CHECK_SQL error with SQL Server
We upgrade our CHeckMK to 2.3.0sp21.
We use check_sql for SQL Server control.
We have this error message for a control with a SQL Server database
Error while connecting to database: 20002, b’DB-Lib error message 20002, severity 9: Adaptive Server connection failed (XXXXXXXXXXXXXXX DB-Lib error message 20002, severity 9: Adaptive Server connection failed (XXXXXXXXXXXXXXX) ’
I follow this doc SQL Database Request Check
Module pymssql is installed :
OMD[XXXXXXX]:~$ pip3 list | grep pymssql
pymssql 2.3.2
Do you know how to resolv this problem?
Thanks for your help,
Matt
Hi all,
I tried to execute the control directly in ssh console of CMK Server
OMD[XXXXX]:~$ /opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins/check_sql  "XXXXXXX" -d mssql -H XXXXXX -P XXXXXX   -n test -u XXXXXX -p "XXXXXX" --debug
  File "src/pymssql/_pymssql.pyx", line 650, in pymssql._pymssql.connect
  File "src/pymssql/_mssql.pyx", line 2158, in pymssql._mssql.connect
  File "src/pymssql/_mssql.pyx", line 712, in pymssql._mssql.MSSQLConnection.__init__
  File "src/pymssql/_mssql.pyx", line 1884, in pymssql._mssql.maybe_raise_MSSQLDatabaseException
  File "src/pymssql/_mssql.pyx", line 1901, in pymssql._mssql.raise_MSSQLDatabaseException
pymssql._mssql.MSSQLDatabaseException: (20009, b'DB-Lib error message 20009, severity 9:\nUnable to connect: Adaptive Server is unavailable or does not exist (XXXXXXXX)\n')
  File "/opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins/check_sql", line 502, in <module>
    main()
  File "/opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins/check_sql", line 479, in main
    conn = connect(args.dbms, args.hostname, args.port, args.name, args.user, args.password)
  File "/opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins/check_sql", line 387, in connect
    return {
  File "/opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins/check_sql", line 258, in mssql_connect
    return pymssql.connect(host=host, port=port, database=db_name, user=user, password=pwd)
  File "src/pymssql/_pymssql.pyx", line 659, in pymssql._pymssql.connect
pymssql.exceptions.OperationalError: (20009, b'DB-Lib error message 20009, severity 9:\nUnable to connect: Adaptive Server is unavailable or does not exist (XXXX)\n')
Matt
I resolved my problem.
source help me : Error : Unable to connect: Adaptive Server is unavailable or does not exist · Issue #896 · pymssql/pymssql · GitHub
I modified check_sql to force TDVS vesion for pymssq.connect method.
XXXXX@XXXXX:~$ cd /opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins/
XXXXX@XXXXX:/opt/omd/versions/2.3.0p21.cre/lib/nagios/plugins# vi check_sql
BEFORE :
AFTER :
return pymssql.connect(host=host, port=port, database=db_name, user=user, password=pwd, tds_version="7.0")
Hope that all someone,
Matt
Thanks, that also resolved the issue for me.
May I ask what version the sql server is which you try to connect to?
SQL Server 2019
Matt
