CheckMK on TrueNAS Scale
CMK version: 2.1.0p15
OS version: TrueNAS SCALE 22.02.4
I installed the CheckMK Agent on a TrueNAS SCALE host. After the installation everything worked. After a reboot the cmk-agent-ctl-daemon and the check-mk-agent.socket failed.
I had to add the checkmk user again.
After that the service and the socket both seemed to work again but the daemon did not bind port 6556 so the agent did not work.
Any ideas how to get this working?
Hi, I use ssh with the authorized_keys file to connect to the agent instead of systemd.
You can configure the authorized_keys file in the root user settings via the WebGUI.
Thanks, great idea. Had to disable agent output encryption for this though. (Just wanted to note this here if anyone stumbles across this.)
How have you realized that the CheckMK is still installed after reboot?
it should still be installed, the user is missing though.
I know it’s a hacky solution and there’s probably a better one, but I added the following command as a pre init script: useradd -r -s /bin/false cmk-agent
After a TrueNAS update you also have to reinstall the agent and reregister for updates and TLS I think.
Maybe I’ll switch to just reinstalling the deb package in the future…
Ok since an update or something it’s not really working anymore. After a reboot of the system CheckMK isn’t able anymore to get access to the system.
I tried with ā€œsudo apt install --reinstall ./check-mk*ā€ but the same - no connection.
Has anybody a good solution?
-Install is not possible / only reinstall without any effect
-check-mk-agent.socket fails - after creating the user it’s possible to start the service
-no open socket for 6556
-not able to register the agent (cmk_agent_ctl - No such file or directory)*
*it’s there with +x
Any ideas how to the the CheckMK service running again?
I use this script for installing and registering the agent. It is placed in my home folder ā€œ/mnt/zfs_pool_01/myhomedir/install_checkmk_agent_from_bakery_true_nas_scale.shā€
The script is executed as user Root. (login as user; then sudo su -; then execute the install script)
This:
apt -y install python3-pip
pip3 install docker
is possibly not working in the current version of TrueNAS Scale. The Debian repo is missing. If you want to see the docker values, you have to add the repo tempoarily, install the package and add the docker plugin to the agent.
#!/bin/bash
#set -x
AUTOMATION_USER="automation"
AUTOMATION_PASS="xxxxxxx"
CMK_SERVER="xxxxxx"
CMK_SITE="xxxxxx"
CMK_PROTO="https"
REGISTRATION_USER="cmkadmin"
REGISTRATION_PASS='xxxxxxx'
REGISTER_PROTO="https"
HOSTNAME=`hostname -s`
CMK_URL="$CMK_PROTO://$CMK_SERVER/$CMK_SITE"
chmod +x /bin/apt*
chmod +x /usr/bin/dpkg
apt -y install curl
# for docker plugin
pip3 install docker
# pip3 install --upgrade docker==5
rm -rf /tmp/downloaded_agent.deb
# host = hostname
HOST="$HOSTNAME"
curl --insecure -o /tmp/downloaded_agent.deb $CMK_URL/check_mk/download_agent.py -d "_username=$AUTOMATION_USER&_secret=$AUTOMATION_PASS&host=$HOST&os=linux_deb"
apt install /tmp/downloaded_agent.deb
# register agent
CMK_UPDATE_AGENT=`which cmk-update-agent`
$CMK_UPDATE_AGENT register -s $CMK_SERVER -i $CMK_SITE -H $HOSTNAME -p $REGISTER_PROTO -U $REGISTRATION_USER -P $REGISTRATION_PASS -v
# tls (optional - if I don't have to, I will not use tls)
#CMK_AGENT_CTL=`which cmk-agent-ctl`
#$CMK_AGENT_CTL register -s $CMK_SERVER -i $CMK_SITE -H $HOSTNAME -U $REGISTRATION_USER -P $REGISTRATION_PASS -v --trust-cert
$CMK_UPDATE_AGENT -v
And I have some Cronjobs in the TrueNAS Scale GUI defined. I’m unsure if they are still needed. They are running every minute.
a)
if [ ! -d /usr/lib/check_mk_agent ]; then ln -s /mnt/zfs_pool_01/checkmk/check_mk_agent /usr/lib/ > /dev/null 2> /dev/null; else echo ā€˜/usr/lib/check_mk_agent does exist’; fi
b)
chmod +x /bin/apt* ; chmod +x /usr/bin/dpkg
Thank you, I will check this out. The issue I had where to activate CheckMK again after the reboot
Btw. do you use TrueNAS Plugins? I used some plugins but they are only compatible with Core - So I have to translate them.
Edit:
I made it - CheckMK access via SSH. And I wrote a script which Checks for TrueNAS Scale Updates.
Sounds good. Would you post it here?
There is also the possibility to pipe the agent to the shell that is opened in the SSH connection. This works as long as no plugins are required:
Hey guys
Since Dragonfish and the ā€œread-onlyā€ problematic - any workaround to get the CheckMK agent running?
Greetz
I’m still on Cobia as 24.04.1 was just released a few days ago. Which read only problem?
Edit: I found what you mean, the boot pool is readonly. I think we’ll either have to use developer mode or try to set it to rw otherwise.
Another option would be to not use the standard Debian package but rather create a custom agent…that would disable agent updates though
I took a closer look at the install-dev-tools command.
The interesting part for us is /usr/local/libexec/disable-rootfs-protection $FORCE_ARG.
/usr/local/libexec/disable-rootfs-protection is a python script which does a few things:
  • checks the license (if an enterprise license is used, the above-mentioned ā€œFORCE_ARGā€ (–force) is needed)
  • looks up the dataset configuration (/conf/truenas_root_ds.json)
  • flags the root dataset as developer mode (truenas:developer=on)
  • sets all datasets listed in /conf/truenas_root_ds.jsonto rw
  • chmods apt and dpkg as executable
To install the checkmk agent we already chmod apt and dpkg so /usr/local/libexec/disable-rootfs-protection is exactly what we want for non-enterprise configurations.
I am personally using checkmk to monitor my home NAS so running this script is no problem for me.
For enterprise users who might need support for their TrueNAS installation this is no option of course…
In this case a minimal agent installed to some writable dataset and called via SSH would probably be a better solution.
