Recently we had some issues with the NFS filesyste. some of them are not mounting properly in the servers. the checkmk agent by default doesnot include the NFS filesystems in the monitoring.
We need to have monitoring for the NFS filesystem that is mounted in the server along with the disks. There is a post in the community regarding the same and the solution suggested is working for check_mk agent 1.6
But it is not working for check_mk agent 2.2. Can someone help on this to enable the monitoring for NFS filesystems.
Thanks, seems the agent is fetching the NFS details under section <<<nfsmounts_v2:sep(0)>>>
also, the agent output downloaded from the console also having the NFS details. still I’m not able to see the metrics even after doing the re-scan. Kindly suggest.
if you run a service discovery with tabular rasa you should see the NFS mounts as disabled
If so you have some rules that suppress (not the same as disable) them.
Thanks. In my case, the nfs mount health check was disabled in service discovery rules.
after excluding the servers from the rule, I’m able to see the utilization in checkmk. but still, am not able to see the historic graphical information. Is it same for you ? @andreas-doehler@Anders
