Checkmk 2.4.0 SAML does not work anymore
CMK version:2.4.0
OS version:virtual appliance
Error message:Unable to create authentication request
Please contact your administrator.
I have setup SAML with Azrue via the webui in a previous version (some of 2.3.0) which always worked flawlessly.
Today I updated to 2.4.0 and SAML does not work anymore.
Error:
In /var/log/webserver.log I also found this error message:
2025-05-07 10:16:38,597 [30] [cmk.web.saml2 1955] Entra Single Sign-On (SITENAMEREDACTED) - SignatureError: ['/omd/sites/SITENAMEREDACTED/bin/xmlsec1', '--sign', '--privkey-pem', '/omd/sites/REDACTED/etc/ssl/saml2/custom/SITENAMEREDACTED/signature/private.pem', '--id-attr:ID', 'urn:oasis:names:tc:SAML:2.0:protocol:AuthnRequest', '--node-id', 'id-REDACTED', '--output', '/tmp/REDACTED.xml', '--lax-key-search', '/tmp/REDACTED.xml']
I tried reneweing the cert in Entra, no chance.
Greetings
Max
Can you share the output of “xmlsec1 --list-transforms” as site user ?
Of course :wink:
"base64","enveloped-signature","c14n","c14n-with-comments","c14n11","c14n11-with-comments","exc-c14n","exc-c14n-with-comments","xpath","xpath2","xpointer","relationship","xslt","aes128-cbc"
,"aes192-cbc","aes192-cbc","aes256-cbc","aes128-gcm","aes192-gcm","aes256-gcm","concatkdf","kw-aes128","kw-aes192","kw-aes256","tripledes-cbc","kw-tripledes","dh-es","dsa-sha1","dsa-sha256"
,"ecdh-es","ecdsa-ripemd160","ecdsa-sha1","ecdsa-sha224","ecdsa-sha256","ecdsa-sha384","ecdsa-sha512","ecdsa-sha3-224","ecdsa-sha3-256","ecdsa-sha3-384","ecdsa-sha3-512","hmac-ripemd160","h
mac-sha1","hmac-sha224","hmac-sha256","hmac-sha384","hmac-sha512","pbkdf2","ripemd160","rsa-ripemd160","rsa-sha1","rsa-sha224","rsa-sha256","rsa-sha384","rsa-sha512","rsa-pss-sha1","rsa-pss
-sha224","rsa-pss-sha256","rsa-pss-sha384","rsa-pss-sha512","rsa-pss-sha3-224","rsa-pss-sha3-256","rsa-pss-sha3-384","rsa-pss-sha3-512","rsa-1_5","rsa-oaep-mgf1p","rsa-oaep-enc11","sha1","s
ha224","sha256","sha384","sha512","sha3-224","sha3-256","sha3-384","sha3-512"
Thanks. Can you raise the log_level to Debug and share the ~/var/log/web.log ?
If its possible to open a support ticket, then we can also handle it there.
Sadly, we don’t have support :frowning:
But I will propose it at our next renewal
I’ve set Alerts and Core to debug and exported the log.
Here is a redacted version:
2025-05-07 12:38:46,599 [10] [cmk.web.saml2 124234] Accessing SAML2.0 connector
2025-05-07 12:38:46,600 [10] [cmk.web.saml2 124234] Authentication request to Identity Provider REDACTED at URL Entra Single Sign-On (REDACTED)
2025-05-07 12:38:46,600 [10] [cmk.web.saml2 124234] Authentication request with RelayState=REDACTED,index.py
2025-05-07 12:38:46,638 [10] [saml2.httpbase 124234] GET to https://login.microsoftonline.com/IDREDACTED/federationmetadata/2007-06/federationmetadata.xml?appid=IDREDACTED
2025-05-07 12:38:46,639 [10] [urllib3.connectionpool 124234] Starting new HTTPS connection (1): login.microsoftonline.com:443
2025-05-07 12:38:46,868 [10] [urllib3.connectionpool 124234] https://login.microsoftonline.com:443 "GET /IDREDACTED/federationmetadata/2007-06/federationmetadata.xml?appid=IDREDACTED HTTP/11" 200 4729
2025-05-07 12:38:46,869 [10] [saml2.httpbase 124234] Response status: 200
2025-05-07 12:38:46,872 [10] [saml2.assertion 124234] policy restrictions: None
2025-05-07 12:38:46,910 [10] [saml2.mdstore 124234] service(https://sts.windows.net/IDREDACTED/, idpsso_descriptor, single_sign_on_service, urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST)
2025-05-07 12:38:46,910 [10] [saml2.mdstore 124234] service => [{'__class__': 'urn:oasis:names:tc:SAML:2.0:metadata&SingleSignOnService', 'binding': 'urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST', 'location': 'https://login.microsoftonline.com/IDREDACTED/saml2'}]
2025-05-07 12:38:46,971 [10] [cmk.web.saml2 124234] Prepare authentication request
2025-05-07 12:38:46,971 [10] [saml2.entity 124234] REQUEST: <ns0:AuthnRequest xmlns:ns0="urn:oasis:names:tc:SAML:2.0:protocol" xmlns:ns1="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:ns2="http://www.w3.org/2000/09/xmldsig#" ID="id-IDREDACTED" Version="2.0" IssueInstant="2025-05-07T10:38:46Z" Destination="https://login.microsoftonline.com/IDREDACTED/saml2" ProtocolBinding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" AssertionConsumerServiceURL="https://checkmk.REDACTED.de/REDACTED/check_mk/saml_acs.py?acs"><ns1:Issuer Format="urn:oasis:names:tc:SAML:2.0:nameid-format:entity">https://checkmk.REDACTED.de/REDACTED/check_mk/saml_metadata.py</ns1:Issuer><ns2:Signature Id="Signature1"><ns2:SignedInfo><ns2:CanonicalizationMethod Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#" /><ns2:SignatureMethod Algorithm="http://www.w3.org/2001/04/xmldsig-more#rsa-sha256" /><ns2:Reference URI="#id-IDREDACTED"><ns2:Transforms><ns2:Transform Algorithm="http://www.w3.org/2000/09/xmldsig#enveloped-signature" /><ns2:Transform Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#" /></ns2:Transforms><ns2:DigestMethod Algorithm="http://www.w3.org/2001/04/xmlenc#sha256" /><ns2:DigestValue /></ns2:Reference></ns2:SignedInfo><ns2:SignatureValue /><ns2:KeyInfo><ns2:X509Data><ns2:X509Certificate>CERTREDACTED</ns2:X509Certificate></ns2:X509Data></ns2:KeyInfo></ns2:Signature><ns0:NameIDPolicy Format="urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified" AllowCreate="false" /></ns0:AuthnRequest>
2025-05-07 12:38:46,975 [10] [saml2.sigver 124234] xmlsec command: /omd/sites/REDACTED/bin/xmlsec1 --sign --privkey-pem /omd/sites/REDACTED/etc/ssl/saml2/custom/REDACTED/signature/private.pem --id-attr:ID urn:oasis:names:tc:SAML:2.0:protocol:AuthnRequest --node-id id-IDREDACTED --output /tmp/tmpsdp2327g.xml --lax-key-search /tmp/tmptmcsxf0i.xml
2025-05-07 12:38:47,000 [40] [saml2.sigver 124234] returncode=1
error=Signature status: ERROR
Error: failed to sign file "/tmp/tmptmcsxf0i.xml"
output=
2025-05-07 12:38:47,000 [30] [cmk.web.saml2 124234] Entra Single Sign-On (REDACTED) - SignatureError: ['/omd/sites/REDACTED/bin/xmlsec1', '--sign', '--privkey-pem', '/omd/sites/REDACTED/etc/ssl/saml2/custom/REDACTED/signature/private.pem', '--id-attr:ID', 'urn:oasis:names:tc:SAML:2.0:protocol:AuthnRequest', '--node-id', 'id-IDREDACTED', '--output', '/tmp/tmpsdp2327g.xml', '--lax-key-search', '/tmp/tmptmcsxf0i.xml']
2025-05-07 12:38:47,000 [10] [cmk.web.saml2 124234] Unable to create authentication request
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/sigver.py", line 796, in sign_statement
    (stdout, stderr, output) = self._run_xmlsec(com_list, [tmp.name])
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/sigver.py", line 870, in _run_xmlsec
    raise XmlsecError(errmsg)
saml2.sigver.XmlsecError: returncode=1
output=
The above exception was the direct cause of the following exception:
  File "/omd/sites/REDACTED/lib/python3/cmk/gui/cee/saml2/_pages.py", line 131, in page
    authentication_request = interface.authentication_request(relay_state_string)
  File "/omd/sites/REDACTED/lib/python3/cmk/gui/cee/saml2/_interface.py", line 264, in authentication_request
    authn_request_id, authn_request = self._client.create_authn_request(
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/client_base.py", line 446, in create_authn_request
    msg = self._message(
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/entity.py", line 588, in _message
    signed_req = self.sign(
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/entity.py", line 524, in sign
    return signed_instance_factory(msg, self.sec, to_sign)
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/sigver.py", line 331, in signed_instance_factory
    signed_xml = seccont.sign_statement(signed_xml, node_name=node_name, node_id=nodeid)
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/sigver.py", line 1695, in sign_statement
    return self.crypto.sign_statement(
  File "/omd/sites/REDACTED/lib/python3.12/site-packages/saml2/sigver.py", line 798, in sign_statement
    raise SignatureError(com_list) from e
saml2.sigver.SignatureError: ['/omd/sites/REDACTED/bin/xmlsec1', '--sign', '--privkey-pem', '/omd/sites/REDACTED/etc/ssl/saml2/custom/REDACTED/signature/private.pem', '--id-attr:ID', 'urn:oasis:names:tc:SAML:2.0:protocol:AuthnRequest', '--node-id', 'id-IDREDACTED', '--output', '/tmp/tmpsdp2327g.xml', '--lax-key-search', '/tmp/tmptmcsxf0i.xml']
  File "/omd/sites/REDACTED/lib/python3/cmk/gui/cee/saml2/_pages.py", line 151, in handle_page
    post_request = self.page()
  File "/omd/sites/REDACTED/lib/python3/cmk/gui/cee/saml2/_pages.py", line 139, in page
    raise MKUserError(
cmk.gui.exceptions.MKUserError: Unable to create authentication request
2025-05-07 12:38:47,002 [10] [cmk.web 124234] Disconnecting site connections
2025-05-07 12:38:47,002 [10] [cmk.store 124234] Releasing all locks
2025-05-07 12:38:47,002 [10] [cmk.store 124234] Acquired locks: {}
Greetings
Max
Hi Max,
Thanks for the log files.
