The CheckMK Telegram Bot now has an integrated AI assistant. This feature is designed to be your problem-solving sidekick, whether you’re struggling with tech troubles or wrestling with those infamous Layer 8 conundrums. Currently, this feature is still experimental and there may be problems, but I would like to share it with you in advance to collect your experiences and possible suggestions.
It is important to note that Bard (Google) is used as the AI model. We use here an unofficial interface from Google which was found and extended by reverse engineering, if you want to know more about it, you can find more information here: GitHub - acheong08/Bard: Python SDK/API for reverse engineered Google Bard
I use this solution because this is FREE, I don’t want to put anyone in front of paywalls. Everyone should be able to use the Telegram Bot for free without any hidden costs. I will also offer the possibility to use the API of OPENAI in the future (if this doesn’t work with Bard anymore) but this will come with later versions. So I’m sorry if one day it won’t work anymore because Google will stop it, but I will try my best to build it in a way that it stays free for you
And one last thing, if you have any ideas or suggestions, feel free to share them with me here or on Github. I am also open for suggestions which are not related to the AI Assistant. I would like to be able to offer a well-developed alternative until a possible mobile app of CheckMK is released.
Using the AI / Assistant
Keep in mind that the AI is currently still highly experimental and I cannot guarantee its output.
The help for automatic notifications
After upgrading to version 3.0.0 or later, each Automatic Message has an additional button. The HELP button. When this button is pressed, the AI gives a summary of how the problem probably arose and what you can do to possibly solve it. Depending on the service output, these suggestions from the AI can be better or worse.
The Chat
The bot also has the default AI functions you may know from ChatGPT. You can ask him questions about CheckMK and IT problems, but you can also use him for other things.
