Checkmk Integration with Grafana(Could not read API response)
Previously the integration was running fine but we have recently upgraded our checkmk from 2.1 to 2.2op8 and now when I run the test in Grafana it gives the below error:
Also on the Grafana server when I run the checkmk URL ,
curl http://IP/checkmk/ -k
Also, the firewall is inactive on both the checkmk and Grafana server.
Please can some guide.
BR
//Prachi
it seems that you are using an older version of the grafana plugin. Can you please update the grafana plugin to the current version and try again?
Well, the grafana plugin version is
And as per the documentation , its version is above 8
Also the datasource taken is
BR
//Prachi
If I remember correctly for Checkmk 2.2 you’ll need the Checkmk datasource at least in version 2.1.
Thank you, yes after updating to latest data source its resolved.
BR
//Prachi