Can you also share the output of the following commands:
As site user:
find -L ~/local
Also, are there any kind of custom changes to the files on the appliance ?
More info here
here is the output:
OMD[REDACTED]:~/var/log$ find -L ~/local
/omd/sites/REDACTED/local
/omd/sites/REDACTED/local/bin
/omd/sites/REDACTED/local/lib
/omd/sites/REDACTED/local/lib/apache
/omd/sites/REDACTED/local/lib/check_mk
/omd/sites/REDACTED/local/lib/check_mk/gui
/omd/sites/REDACTED/local/lib/check_mk/gui/plugins
/omd/sites/REDACTED/local/lib/check_mk/gui/plugins/reports
/omd/sites/REDACTED/local/lib/check_mk/gui/plugins/views
/omd/sites/REDACTED/local/lib/check_mk/gui/plugins/dashboard
/omd/sites/REDACTED/local/lib/check_mk/cee
/omd/sites/REDACTED/local/lib/check_mk/cee/dcd
/omd/sites/REDACTED/local/lib/check_mk/cee/dcd/plugins
/omd/sites/REDACTED/local/lib/check_mk/cee/dcd/plugins/connectors
/omd/sites/REDACTED/local/lib/check_mk/plugins
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/__pycache__/lib.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/graphing
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/graphing/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/graphing/__pycache__/metrics.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/graphing/__pycache__/perfometer.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_temperatures.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_memory.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_logicaldrives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_thermal.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_psu.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_volumes.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers_hpe.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_processors.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_fans.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers_generic.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_storage.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_voltage.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_drives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_power.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_networkports.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_memory_summary.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_ethernetinterfaces.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_physicaldrives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_networkadapters.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/agent_based/__pycache__/redfish_system.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/server_side_calls
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/server_side_calls/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/server_side_calls/__pycache__/special_agent.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/libexec
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/rulesets
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/rulesets/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/rulesets/__pycache__/datasource_program.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/special_agents
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/special_agents/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/plugins/redfish/special_agents/__pycache__/agent_redfish.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/base
/omd/sites/REDACTED/local/lib/check_mk/base/plugins
/omd/sites/REDACTED/local/lib/check_mk/base/plugins/agent_based
/omd/sites/REDACTED/local/lib/check_mk/base/plugins/agent_based/__pycache__
/omd/sites/REDACTED/local/lib/check_mk/base/plugins/agent_based/__pycache__/unifi_controller.cpython-312.pyc
/omd/sites/REDACTED/local/lib/check_mk/special_agents
/omd/sites/REDACTED/local/lib/python3
/omd/sites/REDACTED/local/lib/python3/cx_Oracle.cpython-39-x86_64-linux-gnu.so
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/WHEEL
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/METADATA
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/RECORD
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/top_level.txt
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/LICENSE.txt
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/INSTALLER
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-8.3.0.dist-info/REQUESTED
/omd/sites/REDACTED/local/lib/python3/cmk
/omd/sites/REDACTED/local/lib/python3/cmk/gui
/omd/sites/REDACTED/local/lib/python3/cmk/gui/plugins
/omd/sites/REDACTED/local/lib/python3/cmk/gui/plugins/reports
/omd/sites/REDACTED/local/lib/python3/cmk/gui/plugins/views
/omd/sites/REDACTED/local/lib/python3/cmk/gui/plugins/dashboard
/omd/sites/REDACTED/local/lib/python3/cmk/cee
/omd/sites/REDACTED/local/lib/python3/cmk/cee/dcd
/omd/sites/REDACTED/local/lib/python3/cmk/cee/dcd/plugins
/omd/sites/REDACTED/local/lib/python3/cmk/cee/dcd/plugins/connectors
/omd/sites/REDACTED/local/lib/python3/cmk/plugins
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/__pycache__/lib.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/graphing
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/graphing/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/graphing/__pycache__/metrics.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/graphing/__pycache__/perfometer.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_temperatures.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_memory.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_logicaldrives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_thermal.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_psu.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_volumes.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers_hpe.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_processors.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_fans.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers_generic.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_storage.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_voltage.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_drives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_power.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_networkports.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_memory_summary.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_ethernetinterfaces.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_physicaldrives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_networkadapters.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/agent_based/__pycache__/redfish_system.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/server_side_calls
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/server_side_calls/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/server_side_calls/__pycache__/special_agent.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/libexec
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/rulesets
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/rulesets/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/rulesets/__pycache__/datasource_program.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/special_agents
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/special_agents/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/plugins/redfish/special_agents/__pycache__/agent_redfish.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/base
/omd/sites/REDACTED/local/lib/python3/cmk/base/plugins
/omd/sites/REDACTED/local/lib/python3/cmk/base/plugins/agent_based
/omd/sites/REDACTED/local/lib/python3/cmk/base/plugins/agent_based/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk/base/plugins/agent_based/__pycache__/unifi_controller.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk/special_agents
/omd/sites/REDACTED/local/lib/python3/cmk_addons
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/__pycache__/lib.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/__pycache__/tools.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/graphing
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/graphing/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/graphing/__pycache__/metrics.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/graphing/__pycache__/translation.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/graphing/__pycache__/perfometer.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_temperatures.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_memory.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_logicaldrives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_thermal.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_psu.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_volumes.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers_hpe.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/inv_redfish_firmware_hpe_ilo4.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_outlets.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_processors.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_fans.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers_generic.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_storage.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_voltage.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_drives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_arraycontrollers.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_mains.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_power.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/inv_redfish_firmware.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_networkports.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_memory_summary.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_ethernetinterfaces.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_sensors.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_physicaldrives.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_networkadapters.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/agent_based/__pycache__/redfish_system.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/server_side_calls
