As the documentation states that you should disable the automatic agent update during the upgrade and the fact that you can update the agent later tells me that it should be possible: Update to version 2.0.0 (checkmk.com)
I know the guide you’ve provided states this already, more making sure in your experience what the best practice would be.
Also, when I was reading the update process I couldn’t find in 1.6.0p9 how to disable the agents in this version (pictures look like they reflect 2.0). Any suggestions to disable all the agents from checking in while the update happens?
I did an upgrade from some old version, don’r not it exactly anymore to 2.0.0p7, this has worked. So I assume that it could also be working with p22, but I cannot a guarantee to it.
