Sometimes CheckMK Discovery return this error when on Cisco FTD instantace (Firepower)
no unmonitored services found, 83 vanished services (cisco_asa_failover:1, cisco_cpu_multiitem:14, if64:66, snmp_info:1, uptime:1), no new host labels, [snmp] SystemError(‘ returned a result with an error set’)CRIT
[snmp] Success, execution time 39.9 sec | execution_time=39.850 user_time=0.380 system_time=0.040 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=39.430 cmk_time_agent=0.000
This is a typical timeout error message. As you use the enterprise edition i would define a higher timeout than the default 60 seconds for the discovery service. Something like 5 minutes.
I guess I have a similar issue with 2 of our largest switches since I moved from nagios to cmc. Check_MK is OK, but Check_MK Discovery delivers the same system error.
How can I change the max timeout for the discovery service? I only find a rule “Periodic Service Discovery”, but there is no parameter for timeout.
Looking at the “SNMP rules” I find “Timing settings for SNMP access” but there a value larger than 60 sec. for “Response timeout for a single query” is refused.
If you use the enterprise edition you can find the rule → Service check timeout (Microcore)
There you can define for every active check other timeout values.
Thanks for getting back. My apologies maybe i wasn’t being descriptive. My question is how do i define the service discovery for a new host with a longer timeframe (600seconds) when it times out by default at 110seconds. Example. I have a juniper stack of 9 switches and it seems to timeout at 110 with no services listed and instead just this error message
