Checkmk_ansible_modules
I have started to build ansible modules in ruby. For now you can modify and create users and activate changes. Have a look at: https://github.com/ogaida/checkmk_ansible_modules.
I’ve also made some Ansible modules. I did it in Python and use the Molecule test framework. They’re not public available yet, but if there is any interest…
I’ve got the following modules:
  • checkmk_activate_changes
  • checkmk_auxtag
  • checkmk_bake_agents
  • checkmk_contactgroup
  • checkmk_discover_services
  • checkmk_folder
  • checkmk_get_all_contactgroups
  • checkmk_get_all_folders
  • checkmk_get_all_hostgroups
  • checkmk_get_all_hosts
  • checkmk_get_all_servicegroups
  • checkmk_get_folder
  • checkmk_get_host
  • checkmk_get_hosttags
  • checkmk_get_ruleset
  • checkmk_get_rulesets_info
  • checkmk_host
  • checkmk_hostgroup
  • checkmk_ruleset
  • checkmk_servicegroup
  • checkmk_taggroup
Hi Maarten,
thats brilliant, i am very interested in to check them. Do your modules write checkmk objects too, or only read?
Best Regards
Oliver
Hi Oliver,
The modules that start with checkmk_get_ do only reading. The modules with a ‘noun’ change that object en with ‘verbs’ (checkmk_activate_changes, checkmk_bake_agents, checkmk_discover_services`) are actions.
I need to check if I need something to change to make it publicly available. I get back to you.
Regards,
Maarten
Hey there any chance you made those public? I’d really like to check them out!
Here are also some funktions included (register agent, activate changes etc)
I’m interested in the status of the services per host. And @maartenq’s example provided that. This is why the question was more to him.
It would be awesome if the check_mk team would keep maintaining a check_mk module library and documentation on how to use those.
GitHub - tribe29/ansible-checkmk: Ansible integration of CheckMK is a start but not nearly complete and also has some issues.
An example from netbox. Keeping them in a git repo is faster than having to wait for pip updates for Ansible modules which can take some time.
https://netbox-ansible-collection.readthedocs.io/en/latest/getting_started/installation.html
Thanks!
Pingback to other post: Checkmk goes Ansible - #5 by marcel.arentz
