toddehb
(ToddeHB)
November 19, 2021, 6:41am
1
I followed these instructions to check internet connection:
I set up a host with 2 IP addresses:
Those 2 IP addresses are from Root-Nameserver – Wikipedia so I assume they will be always available. ICMP works on them
The checked worked for couple of minutes an then suddenly the status went down
Both IP addressses are working fine and respond to icmp when checked via manual ping
Any idea what is going wrong?
toddehb
(ToddeHB)
November 19, 2021, 6:42am
2
PLEASE can anyone let me insert more than 1 picture in one post?
toddehb
(ToddeHB)
3
toddehb
(ToddeHB)
November 19, 2021, 6:43am
4
The most important thing is missing. How does your defined ping service looks like?
If there is a problem you should see it inside the ping.
toddehb
(ToddeHB)
November 19, 2021, 7:22am
6
“Check host with ping” as shown in the above screenshot is not sufficient?
kdeutsch
(Karl Deutsch)
November 19, 2021, 7:33am
7
which release and version of Checkmk do you use? Open Source or Enterprise? Patch-Level?
Karl
The output of your ping check is relevant not the definition of the service.
toddehb
(ToddeHB)
November 19, 2021, 10:49am
9
I am using the Raw Edition
OMD - Open Monitoring Distribution Version 2.0.0p15.cre
toddehb
(ToddeHB)
November 19, 2021, 11:22am
11
Saying something about not able to resolve name. What needs to be resolved? This is confusing me
You see something on your ping check is wrong. It is in unknown state and complains about some variable it cannot resolve. If you click on this check you will see at the bottom the complete command line with all arguments.
toddehb
(ToddeHB)
November 19, 2021, 12:51pm
13
It is showing this
Service check command check_mk_active-icmp!-m 1 -w 200.00,80% -c 500.00,100% $HOST_ADDRESSES_4$ $HOST_ADDRESS_4$
toddehb
(ToddeHB)
November 23, 2021, 8:18am
14
Any further help would be appriciated
kdeutsch
(Karl Deutsch)
November 23, 2021, 4:47pm
15
there has been a bug in the Raw Edition when pinging multiple hosts. I thought that the bug has been fixed already?!?
https://checkmk.com/werk/12897
Karl
toddehb
(ToddeHB)
November 25, 2021, 1:28pm
16
I removed additional IP addresses but error persists.
kdeutsch
(Karl Deutsch)
November 25, 2021, 4:25pm
17
that looks like a bug in the Raw edition (I get the same error with your settings). Your settings work fine in the Enterprise Edition.
Karl
kdeutsch
(Karl Deutsch)
November 29, 2021, 11:15am
18
your problem should be fixed with werk 13519: https://checkmk.com/werk/13519
Karl
system
(system)
Closed
November 29, 2022, 11:16am
19
