Hi All,
I’m trying to find information concerning what the best way is to synchronize configuration between 2 instances of checkMK?
In other words: if I add/remove hosts on one instance, what’s the best way to synchronize this to a second CheckMK instance? We are trying to avoid having to do double work with each change in checkMK. We have 2 instances that are redundant from eachother.
If there is a better way, completely different from this, I am all ears as well. I looked into distributed monitoring, but that’s not really what I’m looking for as far as I can tell.
We have 2 datacenters that each have a checkMK instance running. At the moment, we have to manually do each change twice.
Thank you for feedback or pointing me in the right direction.
Kind regards
