CMK version:
check_mk_agent | head
<<<check_mk>>>
Version: 2.1.0p14
AgentOS: linux
Hostname: kenmore-1pnt.kenmore-envelope.local
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
FailedPythonReason:
OS version:
Centos6
rpm -ivh --force check-mk-agent-2.1.0p14-1.noarch.rpm
Preparing... ########################################### [100%]
/var/lib/cmk-agent/scripts/super-server/setup: line 8: realpath: command not found
/var/lib/cmk-agent/scripts/super-server/1_xinetd/setup: line 6: realpath: command not found
/var/lib/cmk-agent/scripts/super-server/0_systemd/setup: line 6: realpath: command not found
1:check-mk-agent ########################################### [100%]
systemd not found on this system
Deployed xinetd
Creating/updating cmk-agent user account ...
Reloading xinetd
Reloading configuration: [ OK ]
**Output of “cmk --debug -vvn hostname”:** (If it is a problem with checks or plugins)
