Hi
I’ve been setting up SFTP servers and saw that in Check_MK you can monitor them as well.
I’ve been trying to get that working, but it seems I am bumping into an issue.
When I use the web interface to configure the check, I get connection failed.
When I use the command line I get “authentication failed” => See below but when I then log in manually it works without issues. (RSA fingerprint has been stored)
Anyone an idea on how to proceed with this?
OMD[sitename]:/opt/omd/versions/2.0.0p1.cre/lib/nagios/plugins$ ./check_sftp --verbose --user [username] --secret [password] --port 22 [IP_of_host]
File “./check_sftp”, line 265, in
exitcode, info = main()
File “./check_sftp”, line 203, in main
client = connection(opt_key, opt_host, opt_user, opt_pass, opt_port, opt_timeout)
File “./check_sftp”, line 41, in connection
client.connect(opt_host,
File “/omd/sites/sitename/lib/python3/paramiko/client.py”, line 435, in connect
self._auth(
File “/omd/sites/sitename/lib/python3/paramiko/client.py”, line 764, in _auth
raise saved_exception
File “/omd/sites/sitename/lib/python3/paramiko/client.py”, line 751, in _auth
self._transport.auth_password(username, password)
File “/omd/sites/sitename/lib/python3/paramiko/transport.py”, line 1509, in auth_password
return self.auth_handler.wait_for_response(my_event)
File “/omd/sites/sitename/lib/python3/paramiko/auth_handler.py”, line 250, in wait_for_response
raise e
paramiko.ssh_exception.AuthenticationException: Authentication failed.
OMD[sitename]:/opt/omd/versions/2.0.0p1.cre/lib/nagios/plugins$ ssh username@IP_of_host
username@IP_of_host’s password:
Welcome to Ubuntu 18.04.6 LTS (GNU/Linux 4.15.0-159-generic x86_64)
- Documentation: https://help.ubuntu.com
- Management: https://landscape.canonical.com
- Support: Ubuntu Advantage for Infrastructure | Ubuntu
System information as of Tue Oct 26 09:09:40 CEST 2021
System load: 0.15 Processes: 125
Usage of /: 8.6% of 196.73GB Users logged in: 1
Memory usage: 42% IP address for mgmt: snipped
Swap usage: 0% IP address for public: snipped
Super-optimized for small spaces - read how we shrank the memory
footprint of MicroK8s to make it the smallest full K8s around.From lightweight to featherweight: MicroK8s memory optimisation | Ubuntu
0 updates can be applied immediately.
New release ‘20.04.3 LTS’ available.
Run ‘do-release-upgrade’ to upgrade to it.
*** System restart required ***
Last login: Tue Jul 20 09:47:33 2021 from snipped
username@ip_of_host:~$ exit
