Hi everyone, I’m looking for a way to pair Jira and checkmk. More precisely, I would like to have a ticket created in Jira at a monitoring event. Also an automatic close if a recovery message is available.
At https://forum.checkmk.com/t/check-mk-english-integration-with-jira-to-open-update-close-tickets/14204/4
a plugin by Heinlein support is suggested.
Code can be found under:
python module has been installed with:
pip install jira
Once the mkp (v0.2) is installed you have to create 2 custom fields in Jira:
monitoring-host
for the hostname
monitoring-service
for the service description
I created those as “Text Field (single line)” as described for the new plugin (https://checkmk.de/cms_notifications_jira.html).
Got all the IDs I need, but:
I get the following error in the notify.log:
020-03-31 13:48:44 - adding notification of cmkadmin via jira
2020-03-31 13:48:44 Executing 1 notifications:
2020-03-31 13:48:44 * notifying cmkadmin via jira, parameters: username, project, monitoring, url, priority, issuetype, password, resolution, bulk: no
2020-03-31 13:48:44 executing /omd/sites/test/local/share/check_mk/notifications/jira
2020-03-31 13:48:45 Output: Unable to create issue, JIRA response code 400, Operation value must be a string
2020-03-31 13:48:45 Plugin exited with code 2
When I remove the custom fields in Jira - issues get created without any hassle - but I need the issues to be closed as well.
Seems to be an error while passing the extra-field in create ticket.
Anybody had this issue or might have an idea how to resolve this?
