CMK version: 2.0
OS version: Centos 7
Error message: tmp directory is not ready. Use “omd start” to prepare it
Hi For some reason i cant not start the nagios service on the OMD:
Caon some one help me please?
CMK version: 2.0
Usually each site has a separate tmpfs, mounted on /opt/omd/sites/SITENAME/tmp. You can check the config with omd config show TMPFS as site user.
But even if you don’t use a (fast because RAM based) tmpfs, in any case you need the ~/tmp directory in the site home. By default it has 0755 permissions (drwxr-xr-x) and is owned by the site user/group. Check if perhaps this directory is missing in your site’s home or has wrong permissions/owner/group.
Ah, your screenshow shows “Temporary filesystem already mounted”, so TMPFS is obviously configured.
You can try omd disable SITENAME; omd enable SITENAME; omd start SITENAME (instead of just stop/start). This should unmount and re-mount the tmpfs.
Or debug further with:
mount | grep /sites
df -h -t tmpfs | grep /sites
grep omd/sites /etc/fstab
ls -ld /opt/omd/*/tmp
