CheckMk Agent execution
Can you let us know if checkmk windows agent will execute this.
Command Line Arguments: wmic qfe get HotfixID,Description,InstalledOn /format:csv
Tactics: Execution
Techniques: Windows Management Instrumentation
Write a small wrapper script that calls your wanted wmic query and then formats the output in a way that it can be processed by CMK.
Maybe yeah, although the script for check updates does some curious COM object stuff that may or may not do WMI behind the scenes. Hard to tell.
Can’t put exceptions for the checkmk agent into what I presume is your hair-trigger security monitoring tool?
@andreas-doehler I think they’re wanting it to NOT do it. The Tactics/Techniques thing sounds like security event classifications to me (that is, some security company thinks this WMI query is suspicious).
@bmst then it would be better to ask the question this way :smiley:
I wrote a small plugin what shows the hotfix status and it works nearly the same way as the wmic query there only in Powershell. If such things are a problem for your security then would be good to ask how you can restrict the agent by itself.
We can say, i think, the agent can execute all what you can do as local system on this machine.
Aye, I’m reading the intent between the lines a bit. We could use more context about how big a deal it is. Like, if they’re trying to establish the legitimacy of a flagged incident, maybe we do need a very concrete answer. If they’re just scoping out Checkmk as a potential product, well maybe it doesn’t matter so much.
they are seeing that this is utilizing more CPU so want to understand if it is caused by check_mk agent ot anything else
They can attribute CPU usage to a particular process but not trace its parent processes? Can they put a timestamp on it and correlate it with the running of the agent?
this is the command it is executing wmic qfe get so does checkMk agent use this
Dear @nvnbs
I believe that the Checkmk agent does not do that per default, but the developers of the agent may prove me wrong…
I think what @bmst was trying to tell you above is that the Checkmk agent may be using
something similar if - whoever configured this machine - has installed the Windows Updates check plugin. You could check whether this plugin exists, and how it is executed (because one is supposed to execute this “cached”): If it’s executed too frequently, it may indeed result in higher than normal CPU utilization.
HTH,
Thomas
Thanks alot we figured it was not checkMK agent which is executing it there are other Agents responsible for this thanks all for the Help :slight_smile:
@bmst : thank you so much for the inputs