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/server_side_calls/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/server_side_calls/__pycache__/special_agent.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/libexec
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/rulesets
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/rulesets/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/rulesets/__pycache__/datasource_program.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/rulesets/__pycache__/redfish_outlets.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/special_agents
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/special_agents/__pycache__
/omd/sites/REDACTED/local/lib/python3/cmk_addons/plugins/redfish/special_agents/__pycache__/agent_redfish.cpython-312.pyc
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-doc
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-doc/README.txt
/omd/sites/REDACTED/local/lib/python3/cx_Oracle-doc/LICENSE.txt
/omd/sites/REDACTED/local/lib/nagios
/omd/sites/REDACTED/local/lib/nagios/plugins
/omd/sites/REDACTED/local/share
/omd/sites/REDACTED/local/share/check_mk
/omd/sites/REDACTED/local/share/check_mk/pnp-templates
/omd/sites/REDACTED/local/share/check_mk/checkman
/omd/sites/REDACTED/local/share/check_mk/mibs
/omd/sites/REDACTED/local/share/check_mk/web
/omd/sites/REDACTED/local/share/check_mk/web/htdocs
/omd/sites/REDACTED/local/share/check_mk/web/htdocs/themes
/omd/sites/REDACTED/local/share/check_mk/web/htdocs/images
/omd/sites/REDACTED/local/share/check_mk/web/plugins
/omd/sites/REDACTED/local/share/check_mk/web/plugins/pages
/omd/sites/REDACTED/local/share/check_mk/web/plugins/sidebar
/omd/sites/REDACTED/local/share/check_mk/web/plugins/visuals
/omd/sites/REDACTED/local/share/check_mk/web/plugins/config
/omd/sites/REDACTED/local/share/check_mk/web/plugins/views
/omd/sites/REDACTED/local/share/check_mk/web/plugins/wato
/omd/sites/REDACTED/local/share/check_mk/web/plugins/perfometer
/omd/sites/REDACTED/local/share/check_mk/web/plugins/dashboard
/omd/sites/REDACTED/local/share/check_mk/web/plugins/icons
/omd/sites/REDACTED/local/share/check_mk/web/plugins/metrics
/omd/sites/REDACTED/local/share/check_mk/reporting
/omd/sites/REDACTED/local/share/check_mk/reporting/images
/omd/sites/REDACTED/local/share/check_mk/checks
/omd/sites/REDACTED/local/share/check_mk/pnp-rraconf
/omd/sites/REDACTED/local/share/check_mk/alert_handlers
/omd/sites/REDACTED/local/share/check_mk/agents
/omd/sites/REDACTED/local/share/check_mk/agents/plugins
/omd/sites/REDACTED/local/share/check_mk/agents/bakery
/omd/sites/REDACTED/local/share/check_mk/agents/special
/omd/sites/REDACTED/local/share/check_mk/agents/linux
/omd/sites/REDACTED/local/share/check_mk/agents/linux/alert_handlers
/omd/sites/REDACTED/local/share/check_mk/enabled_packages
/omd/sites/REDACTED/local/share/check_mk/enabled_packages/redfish-2.3.38.mkp
/omd/sites/REDACTED/local/share/check_mk/inventory
/omd/sites/REDACTED/local/share/check_mk/locale
/omd/sites/REDACTED/local/share/check_mk/notifications
/omd/sites/REDACTED/local/share/nagvis
/omd/sites/REDACTED/local/share/nagvis/htdocs
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/templates
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/scripts
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/styles
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/gadgets
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/images
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/images/shapes
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/images/maps
/omd/sites/REDACTED/local/share/nagvis/htdocs/userfiles/images/iconsets
/omd/sites/REDACTED/local/share/nagvis/htdocs/server
/omd/sites/REDACTED/local/share/nagvis/htdocs/server/core
/omd/sites/REDACTED/local/share/nagvis/htdocs/server/core/classes
/omd/sites/REDACTED/local/share/nagvis/htdocs/server/core/classes/objects
/omd/sites/REDACTED/local/share/doc
/omd/sites/REDACTED/local/share/doc/check_mk
/omd/sites/REDACTED/local/share/snmp
/omd/sites/REDACTED/local/share/snmp/mibs
/omd/sites/REDACTED/local/share/diskspace
/omd/sites/REDACTED/local/share/nagios
/omd/sites/REDACTED/local/share/nagios/htdocs
/omd/sites/REDACTED/local/share/nagios/htdocs/theme
/omd/sites/REDACTED/local/share/nagios/htdocs/theme/stylesheets
/omd/sites/REDACTED/local/share/nagios/htdocs/theme/images
root@checkmk:~# find /rw/
/rw/
/rw/overlay-rw
/rw/overlay-rw/usr
/rw/overlay-rw/usr/lib
/rw/overlay-rw/usr/lib/check_mk_agent
/rw/overlay-rw/usr/lib/check_mk_agent/plugins
/rw/overlay-rw/usr/lib/check_mk_agent/local
/rw/overlay-rw/usr/share
/rw/overlay-rw/usr/share/cma
/rw/overlay-rw/usr/share/cma/omd-versions
/rw/overlay-rw/usr/share/cma/omd-versions/initialized
/rw/overlay-rw/usr/share/cma/version
/rw/overlay-rw/run
/rw/overlay-rw/run/network
/rw/overlay-rw/run/network/.ifstate.lock
/rw/overlay-rw/run/network/ifstate
/rw/overlay-rw/run/network/ifstate.ens32
/rw/overlay-rw/ro
/rw/overlay-rw/var
/rw/overlay-rw/var/lib
/rw/overlay-rw/var/lib/check_mk_agent
/rw/overlay-rw/var/lib/check_mk_agent/rtc_remotes
/rw/overlay-rw/var/lib/check_mk_agent/rtc_remotes/::ffff:127.0.0.1
/rw/overlay-rw/var/lib/check_mk_agent/cache
/rw/overlay-rw/var/lib/check_mk_agent/cache/ntp.cache
/rw/overlay-rw/var/lib/check_mk_agent/cache/omd_status.cache
/rw/overlay-rw/var/lib/check_mk_agent/persisted
/rw/overlay-rw/var/lib/check_mk_agent/persisted/sections_mk_inventory.::ffff:127.0.0.1
/rw/overlay-rw/var/lib/check_mk_agent/logwatch-batches
/rw/overlay-rw/var/lib/check_mk_agent/logwatch-batches/::ffff:127.0.0.1
/rw/overlay-rw/var/lib/check_mk_agent/logwatch-batches/::ffff:127.0.0.1/logwatch-batch-file-1746622301-039081103067142032137208135009208187248030080190
/rw/overlay-rw/var/lib/check_mk_agent/mk_inventory.last.::ffff:127.0.0.1
/rw/overlay-rw/var/lib/check_mk_agent/logwatch.state.__ffff_127.0.0.1
/rw/overlay-rw/var/lib/logrotate
/rw/overlay-rw/var/lib/logrotate/status
/rw/overlay-rw/var/lib/postfix
/rw/overlay-rw/var/lib/postfix/smtp_scache.db
/rw/overlay-rw/var/lib/postfix/prng_exch
/rw/overlay-rw/var/lib/postfix/master.lock
/rw/overlay-rw/var/lib/heartbeat
/rw/overlay-rw/var/lib/heartbeat/log_daemon
/rw/overlay-rw/var/lib/snmp
/rw/overlay-rw/var/lib/snmp/cert_indexes
/rw/overlay-rw/var/lib/samba
/rw/overlay-rw/var/lib/samba/winbindd_privileged
/rw/overlay-rw/var/lib/samba/winbindd_privileged/pipe
/rw/overlay-rw/var/lib/samba/winbindd_cache.tdb
/rw/overlay-rw/var/lib/samba/private
/rw/overlay-rw/var/lib/samba/private/secrets.tdb
/rw/overlay-rw/var/lib/samba/private/msg.sock
/rw/overlay-rw/var/lib/samba/private/msg.sock/5356
/rw/overlay-rw/var/lib/samba/private/msg.sock/1474
/rw/overlay-rw/var/lib/samba/private/msg.sock/739
/rw/overlay-rw/var/lib/samba/private/msg.sock/19970
/rw/overlay-rw/var/lib/samba/private/msg.sock/737
/rw/overlay-rw/var/lib/samba/private/msg.sock/675
/rw/overlay-rw/var/lib/samba/private/msg.sock/806
/rw/overlay-rw/var/lib/samba/private/msg.sock/615
/rw/overlay-rw/var/lib/samba/private/msg.sock/683
/rw/overlay-rw/var/lib/samba/private/msg.sock/769
/rw/overlay-rw/var/lib/samba/private/netlogon_creds_cli.tdb
/rw/overlay-rw/var/lib/vmware
/rw/overlay-rw/var/lib/vmware/VGAuth
/rw/overlay-rw/var/lib/vmware/VGAuth/aliasStore
/rw/overlay-rw/var/lib/ntpsec
/rw/overlay-rw/var/lib/ntpsec/ntp.drift
/rw/overlay-rw/var/lib/systemd
/rw/overlay-rw/var/lib/systemd/linger
/rw/overlay-rw/var/lib/systemd/timers
/rw/overlay-rw/var/lib/systemd/timers/stamp-anacron.timer
/rw/overlay-rw/var/lib/systemd/timers/stamp-logrotate.timer
/rw/overlay-rw/var/lib/systemd/timers/stamp-man-db.timer
/rw/overlay-rw/var/lib/systemd/timers/stamp-fstrim.timer
/rw/overlay-rw/var/lib/systemd/timers/stamp-phpsessionclean.timer
/rw/overlay-rw/var/lib/systemd/timers/stamp-e2scrub_all.timer
/rw/overlay-rw/var/lib/systemd/timers/stamp-ntpsec-rotate-stats.timer
/rw/overlay-rw/var/lib/systemd/random-seed
/rw/overlay-rw/var/lib/systemd/coredump
/rw/overlay-rw/var/lib/private
/rw/overlay-rw/var/lib/apache2
/rw/overlay-rw/var/lib/apache2/site
/rw/overlay-rw/var/lib/apache2/site/enabled_by_admin
/rw/overlay-rw/var/lib/apache2/site/enabled_by_admin/cma-https
/rw/overlay-rw/var/lib/apache2/module
/rw/overlay-rw/var/lib/apache2/module/enabled_by_admin
/rw/overlay-rw/var/lib/apache2/module/enabled_by_admin/socache_shmcb
/rw/overlay-rw/var/lib/apache2/module/enabled_by_admin/ssl
/rw/overlay-rw/var/lib/apache2/module/enabled_by_admin/rewrite
/rw/overlay-rw/var/lib/apache2/module/enabled_by_admin/headers
/rw/overlay-rw/var/lib/apache2/fcgid
/rw/overlay-rw/var/lib/cma
/rw/overlay-rw/var/lib/cma/crashes
