I’m trying to configure a monitor using SQL query on Check SQL Database.
The query is returning the right result on SSMS, but on CheckMK i’m getting the following error on this monitor:
Error while executing SQL command: 102, b"Incorrect syntax near ‘$’.DB-Lib error message 20018, severity 15: General SQL Server error: Check messages from the SQL Server "
I tried change the query to a simplified version like this example:
SELECT 1 AS status_number, ‘OK’ AS status_text;
But i still got the same error.
The SQL server doesn’t have a default instance name, but I’m not sure where and how I should configure the instance. I set it on the field DNS Hostname or IP address as “SERVER\SQLINSTANCE”.
Anyone can help me with this issue ?
CentOS 7
Checkmk Raw Edition 2.1.0p23
Thanks
