I m running Checkmk Raw Edition 2.1.0p4. I m trying to configure the HW/SW Inventory plugin to interrogate multiple appliances’ firmware versions. The problem arrises with my Fortigate firewall. The firmware version is present in /omd/sites/monit/tmp/check_mk/data_source_cache/snmp/inventory/fw.s.com
, but it is shown neither in Inventory, nor in Services sections of the host.
Running cmk --debug -vv --inventory-as-check fw.s.com -i
produces the following output (redacted in order not to be marked as spam):
+ FETCHING DATA
[cpu_tracking] Start [7fbfc196f580]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(fw.s.com, base_path=/omd/sites/monit/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 182 sec, allowed is 120 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -On -OQ -Oe -Ot 10.10.1.1 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["fortigate"]
b'fortigate'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -On -OQ -Oe -Ot 10.10.1.1 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.12356.101.1.1041]
b'.1.3.6.1.4.1.12356.101.1.1041'
Using cached OID .1.3.6.1.2.1.1.1.0: 'fortigate'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.12356.101.1.1041'
Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -On -OQ -Oe -Ot 10.10.1.1 .1.3.6.1.2.1.2.2.1'
SNMP answer: ==> [1]
b'1'
Using cached OID .1.3.6.1.4.1.2036.2.1.1.4.0: None
Getting OID .1.3.6.1.4.1.674.*: Running 'snmpgetnext -Cf -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -On -OQ -Oe -Ot 10.10.1.1 .1.3.6.1.4.1.674'
SNMP answer: ==> ["fortigate_serial"]
failed.
Getting OID .1.3.6.1.2.1.47.1.1.1.1.*: Running 'snmpgetnext -Cf -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -On -OQ -Oe -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1'
SNMP answer: ==> ["Fortinet fortigate_monumber, HW Serial#: fortigate_serial"]
b'Fortinet fortigate_monumber, HW Serial#: fortigate_serial'
SNMP scan found fortigate_ha hr_mem inv_if snmp_extended_info snmp_info snmp_os snmp_uptime
Trying to acquire lock on /omd/sites/monit/tmp/check_mk/snmp_scan_cache/fw.s.com.10.10.1.1
Got lock on /omd/sites/monit/tmp/check_mk/snmp_scan_cache/fw.s.com.10.10.1.1
Releasing lock on /omd/sites/monit/tmp/check_mk/snmp_scan_cache/fw.s.com.10.10.1.1
Released lock on /omd/sites/monit/tmp/check_mk/snmp_scan_cache/fw.s.com.10.10.1.1
fortigate_ha: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.4.1.12356.101.13.1.1'
hr_mem: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.25.2.3.1.2'
inv_if: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.2.2.1.1'
snmp_extended_info: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.47.1.1.1.1.13'
snmp_info: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.1.1'
snmp_os: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.1.1.0'
snmp_uptime: Fetching data (SNMP walk cache cleared)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u justmyadmin -A justmypass -x AES -X justmypass -m "" -M "" -t 5.00 -r 5 -Cc -OQ -OU -On -Ot 10.10.1.1 .1.3.6.1.2.1.1.3'
Write data to cache file /omd/sites/monit/tmp/check_mk/data_source_cache/snmp/inventory/fw.s.com
Trying to acquire lock on /omd/sites/monit/tmp/check_mk/data_source_cache/snmp/inventory/fw.s.com
Got lock on /omd/sites/monit/tmp/check_mk/data_source_cache/snmp/inventory/fw.s.com
Releasing lock on /omd/sites/monit/tmp/check_mk/data_source_cache/snmp/inventory/fw.s.com
Released lock on /omd/sites/monit/tmp/check_mk/data_source_cache/snmp/inventory/fw.s.com
[cpu_tracking] Stop [7fbfc196f580 - Snapshot(process=posix.times_result(user=0.040000000000000036, system=0.11000000000000001, children_user=1.11, children_system=0.12, elapsed=5.329999998211861))]
[cpu_tracking] Start [7fbfc18777c0]
[PiggybackFetcher] Fetch with cache settings: NoCache(fw.s.com, base_path=/omd/sites/monit/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'fw.s.com'. Skip processing.
No piggyback files for '10.10.1.1'. Skip processing.
[cpu_tracking] Stop [7fbfc18777c0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
-> Add sections: ['fortigate_ha', 'hr_mem', 'inv_if', 'snmp_extended_info', 'snmp_info', 'snmp_os', 'snmp_uptime']
-> Add sections: []
Received no piggyback data
+ EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: skipped (no data)
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: ok
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: ok
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: skipped (no data)
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: ok
snmp_info: skipped (no data)
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: ok
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
Inventory tree not updated (No retention intervals found.).
Found 310 inventory entries, Found 136 status entries |
How can i enable the full output to be shown in GUI? I think the underlaying problem is that output is shown only from snmp_info module, and not from snmp_extended_info.