/rw/overlay-rw/var/lib/cma/crashes/398f0926-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/56763c80-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/91f2b974-c767-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/4d4a3724-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/217a4f0a-c766-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/4192da62-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/2bb6fe36-c767-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/79ffc8d0-c766-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/4d5b95fa-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/a2820308-c767-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/568936be-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/de04b4d6-c765-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/920046ac-c767-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/3b8a52f8-c768-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/cma/crashes/2ba3fd18-c767-11ef-bea0-005056b3d166.tar.gz
/rw/overlay-rw/var/lib/ntp/ntp.drift
/rw/overlay-rw/var/spool
/rw/overlay-rw/var/spool/postfix
/rw/overlay-rw/var/spool/postfix/lib
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_winbind.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss3.so
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_hesiod.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_dns.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_wins.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnssdbm3.so
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_files.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libgcc_s.so.1
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnssckbi.so
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_systemd.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libresolv.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnss_compat.so.2
/rw/overlay-rw/var/spool/postfix/lib/x86_64-linux-gnu/libnssutil3.so
/rw/overlay-rw/var/spool/postfix/trace
/rw/overlay-rw/var/spool/postfix/bounce
/rw/overlay-rw/var/spool/postfix/pid
/rw/overlay-rw/var/spool/postfix/pid/unix.bounce
/rw/overlay-rw/var/spool/postfix/pid/master.pid
/rw/overlay-rw/var/spool/postfix/pid/unix.showq
/rw/overlay-rw/var/spool/postfix/pid/unix.cleanup
/rw/overlay-rw/var/spool/postfix/pid/unix.smtp
/rw/overlay-rw/var/spool/postfix/usr
/rw/overlay-rw/var/spool/postfix/usr/lib
/rw/overlay-rw/var/spool/postfix/usr/lib/zoneinfo
/rw/overlay-rw/var/spool/postfix/usr/lib/zoneinfo/localtime
/rw/overlay-rw/var/spool/postfix/active
/rw/overlay-rw/var/spool/postfix/dev
/rw/overlay-rw/var/spool/postfix/dev/log
/rw/overlay-rw/var/spool/postfix/dev/random
/rw/overlay-rw/var/spool/postfix/dev/urandom
/rw/overlay-rw/var/spool/postfix/public
/rw/overlay-rw/var/spool/postfix/public/showq
/rw/overlay-rw/var/spool/postfix/public/flush
/rw/overlay-rw/var/spool/postfix/public/postlog
/rw/overlay-rw/var/spool/postfix/public/qmgr
/rw/overlay-rw/var/spool/postfix/public/cleanup
/rw/overlay-rw/var/spool/postfix/public/pickup
/rw/overlay-rw/var/spool/postfix/private
/rw/overlay-rw/var/spool/postfix/private/tlsmgr
/rw/overlay-rw/var/spool/postfix/private/retry
/rw/overlay-rw/var/spool/postfix/private/ifmail
/rw/overlay-rw/var/spool/postfix/private/trace
/rw/overlay-rw/var/spool/postfix/private/bounce
/rw/overlay-rw/var/spool/postfix/private/discard
/rw/overlay-rw/var/spool/postfix/private/verify
/rw/overlay-rw/var/spool/postfix/private/scache
/rw/overlay-rw/var/spool/postfix/private/uucp
/rw/overlay-rw/var/spool/postfix/private/local
/rw/overlay-rw/var/spool/postfix/private/bsmtp
/rw/overlay-rw/var/spool/postfix/private/proxymap
/rw/overlay-rw/var/spool/postfix/private/relay
/rw/overlay-rw/var/spool/postfix/private/rewrite
/rw/overlay-rw/var/spool/postfix/private/error
/rw/overlay-rw/var/spool/postfix/private/virtual
/rw/overlay-rw/var/spool/postfix/private/smtp
/rw/overlay-rw/var/spool/postfix/private/lmtp
/rw/overlay-rw/var/spool/postfix/private/mailman
/rw/overlay-rw/var/spool/postfix/private/proxywrite
/rw/overlay-rw/var/spool/postfix/private/anvil
/rw/overlay-rw/var/spool/postfix/private/defer
/rw/overlay-rw/var/spool/postfix/private/scalemail-backend
/rw/overlay-rw/var/spool/postfix/private/maildrop
/rw/overlay-rw/var/spool/postfix/incoming
/rw/overlay-rw/var/spool/postfix/maildrop
/rw/overlay-rw/var/spool/postfix/etc
/rw/overlay-rw/var/spool/postfix/etc/hosts
/rw/overlay-rw/var/spool/postfix/etc/localtime
/rw/overlay-rw/var/spool/postfix/etc/ssl
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Security_Communication_ECC_RootCA1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/T-TeleSec_GlobalRoot_Class_2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/607986c7.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_Root_CA_-_R6.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ca6e4ad9.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/626dceaf.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/UCA_Extended_Validation_Root.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f081611a.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/USERTrust_ECC_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/c01eb047.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/emSign_Root_CA_-_C1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/54657681.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b1159c4c.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9482e63a.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f39fc864.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/3e44d2f7.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/HiPKI_Root_CA_-_G1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/02265526.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Hongkong_Post_Root_CA_3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5e98733a.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/UCA_Global_G2_Root.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certigna_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ACCVRAIZ1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Global_Root_G3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GTS_Root_R2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Amazon_Root_CA_1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/6fa5da56.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Baltimore_CyberTrust_Root.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/773e07ad.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/406c9bb1.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/vTrus_ECC_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/eed8c118.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b7a5b843.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TWCA_Root_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TunTrust_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/1e08bfd1.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/653b494a.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Trustwave_Global_ECC_P256_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ePKI_Root_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TrustCor_RootCert_CA-1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/cd8c0d63.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/HARICA_TLS_RSA_Root_CA_2021.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/48bec511.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f0c70a8d.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/40193066.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certum_EC-384_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/de6d66f3.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9ef4a08a.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certum_Trusted_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certum_Trusted_Network_CA_2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b433981b.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/CA_Disig_Root_R2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Assured_ID_Root_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/QuoVadis_Root_CA_3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TrustCor_ECA-1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e35234b1.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Amazon_Root_CA_3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/244b5494.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/064e0aa9.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5a7722fb.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/dd8e9d41.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/6b99d060.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/HARICA_TLS_ECC_Root_CA_2021.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Security_Communication_RootCA2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/d52c538d.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/1e09d511.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Trusted_Root_G4.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GTS_Root_R4.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9b5697b0.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e868b802.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/COMODO_RSA_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/aee5f10d.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/8cb5ee0f.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/emSign_ECC_Root_CA_-_C3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/a3418fda.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/57bcb2da.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/AffirmTrust_Premium.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/32888f65.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/a94d09e5.