I’d like to use check_mk raw under Ubuntu 22.04 running on an ODROID XU4 (armhf/armv7 architecture). I can only see Ubuntu versions for amd64 or Raspbian versions für armhf. I guess both won’t work. Which version should I use?
Hi Frank,
I think the official answer is :
tldr; there is and there will be no short term solution for checkmk server on ARM Processors.
There is an inofficial ARM built, but i would not recommend to use that in production.
Hi Andre,
thanks for your quick reply!
I yesterday started using checkmk in a docker but ran into a check_icmp error (Failed to obtain ICMP socket: Operation not permitted), which I can’t fix.
Both limitations seems to be the end of my checkmk story. Very sad!
Hi Frank,
i think the docker error is a permission problem with your synology, that is not primarily a checkmk issue.
There are several other options to use checkmk:
- Different Linux Operating Systems (Ubuntu, Debian,SuSE, Red Hat)
- The virtual checkmk Appliance (OVA)
- Hardware Appliances
- Cloud Options (AWS, Azure)
- Docker Container (On other nodes than a synology NAS Device)
- Inofficial ARM Builds (not for production use)
- a SAAS offer will probably be coming this year
If all these options are not enough, then yes, this might be the end of your checkmk story.
Thanks again, Andre.
I will check some of the other options you mentioned!
