CMK version: Enterprise Edition 2.1.0p9 OS version: Red Hat Enterprise Linux
Error message: No explicit error message
Hi everyone,
I’m trying to add a custom check to the services overview, for this I use a python script which is opened by the CheckMK agent. But as soon as I add "import requests " to the code the check doesn’t show up anymore.
When I execute the file with a Python command it runs normally under both my own user and as root and there’s no error whatsoever and it runs fine. The CheckMK agent also doesn’t give any error, but it still doesn’t fully function as expected. Note that the result doesn show up just a usual in the command line output after the check_mk_agent comamnd.
Here’s a screenshot where my check (Service ResilientHeartbeat_20) is seen as an undecided service.
Hi Sander, does your python script file name ends with .py ?
Please try to remove the file ending .py.
Maybe that helps. It is just an idea. We had this behavior several times… That the agent ignore scripts as long as they have .py at the end.
Thanks for the suggestion, didn’t think of that one! I just did a few tests with the file extension removed, but the behavior is exactly the same sadly, so the issue still persists
Apparmor doesn’t seem to be installed, aa-status gives “command not found”. But if anyone has any suggestions on other loggings that might be relevant I’m happy to have a look.