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certainly_Root_E1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/cd58d51e.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e18bfb83.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/8160b96c.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/106f3e4d.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/76faf6c0.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/7a3adc42.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/COMODO_ECC_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/bf53fb88.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5ad8a5d6.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/emSign_Root_CA_-_G1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Entrust_Root_Certification_Authority_-_G4.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Amazon_Root_CA_4.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/08063a00.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/AC_RAIZ_FNMT-RCM_SERVIDORES_SEGUROS.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/d4dae3dd.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/fc5a8f99.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5f15c80c.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f387163d.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Atos_TrustedRoot_2011.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_TLS_ECC_P384_Root_G5.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/QuoVadis_Root_CA_2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/0f6fa695.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/062cdee6.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SwissSign_Silver_CA_-_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5443e9e3.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/COMODO_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/18856ac4.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/90c5a3c8.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Microsoft_ECC_Root_Certificate_Authority_2017.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/E-Tugra_Global_Root_CA_RSA_v3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/IdenTrust_Commercial_Root_CA_1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/002c0b4f.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Assured_ID_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/cbf06781.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/749e9e03.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/1001acf7.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Trustwave_Global_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/0f5dc4f3.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/XRamp_Global_CA_Root.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/fe8a2cd8.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/certSIGN_Root_CA_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/QuoVadis_Root_CA_2_G3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f3377b1b.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SZAFIR_ROOT_CA2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/68dd7389.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/AC_RAIZ_FNMT-RCM.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/8f103249.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ef954a4e.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Microsec_e-Szigno_Root_CA_2009.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/3bde41ac.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SSL.com_Root_Certification_Authority_ECC.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/2923b3f9.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ANF_Secure_Server_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certigna.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Starfield_Root_Certificate_Authority_-_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_Root_CA_-_R3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SwissSign_Gold_CA_-_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Izenpe.com.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/75d1b2ed.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/66445960.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/4f316efb.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Go_Daddy_Root_Certificate_Authority_-_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Secure_Global_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/AffirmTrust_Commercial.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/D-TRUST_BR_Root_CA_1_2020.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Comodo_AAA_Services_root.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e73d606e.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TrustCor_RootCert_CA-2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b727005e.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/d887a5bb.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ed858448.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GDCA_TrustAUTH_R5_ROOT.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/09789157.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/T-TeleSec_GlobalRoot_Class_3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SSL.com_Root_Certification_Authority_RSA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TeliaSonera_Root_CA_v1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certainly_Root_R1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f249de83.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Entrust.net_Premium_2048_Secure_Server_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/3513523f.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Security_Communication_RootCA3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Actalis_Authentication_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/40547a79.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9c8dfbd4.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/7719f463.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ff34af3f.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/CFCA_EV_ROOT.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ISRG_Root_X1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/D-TRUST_Root_Class_3_CA_2_EV_2009.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/OISTE_WISeKey_Global_Root_GB_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/vTrus_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TWCA_Global_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e36a6752.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b0e59380.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/3bde41ac.1
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_ECC_Root_CA_-_R4.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Buypass_Class_3_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Global_Root_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/0b1b94ef.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5d3033c5.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/988a38cb.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Starfield_Class_2_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/d7e8dc79.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/2ae6433e.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Entrust_Root_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/certSIGN_ROOT_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Microsoft_RSA_Root_Certificate_Authority_2017.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GTS_Root_R1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/NAVER_Global_Root_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/D-TRUST_Root_Class_3_CA_2_2009.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/IdenTrust_Public_Sector_Root_CA_1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Amazon_Root_CA_2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/0b9bc432.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SecureSign_RootCA11.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/06dc52d5.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/fa5da96b.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Telia_Root_CA_v2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ISRG_Root_X2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_Root_E46.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5f618aec.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/cc450945.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/QuoVadis_Root_CA_3_G3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/OISTE_WISeKey_Global_Root_GC_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/6d41d539.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GTS_Root_R3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_ECC.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/E-Tugra_Global_Root_CA_ECC_v3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f51bb24c.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e8de2f56.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/7f3d5d1d.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Entrust_Root_Certification_Authority_-_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/NetLock_Arany_=Class_Gold=_F??tan??s??tv??ny.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/AffirmTrust_Networking.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/D-TRUST_EV_Root_CA_1_2020.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_Root_R46.