Checkmk Raw Edition 2.4.0p20 running as podman container: Error running automation call service-discovery-preview: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
CMK version: Checkmk Raw Edition 2.4.0p20
OS version: Rocky Linux 9.7
cmk does not work inside the container, it appears the CheckMK docker image is somehow missing useful features, like cmk amd SSL support for the webserver. But I have this stacktrace in the /check_mk/user_message.py page:
Failed to execute the test ACTestDeprecatedRuleSets: Traceback (most recent call last):
  File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connectionpool.py", line 787, in urlopen
    response = self._make_request(
  File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connectionpool.py", line 493, in _make_request
    conn.request(
  File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connection.py", line 500, in request
    self.endheaders()
  File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1333, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1093, in _send_output
    self.send(msg)
  File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1037, in send
    self.connect()
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/automation_helper.py", line 84, in connect
    self.sock.connect(str(paths.omd_root.joinpath(AUTOMATION_HELPER_SOCKET)))
FileNotFoundError: [Errno 2] No such file or directory
  File "/omd/sites/cmk/lib/python3.12/site-packages/requests/adapters.py", line 667, in send
    resp = conn.urlopen(
  File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connectionpool.py", line 841, in urlopen
    retries = retries.increment(
  File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/util/retry.py", line 490, in increment
    raise reraise(type(error), error, _stacktrace)
  File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/util/util.py", line 38, in reraise
    raise value.with_traceback(tb)
    conn.request(
    self.endheaders()
    self.send(msg)
    self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/automations.py", line 130, in check_mk_local_automation_serialized
    result = executor.execute(command, args, stdin_data, auto_logger, timeout)
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/automation_helper.py", line 50, in execute
    response = session.post(AUTOMATION_HELPER_ENDPOINT, json=payload)
  File "/omd/sites/cmk/lib/python3.12/site-packages/requests/sessions.py", line 637, in post
    return self.request("POST", url, data=data, json=json, **kwargs)
  File "/omd/sites/cmk/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "/omd/sites/cmk/lib/python3.12/site-packages/opentelemetry/instrumentation/requests/__init__.py", line 333, in instrumented_send
    raise exception.with_traceback(exception.__traceback__)
  File "/omd/sites/cmk/lib/python3.12/site-packages/opentelemetry/instrumentation/requests/__init__.py", line 255, in instrumented_send
    result = wrapped_send(
  File "/omd/sites/cmk/lib/python3.12/site-packages/opentelemetry/instrumentation/requests/__init__.py", line 180, in instrumented_send
    return wrapped_send(self, request, **kwargs)
  File "/omd/sites/cmk/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "/omd/sites/cmk/lib/python3.12/site-packages/requests/adapters.py", line 682, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/analyze_configuration.py", line 174, in run
    for result in self.execute():
  File "/omd/sites/cmk/lib/python3/cmk/gui/wato/_ac_tests.py", line 1374, in execute
    for r in find_unknown_check_parameter_rule_sets().result
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/check_mk_automations.py", line 571, in find_unknown_check_parameter_rule_sets
    _automation_serialized(
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/check_mk_automations.py", line 61, in _automation_serialized
    cmdline, serialized_result = check_mk_local_automation_serialized(
  File "/omd/sites/cmk/lib/python3/cmk/gui/watolib/automations.py", line 137, in check_mk_local_automation_serialized
    raise MKAutomationException(msg)
cmk.gui.watolib.automations.MKAutomationException: Error running automation call find-unknown-check-parameter-rule-sets: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
This does not work in Checkmk 2.4.0.
We highly recommend solving this issue already in your installation.
Affected sites: cmk
Details:
    conn.request(
    self.endheaders()
    self.send(msg)
    self.connect()
    conn.request(
    self.endheaders()
    self.send(msg)
    self.connect()
I don’t know how to reproduce it yet. I have another podman container on another machine which is running fine (still) with an almost similar set of hosts & services.
