [USER_NAME] = PATH_TO_CFG
    ## Add config files that contain additional MRPE check lines
    # - include = $CUSTOM_AGENT_PATH$\mrpe_checks.cfg
    # - include some_user_name = $CUSTOM_AGENT_PATH$\mrpe_checks.cfg
Obviously I also tried to change the path of the checks by moving them but nothing changed.
Where could I have gone wrong?
Solved.
Post here the solution that could be useful for other users
When execute vbs custon script via mrpe you must specified the interpreter of the command
Example
mrpe:
enabled: yes
timeout: 60
config:
    - check = TESTFINALE 'c:\windows\system32\cscript.exe' //nologo C:\ProgramData\checkmk\agent\mrpe\SCRIPT_NAME.vbs