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/8508e720.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/8d89cda1.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_High_Assurance_EV_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/4b718d9b.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Security_Communication_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/4bfab552.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/0a775a30.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/0bf05006.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5cd81ad7.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/6bacb678.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/f30dd6ad.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Assured_ID_Root_G3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Hongkong_Post_Root_CA_1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/706f604c.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_TLS_RSA4096_Root_G5.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b66938e9.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_RSA_R2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/930ac5d2.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/feffd413.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5860aaa6.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Trustwave_Global_ECC_P384_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e-Szigno_Root_CA_2017.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9d04f354.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/93bc0acc.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/7aaf71c0.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/fd64f3fc.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Certum_Trusted_Network_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Starfield_Services_Root_Certificate_Authority_-_G2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/USERTrust_RSA_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068_2.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/3e45d192.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/7a780d93.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/E-Tugra_Certification_Authority.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GLOBALTRUST_2020.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Go_Daddy_Class_2_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ee64a828.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/SecureTrust_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9846683b.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5273a94c.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/QuoVadis_Root_CA_1_G3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/GlobalSign_ECC_Root_CA_-_R5.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/2b349938.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Entrust_Root_Certification_Authority_-_EC1.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/c28a8a30.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/5931b5bc.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/9f727ac7.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/dc4d6a89.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/e113c810.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/Buypass_Class_2_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/14bc7599.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/AffirmTrust_Premium_ECC.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/4042bcee.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/b81b93f0.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/8d86cdd1.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/emSign_ECC_Root_CA_-_G3.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/1d3472b9.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ecccd8db.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ce5e74ef.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/3fb36b73.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/d6325660.0
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/DigiCert_Global_Root_CA.pem
/rw/overlay-rw/var/spool/postfix/etc/ssl/certs/ssl-cert-snakeoil.pem
/rw/overlay-rw/var/spool/postfix/etc/resolv.conf
/rw/overlay-rw/var/spool/postfix/etc/services
/rw/overlay-rw/var/spool/postfix/etc/host.conf
/rw/overlay-rw/var/spool/postfix/etc/nsswitch.conf
/rw/overlay-rw/var/spool/postfix/hold
/rw/overlay-rw/var/spool/anacron
/rw/overlay-rw/var/spool/anacron/cron.daily
/rw/overlay-rw/var/spool/anacron/cron.weekly
/rw/overlay-rw/var/spool/anacron/cron.monthly
/rw/overlay-rw/var/spool/nullmailer
/rw/overlay-rw/var/spool/nullmailer/failed
/rw/overlay-rw/var/spool/nullmailer/failed/1661933305.1810
/rw/overlay-rw/var/spool/nullmailer/failed/1707928179.3990
/rw/overlay-rw/var/spool/nullmailer/failed/1707928199.4034
/rw/overlay-rw/var/spool/nullmailer/failed/1661933271.1680
/rw/overlay-rw/var/spool/nullmailer/queue
/rw/overlay-rw/var/spool/nullmailer/tmp
/rw/overlay-rw/var/spool/nullmailer/trigger
/rw/overlay-rw/var/spool/cron
/rw/overlay-rw/var/spool/cron/crontabs
/rw/overlay-rw/var/spool/cron/crontabs/REDACTED
/rw/overlay-rw/var/cache
/rw/overlay-rw/var/cache/apparmor
/rw/overlay-rw/var/cache/apparmor/201d1af9.0
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/.features
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/sbin.dhclient
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/usr.sbin.ntpd
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/usr.bin.tcpdump
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/nvidia_modprobe
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/usr.sbin.haveged
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/lsb_release
/rw/overlay-rw/var/cache/apparmor/201d1af9.0/usr.bin.man
/rw/overlay-rw/var/cache/ldconfig
/rw/overlay-rw/var/cache/ldconfig/aux-cache
/rw/overlay-rw/var/cache/man
/rw/overlay-rw/var/cache/man/sr
/rw/overlay-rw/var/cache/man/sr/cat5
/rw/overlay-rw/var/cache/man/sr/cat1
/rw/overlay-rw/var/cache/man/sr/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/sr/index.db
/rw/overlay-rw/var/cache/man/sr/cat8
/rw/overlay-rw/var/cache/man/uk
/rw/overlay-rw/var/cache/man/uk/cat5
/rw/overlay-rw/var/cache/man/uk/cat1
/rw/overlay-rw/var/cache/man/uk/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/uk/index.db
/rw/overlay-rw/var/cache/man/uk/cat8
/rw/overlay-rw/var/cache/man/uk/cat3
/rw/overlay-rw/var/cache/man/sv
/rw/overlay-rw/var/cache/man/sv/cat5
/rw/overlay-rw/var/cache/man/sv/cat1
/rw/overlay-rw/var/cache/man/sv/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/sv/cat7
/rw/overlay-rw/var/cache/man/sv/index.db
/rw/overlay-rw/var/cache/man/sv/cat8
/rw/overlay-rw/var/cache/man/sv/cat3
/rw/overlay-rw/var/cache/man/it
/rw/overlay-rw/var/cache/man/it/cat5
/rw/overlay-rw/var/cache/man/it/cat1
/rw/overlay-rw/var/cache/man/it/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/it/index.db
/rw/overlay-rw/var/cache/man/it/cat8
/rw/overlay-rw/var/cache/man/zh_TW
/rw/overlay-rw/var/cache/man/zh_TW/cat5
/rw/overlay-rw/var/cache/man/zh_TW/cat1
/rw/overlay-rw/var/cache/man/zh_TW/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/zh_TW/index.db
/rw/overlay-rw/var/cache/man/zh_TW/cat8
/rw/overlay-rw/var/cache/man/cat5
/rw/overlay-rw/var/cache/man/cat2
/rw/overlay-rw/var/cache/man/cat1
/rw/overlay-rw/var/cache/man/da
/rw/overlay-rw/var/cache/man/da/cat5
/rw/overlay-rw/var/cache/man/da/cat1
/rw/overlay-rw/var/cache/man/da/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/da/index.db
/rw/overlay-rw/var/cache/man/da/cat8
/rw/overlay-rw/var/cache/man/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/gl
/rw/overlay-rw/var/cache/man/gl/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/gl/index.db
/rw/overlay-rw/var/cache/man/gl/cat8
/rw/overlay-rw/var/cache/man/sk
/rw/overlay-rw/var/cache/man/sk/cat1
/rw/overlay-rw/var/cache/man/sk/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/sk/index.db
/rw/overlay-rw/var/cache/man/cat6
/rw/overlay-rw/var/cache/man/fr
/rw/overlay-rw/var/cache/man/fr/cat5
/rw/overlay-rw/var/cache/man/fr/cat1
/rw/overlay-rw/var/cache/man/fr/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/fr/index.db
/rw/overlay-rw/var/cache/man/fr/cat8
/rw/overlay-rw/var/cache/man/cat4
/rw/overlay-rw/var/cache/man/hr
/rw/overlay-rw/var/cache/man/hr/cat1
/rw/overlay-rw/var/cache/man/hr/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/hr/index.db
/rw/overlay-rw/var/cache/man/cat7
/rw/overlay-rw/var/cache/man/zh_CN
/rw/overlay-rw/var/cache/man/zh_CN/cat5
/rw/overlay-rw/var/cache/man/zh_CN/cat1
/rw/overlay-rw/var/cache/man/zh_CN/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/zh_CN/index.db
/rw/overlay-rw/var/cache/man/zh_CN/cat8
/rw/overlay-rw/var/cache/man/tr
/rw/overlay-rw/var/cache/man/tr/cat5
/rw/overlay-rw/var/cache/man/tr/cat1
/rw/overlay-rw/var/cache/man/tr/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/tr/index.db
/rw/overlay-rw/var/cache/man/tr/cat8
/rw/overlay-rw/var/cache/man/de
/rw/overlay-rw/var/cache/man/de/cat5
/rw/overlay-rw/var/cache/man/de/cat1
/rw/overlay-rw/var/cache/man/de/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/de/cat7
/rw/overlay-rw/var/cache/man/de/index.db
/rw/overlay-rw/var/cache/man/de/cat8
/rw/overlay-rw/var/cache/man/ru
/rw/overlay-rw/var/cache/man/ru/cat5
/rw/overlay-rw/var/cache/man/ru/cat1
/rw/overlay-rw/var/cache/man/ru/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/ru/index.db
/rw/overlay-rw/var/cache/man/ru/cat8
/rw/overlay-rw/var/cache/man/nl
/rw/overlay-rw/var/cache/man/nl/cat5
/rw/overlay-rw/var/cache/man/nl/cat1
/rw/overlay-rw/var/cache/man/nl/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/nl/cat7
/rw/overlay-rw/var/cache/man/nl/index.db
/rw/overlay-rw/var/cache/man/nl/cat8
/rw/overlay-rw/var/cache/man/index.db
/rw/overlay-rw/var/cache/man/zh/cat1
/rw/overlay-rw/var/cache/man/zh/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/zh/index.db
/rw/overlay-rw/var/cache/man/ro
/rw/overlay-rw/var/cache/man/ro/cat5
/rw/overlay-rw/var/cache/man/ro/cat1
/rw/overlay-rw/var/cache/man/ro/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/ro/index.db
/rw/overlay-rw/var/cache/man/ro/cat8
/rw/overlay-rw/var/cache/man/cs
/rw/overlay-rw/var/cache/man/cs/cat5
/rw/overlay-rw/var/cache/man/cs/cat1
/rw/overlay-rw/var/cache/man/cs/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/cs/index.db
/rw/overlay-rw/var/cache/man/cs/cat8
/rw/overlay-rw/var/cache/man/sl
/rw/overlay-rw/var/cache/man/sl/cat1
/rw/overlay-rw/var/cache/man/sl/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/sl/index.db
/rw/overlay-rw/var/cache/man/sl/cat8
/rw/overlay-rw/var/cache/man/fi
/rw/overlay-rw/var/cache/man/fi/cat1
/rw/overlay-rw/var/cache/man/fi/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/fi/index.db
/rw/overlay-rw/var/cache/man/fi/cat8
/rw/overlay-rw/var/cache/man/es
/rw/overlay-rw/var/cache/man/es/cat5
/rw/overlay-rw/var/cache/man/es/cat1
/rw/overlay-rw/var/cache/man/es/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/es/index.db
/rw/overlay-rw/var/cache/man/es/cat8
/rw/overlay-rw/var/cache/man/hu
/rw/overlay-rw/var/cache/man/hu/cat5
/rw/overlay-rw/var/cache/man/hu/cat1
/rw/overlay-rw/var/cache/man/hu/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/hu/index.db
/rw/overlay-rw/var/cache/man/hu/cat8
/rw/overlay-rw/var/cache/man/cat8
/rw/overlay-rw/var/cache/man/cat9
/rw/overlay-rw/var/cache/man/pt_BR
/rw/overlay-rw/var/cache/man/pt_BR/cat5
/rw/overlay-rw/var/cache/man/pt_BR/cat1
/rw/overlay-rw/var/cache/man/pt_BR/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/pt_BR/index.db
/rw/overlay-rw/var/cache/man/pt_BR/cat8
/rw/overlay-rw/var/cache/man/cat3
/rw/overlay-rw/var/cache/man/id
/rw/overlay-rw/var/cache/man/id/cat5
/rw/overlay-rw/var/cache/man/id/cat1
/rw/overlay-rw/var/cache/man/id/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/id/index.db
/rw/overlay-rw/var/cache/man/id/cat8
/rw/overlay-rw/var/cache/man/ko
/rw/overlay-rw/var/cache/man/ko/cat5
/rw/overlay-rw/var/cache/man/ko/cat1
/rw/overlay-rw/var/cache/man/ko/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/ko/index.db
/rw/overlay-rw/var/cache/man/ko/cat8
/rw/overlay-rw/var/cache/man/ja
/rw/overlay-rw/var/cache/man/ja/cat5
/rw/overlay-rw/var/cache/man/ja/cat1
/rw/overlay-rw/var/cache/man/ja/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/ja/index.db
/rw/overlay-rw/var/cache/man/ja/cat8
/rw/overlay-rw/var/cache/man/pt/cat5
/rw/overlay-rw/var/cache/man/pt/cat1
/rw/overlay-rw/var/cache/man/pt/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/pt/cat7
/rw/overlay-rw/var/cache/man/pt/index.db
/rw/overlay-rw/var/cache/man/pt/cat8
/rw/overlay-rw/var/cache/man/pl
/rw/overlay-rw/var/cache/man/pl/cat5
/rw/overlay-rw/var/cache/man/pl/cat1
/rw/overlay-rw/var/cache/man/pl/CACHEDIR.TAG
/rw/overlay-rw/var/cache/man/pl/index.db
/rw/overlay-rw/var/cache/man/pl/cat8
/rw/overlay-rw/var/cache/man/pl/cat3
/rw/overlay-rw/var/cache/samba
/rw/overlay-rw/var/cache/samba/netsamlogon_cache.tdb
/rw/overlay-rw/var/cache/samba/gencache.tdb
/rw/overlay-rw/var/cache/private
/rw/overlay-rw/var/log
/rw/overlay-rw/var/log/vmware-network.7.log
/rw/overlay-rw/var/log/vmware-network.3.log
/rw/overlay-rw/var/log/apt
/rw/overlay-rw/var/log/apt/term.log.1.gz
/rw/overlay-rw/var/log/apt/history.log
/rw/overlay-rw/var/log/apt/history.log.1.gz
/rw/overlay-rw/var/log/vmware-network.8.log
/rw/overlay-rw/var/log/vmware-network.4.log
/rw/overlay-rw/var/log/vmware-vmsvc-root.2.log
/rw/overlay-rw/var/log/wtmp.1
/rw/overlay-rw/var/log/vmware-vmsvc-root.log
/rw/overlay-rw/var/log/cma-debug.log
/rw/overlay-rw/var/log/vmware-network.9.log
/rw/overlay-rw/var/log/syslog
/rw/overlay-rw/var/log/journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-000000000009c4cc-00062679420e18bb.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000a20db-000626a17dbe33c2.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-000000000007f6af-000625b43313796e.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000852f6-000625dc1c7c048e.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000a7cf8-000626c9a3f9a577.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000dba6d-00062831bc3a98ab.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000e1673-00062859dccd690c.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-0000000000096848-00062651b93393e5.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000b3541-00062719d0435a42.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000ca5a4-000627ba219d18c4.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000685d8-00062513ec80bd8d.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000ad93b-000626f190fd7734.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000b9141-0006274224f09c56.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000d01f5-000627e203de43a9.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-0000000000079a7a-0006258c2249c2db.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-000000000008af09-000626047137222a.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000c49a4-00062791e5ee2998.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-000000000006e1e6-0006253bfd2fd7ac.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-0000000000090b19-0006262c9b0496db.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000e729e-00062881e9fdfc71.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000d5e4a-00062809e6225856.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000ecef8-000628a9a4eb35dd.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-00000000000bed52-0006276a158a5ede.journal
/rw/overlay-rw/var/log/journal/b99cf6cd560a421fb902bf0ccc6cda0e/system@c17021a863e84ed4893aec12247c0256-0000000000073e6d-00062563a63beefc.journal
/rw/overlay-rw/var/log/syslog.6.gz
/rw/overlay-rw/var/log/vmware-vmtoolsd-root.log
/rw/overlay-rw/var/log/syslog.3.gz
/rw/overlay-rw/var/log/vmware-vmsvc-root.3.log
/rw/overlay-rw/var/log/cma-debug.log.3.gz
/rw/overlay-rw/var/log/btmp
/rw/overlay-rw/var/log/faillog
/rw/overlay-rw/var/log/vmware-vmsvc-root.1.log
/rw/overlay-rw/var/log/samba
/rw/overlay-rw/var/log/samba/log.wb-CHECKMK
/rw/overlay-rw/var/log/samba/log.winbindd.3.gz
/rw/overlay-rw/var/log/samba/log.winbindd.6.gz
/rw/overlay-rw/var/log/samba/log.winbindd.2.gz
/rw/overlay-rw/var/log/samba/log.winbindd.4.gz
/rw/overlay-rw/var/log/samba/log.winbindd.5.gz
/rw/overlay-rw/var/log/samba/cores
/rw/overlay-rw/var/log/samba/cores/winbindd
/rw/overlay-rw/var/log/samba/log.winbindd.1
/rw/overlay-rw/var/log/samba/log.wb-CMA
/rw/overlay-rw/var/log/vmware-vmsvc.1.log
/rw/overlay-rw/var/log/vmware-vmsvc.3.log
/rw/overlay-rw/var/log/cma-debug.log.2.gz
/rw/overlay-rw/var/log/cma-migrate-overlayfs.log
/rw/overlay-rw/var/log/syslog.1.gz-2023072400.backup
/rw/overlay-rw/var/log/vmware-network.6.log
/rw/overlay-rw/var/log/syslog.5.gz
/rw/overlay-rw/var/log/ntpsec
/rw/overlay-rw/var/log/ntpsec/loopstats
/rw/overlay-rw/var/log/ntpsec/loopstats.20250506.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250430.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250503.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250429.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250430.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250502.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250501.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250503.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250504.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250501.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250505.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250502.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250507
/rw/overlay-rw/var/log/ntpsec/peerstats.20250507
/rw/overlay-rw/var/log/ntpsec/peerstats.20250506.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250429.gz
/rw/overlay-rw/var/log/ntpsec/peerstats.20250505.gz
/rw/overlay-rw/var/log/ntpsec/loopstats.20250504.gz
/rw/overlay-rw/var/log/lastlog
/rw/overlay-rw/var/log/vmware-vmsvc.2.log
/rw/overlay-rw/var/log/btmp.1
/rw/overlay-rw/var/log/vmware-network.5.log
/rw/overlay-rw/var/log/syslog.4.gz
/rw/overlay-rw/var/log/vmware-network.log
/rw/overlay-rw/var/log/syslog.2.gz
/rw/overlay-rw/var/log/vmware-network.1.log
/rw/overlay-rw/var/log/private
/rw/overlay-rw/var/log/apache2
/rw/overlay-rw/var/log/apache2/access.log.1
/rw/overlay-rw/var/log/apache2/error.log
/rw/overlay-rw/var/log/apache2/ssl_access.log
/rw/overlay-rw/var/log/apache2/error.log.1
/rw/overlay-rw/var/log/apache2/other_vhosts_access.log
/rw/overlay-rw/var/log/apache2/ssl_access.log.1
/rw/overlay-rw/var/log/cma-debug.log.1
/rw/overlay-rw/var/log/vmware-vmsvc.log
/rw/overlay-rw/var/log/vmware-network.2.log
/rw/overlay-rw/var/log/sysstat
/rw/overlay-rw/var/log/sysstat/sar28
/rw/overlay-rw/var/log/sysstat/sa06
/rw/overlay-rw/var/log/sysstat/sa05
/rw/overlay-rw/var/log/sysstat/sar30
/rw/overlay-rw/var/log/sysstat/sar03
/rw/overlay-rw/var/log/sysstat/sar02
/rw/overlay-rw/var/log/sysstat/sa04
/rw/overlay-rw/var/log/sysstat/sa29
/rw/overlay-rw/var/log/sysstat/sa02
/rw/overlay-rw/var/log/sysstat/sar01
/rw/overlay-rw/var/log/sysstat/sa03
/rw/overlay-rw/var/log/sysstat/sar06
/rw/overlay-rw/var/log/sysstat/sa30
/rw/overlay-rw/var/log/sysstat/sa01
/rw/overlay-rw/var/log/sysstat/sa07
/rw/overlay-rw/var/log/sysstat/sar04
/rw/overlay-rw/var/log/sysstat/sar05
/rw/overlay-rw/var/log/sysstat/sar29
/rw/overlay-rw/var/tmp
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-ntpsec.service-KFyrGn
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-ntpsec.service-KFyrGn/tmp
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-haveged.service-BhoiTT
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-haveged.service-BhoiTT/tmp
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-systemd-logind.service-C4A2X5
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-systemd-logind.service-C4A2X5/tmp
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-apache2.service-vGMhxD
/rw/overlay-rw/var/tmp/systemd-private-cc06b81c479f438ca57643371f9801c4-apache2.service-vGMhxD/tmp
/rw/overlay-rw/var/backups
/rw/overlay-rw/var/backups/gshadow.bak
/rw/overlay-rw/var/backups/dpkg.arch.2.gz
/rw/overlay-rw/var/backups/dpkg.arch.5.gz
/rw/overlay-rw/var/backups/group.bak
/rw/overlay-rw/var/backups/dpkg.statoverride.2.gz
/rw/overlay-rw/var/backups/dpkg.diversions.1.gz
/rw/overlay-rw/var/backups/dpkg.statoverride.4.gz
/rw/overlay-rw/var/backups/alternatives.tar.2.gz
/rw/overlay-rw/var/backups/dpkg.diversions.4.gz
/rw/overlay-rw/var/backups/dpkg.arch.3.gz
/rw/overlay-rw/var/backups/dpkg.statoverride.5.gz
/rw/overlay-rw/var/backups/dpkg.statoverride.6.gz
/rw/overlay-rw/var/backups/dpkg.status.0
/rw/overlay-rw/var/backups/dpkg.diversions.0
/rw/overlay-rw/var/backups/dpkg.statoverride.0
/rw/overlay-rw/var/backups/passwd.bak
/rw/overlay-rw/var/backups/dpkg.diversions.2.gz
/rw/overlay-rw/var/backups/dpkg.diversions.5.gz
/rw/overlay-rw/var/backups/dpkg.status.6.gz
/rw/overlay-rw/var/backups/alternatives.tar.4.gz
/rw/overlay-rw/var/backups/alternatives.tar.6.gz
/rw/overlay-rw/var/backups/dpkg.status.2.gz
/rw/overlay-rw/var/backups/alternatives.tar.5.gz
/rw/overlay-rw/var/backups/dpkg.diversions.3.gz
/rw/overlay-rw/var/backups/alternatives.tar.1.gz
/rw/overlay-rw/var/backups/dpkg.status.5.gz
/rw/overlay-rw/var/backups/alternatives.tar.0
/rw/overlay-rw/var/backups/alternatives.tar.3.gz
/rw/overlay-rw/var/backups/dpkg.status.3.gz
/rw/overlay-rw/var/backups/dpkg.status.1.gz
/rw/overlay-rw/var/backups/dpkg.arch.4.gz
/rw/overlay-rw/var/backups/dpkg.arch.0
/rw/overlay-rw/var/backups/dpkg.arch.1.gz
/rw/overlay-rw/var/backups/dpkg.statoverride.3.gz
/rw/overlay-rw/var/backups/dpkg.statoverride.1.gz
/rw/overlay-rw/var/backups/shadow.bak
/rw/overlay-rw/var/backups/dpkg.status.4.gz
/rw/overlay-rw/var/backups/dpkg.diversions.6.gz
/rw/overlay-rw/var/cma
/rw/overlay-rw/var/cma/webconf
/rw/overlay-rw/var/cma/webconf/bruteforce_throttle.json
/rw/overlay-rw/var/cma/webconf/session_db.json
/rw/overlay-rw/root
/rw/overlay-rw/root/index.html
/rw/overlay-rw/root/.local
/rw/overlay-rw/root/.local/share
/rw/overlay-rw/root/.local/share/nano
/rw/overlay-rw/root/.rpmdb
/rw/overlay-rw/root/.rpmdb/rpmdb.sqlite
/rw/overlay-rw/root/.rpmdb/__db.003
/rw/overlay-rw/root/.rpmdb/__db.001
/rw/overlay-rw/root/.rpmdb/__db.002
/rw/overlay-rw/root/.rpmdb/rpmdb.sqlite-wal
/rw/overlay-rw/root/.rpmdb/rpmdb.sqlite-shm
/rw/overlay-rw/root/.gnupg
/rw/overlay-rw/root/.gnupg/private-keys-v1.d
/rw/overlay-rw/root/.gnupg/trustdb.gpg
/rw/overlay-rw/root/.forward
/rw/overlay-rw/root/.wget-hsts
/rw/overlay-rw/root/.bash_history
/rw/overlay-rw/root/sslbackup_09.10.24
/rw/overlay-rw/root/sslbackup_09.10.24/info.txt
/rw/overlay-rw/root/sslbackup_09.10.24/files
/rw/overlay-rw/root/sslbackup_09.10.24/files/apache.key
/rw/overlay-rw/root/sslbackup_09.10.24/files/apache-chain.crt
/rw/overlay-rw/root/sslbackup_09.10.24/files/apache.crt
/rw/overlay-rw/rw
/rw/overlay-rw/fw_update
/rw/overlay-rw/mnt
/rw/overlay-rw/mnt/auto
/rw/overlay-rw/etc
/rw/overlay-rw/etc/hosts
/rw/overlay-rw/etc/group
/rw/overlay-rw/etc/rc4.d
/rw/overlay-rw/etc/rc4.d/S01ssh
/rw/overlay-rw/etc/rc4.d/K01ssh
/rw/overlay-rw/etc/console-setup
/rw/overlay-rw/etc/console-setup/cached_UTF-8_del.kmap.gz
/rw/overlay-rw/etc/console-setup/cached_setup_keyboard.sh
/rw/overlay-rw/etc/console-setup/cached_setup_terminal.sh
/rw/overlay-rw/etc/console-setup/cached_Lat15-Fixed16.psf.gz
/rw/overlay-rw/etc/console-setup/cached_setup_font.sh
/rw/overlay-rw/etc/localtime
/rw/overlay-rw/etc/postfix
/rw/overlay-rw/etc/postfix/sasl
/rw/overlay-rw/etc/postfix/sasl/sasl_passwd
/rw/overlay-rw/etc/postfix/sasl/sasl_passwd.db
/rw/overlay-rw/etc/postfix/main.cf
/rw/overlay-rw/etc/ssl
/rw/overlay-rw/etc/ssl/localcerts
/rw/overlay-rw/etc/ssl/localcerts/apache.key
/rw/overlay-rw/etc/ssl/localcerts/apache-chain.crt
/rw/overlay-rw/etc/ssl/localcerts/apache.crt
/rw/overlay-rw/etc/ssl/certs
/rw/overlay-rw/etc/ssl/private
/rw/overlay-rw/etc/resolv.conf
/rw/overlay-rw/etc/ssh
/rw/overlay-rw/etc/ssh/ssh_host_rsa_key.pub
/rw/overlay-rw/etc/ssh/ssh_host_dsa_key.pub
/rw/overlay-rw/etc/ssh/ssh_host_ecdsa_key.pub
/rw/overlay-rw/etc/vmware-tools
/rw/overlay-rw/etc/vmware-tools/quiesce_manifest.xml
/rw/overlay-rw/etc/rc2.d
/rw/overlay-rw/etc/rc2.d/S01ssh
/rw/overlay-rw/etc/rc2.d/K01ssh
/rw/overlay-rw/etc/machine-id
/rw/overlay-rw/etc/shadow-
/rw/overlay-rw/etc/passwd-
/rw/overlay-rw/etc/group-
/rw/overlay-rw/etc/network
/rw/overlay-rw/etc/network/interfaces
/rw/overlay-rw/etc/rc5.d
/rw/overlay-rw/etc/rc5.d/S01ssh
/rw/overlay-rw/etc/rc5.d/K01ssh
/rw/overlay-rw/etc/auto.cma
/rw/overlay-rw/etc/gshadow-
/rw/overlay-rw/etc/hostname
/rw/overlay-rw/etc/ntpsec
/rw/overlay-rw/etc/ntpsec/ntp.conf
/rw/overlay-rw/etc/rc3.d
/rw/overlay-rw/etc/rc3.d/S01ssh
/rw/overlay-rw/etc/rc3.d/K01ssh
/rw/overlay-rw/etc/.pwd.lock
/rw/overlay-rw/etc/mail.rc
/rw/overlay-rw/etc/nullmailer
/rw/overlay-rw/etc/nullmailer/sendtimeout
/rw/overlay-rw/etc/nullmailer/default-from
/rw/overlay-rw/etc/nullmailer/adminaddr
/rw/overlay-rw/etc/nullmailer/defaultdomain
/rw/overlay-rw/etc/nullmailer/remotes
/rw/overlay-rw/etc/systemd
/rw/overlay-rw/etc/systemd/system.control
/rw/overlay-rw/etc/systemd/system.control/user.slice.d
/rw/overlay-rw/etc/systemd/system.control/user.slice.d/50-MemoryHigh.conf
/rw/overlay-rw/etc/systemd/system/sshd.service
/rw/overlay-rw/etc/systemd/system/multi-user.target.wants
/rw/overlay-rw/etc/systemd/system/multi-user.target.wants/ssh.service
/rw/overlay-rw/etc/mailname
/rw/overlay-rw/etc/apache2
/rw/overlay-rw/etc/apache2/conf-available
/rw/overlay-rw/etc/apache2/conf-available/cma-default-gui.conf
/rw/overlay-rw/etc/apache2/conf-available/cma-servername.conf
/rw/overlay-rw/etc/apache2/conf-http-enabled
/rw/overlay-rw/etc/apache2/conf-http-enabled/cma-http-to-https.conf
/rw/overlay-rw/etc/apache2/sites-available
/rw/overlay-rw/etc/apache2/sites-enabled
/rw/overlay-rw/etc/apache2/sites-enabled/cma-https.conf
/rw/overlay-rw/etc/apache2/mods-enabled
/rw/overlay-rw/etc/apache2/mods-enabled/socache_shmcb.load
/rw/overlay-rw/etc/apache2/mods-enabled/headers.load
/rw/overlay-rw/etc/apache2/mods-enabled/ssl.load
/rw/overlay-rw/etc/apache2/mods-enabled/ssl.conf
/rw/overlay-rw/etc/apache2/mods-enabled/rewrite.load
/rw/overlay-rw/etc/apache2/conf-https-enabled
/rw/overlay-rw/etc/apache2/conf-https-enabled/cma-https-enable-cert-chain.conf
/rw/overlay-rw/etc/ntp.conf
/rw/overlay-rw/etc/mtab
/rw/overlay-rw/etc/ld.so.cache
/rw/overlay-rw/etc/cma
/rw/overlay-rw/etc/cma/device.secret
/rw/overlay-rw/etc/cma/device.conf
/rw/overlay-rw/etc/cma/cma.conf
/rw/overlay-rw/etc/cma/cookie.secret
/rw/overlay-rw/etc/fstab
/rw/lost+found
/rw/overlay-work
/rw/overlay-work/work
root@checkmk:~#
root@checkmk:~# find /rw/ | grep "/rw/overlay-rw/etc/"
root@checkmk:~#
I pretty much never modified any files manually, only installed some Extension Packages.
Also I once renewed the certificate manually via SSH since I didn’t know at the time yet, that it is possible to renew it via webconf.
Other than that, no.
Greetings
Could you please remove the not redacted sitename.
I forgot to remove that :frowning:
Thanks. I noticed this command:
/omd/sites/REDACTED/bin/xmlsec1 --sign --privkey-pem /omd/sites/REDACTED/etc/ssl/saml2/custom/REDACTED/signature/private.pem --id-attr:ID urn:oasis:names:tc:SAML:2.0:protocol:AuthnRequest --node-id id-IDREDACTED --output /tmp/tmpsdp2327g.xml --lax-key-search /tmp/tmptmcsxf0i.xml
What have you defined here in the SAML connection ?
If its Custom, can you try to switch to builtin as a test and share the error message again ?
I switched to the Checkmk cert and it works!
Previously I generated one internally and uploaded that to Azure and put it in the SAML config.
Thank you for the help, if it works that way I will leave it as is.
Or are there any security risks if I use the cert of Checkmk?
Greetings
Max
(The one I uploaded to Azure is from our internal AD CS, which is trusted by Checkmk)
As per the inline help:
Checkmk signs your SAML 2.0 requests to your identity provider. You can use the certificate that comes with Checkmk. Alternatively, if your organization manages its own certificates, you can add a custom certificate. Note that the public certificate must be a single certificate (not a certificate chain). Only RSA certificates are supported at this time.
So, in principle custom certificates should work if it matches the above criteria. If you could try this on a freshly created test site, then this will help to nail down the problem ?
If the own Checkmk certificate works, I will probably just leave it as is.
But thank you for your help!
