Cisco ASA fan sensor data incorrect
CMK version: Checkmk Raw Edition 2.1.0p9
OS version: Ubuntu 20.04
The Cisco ASA fan sensors show:
Operational status: OK
Speed: 0 RPM (warn/crit below 2000 RPM/1000 RPM)
Running the command below does give output, other than 0 RPM
HOSTNAME/pri/act# sh environment fans
Cooling Fans:
   Chassis Fans:
   Cooling Fan 1: 6656 RPM - OK
   Cooling Fan 2: 6656 RPM - OK
   Cooling Fan 3: 6912 RPM - OK
**Output of “cmk --debug -vvn hostname”:
Checkmk version 2.1.0p9
Trying to acquire lock on
/omd/sites/network/var/check_mk/license_usage/next_run
Got lock on /omd/sites/network/var/check_mk/license_usage/next_run
/omd/sites/network/var/check_mk/license_usage/history.json
Got lock on /omd/sites/network/var/check_mk/license_usage/history.json
Releasing lock on
Released lock on
Releasing lock on /omd/sites/network/var/check_mk/license_usage/next_run
Released lock on /omd/sites/network/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f5da96b80a0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(HOSTNAME,
base_path=/omd/sites/network/tmp/check_mk/data_source_cache/snmp,
max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False,
use_outdated=False, simulation=False)
Not using cache (Too old. Age is 11 sec, allowed is 0 sec)
  SNMP scan:
       Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v2c -c
Bw9x3daOFiDrkO4CoNJw -m "" -M "" -On -OQ -Oe -Ot IP_ADDRESS
.1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Cisco Adaptive Security Appliance Version 9.6(3)1"]
b'Cisco Adaptive Security Appliance Version 9.6(3)1'
       Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v2c -c
.1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.9.1.1421]
b'.1.3.6.1.4.1.9.1.1421'
       Using cached OID .1.3.6.1.2.1.1.1.0: 'Cisco Adaptive Security
   SNMP scan found                    cisco_mem_asa64 entity_sensors
snmp_uptime
/omd/sites/network/tmp/check_mk/snmp_scan_cache/HOSTNAME.IP_ADDRESS
Got lock on
Releasing lock on
Released lock on
cisco_cpu_multiitem: Fetching data (SNMP walk cache is enabled: Use any
locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c Bw9x3daOFiDrkO4CoNJw -m "" -M "" -Cc
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.109.1.1.1.1.2'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.109.1.1.1.1.8'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.47.1.1.1.1.7'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.47.1.1.1.1.5'
cisco_asa_conn: Fetching data (SNMP walk cache is enabled: Use any locally
cached information)
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.1'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.4.20.1.2'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.4.20.1.1'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.7'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.8'
cisco_asa_failover: Fetching data (SNMP walk cache is enabled: Use any
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.147.1.2.1.1.1.2'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.147.1.2.1.1.1.3'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.147.1.2.1.1.1.4'
cisco_mem_asa64: Fetching data (SNMP walk cache is enabled: Use any
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.221.1.1.1.1.3'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.221.1.1.1.1.18'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.221.1.1.1.1.20'
cisco_vpn_sessions: Fetching data (SNMP walk cache is enabled: Use any
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.26'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.27'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.28'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.29'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.30'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.31'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.35'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.36'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.37'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.38'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.39'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.3.40'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.4.1.9.9.392.1.1.1'
entity_sensors: Fetching data (SNMP walk cache is enabled: Use any locally
cached information)
Already fetched OID: .1.3.6.1.2.1.47.1.1.1.1.7
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.99.1.1.1.1'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.99.1.1.1.2'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.99.1.1.1.4'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.99.1.1.1.5'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.99.1.1.1.6'
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached
information)
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.1'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.2'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.3'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.5'
Already fetched OID: .1.3.6.1.2.1.2.2.1.8
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.6'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.7'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.8'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.9'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.13'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.14'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.10'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.11'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.12'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.13'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.19'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.20'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.21'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.18'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.2.2.1.6'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.31.1.1.1.15'
snmp_info: Fetching data (SNMP walk cache is enabled: Use any locally
cached information)
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.1.1'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.1.4'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.1.5'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.1.6'
snmp_uptime: Fetching data (SNMP walk cache is enabled: Use any locally
cached information)
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.1.3'
-OQ -OU -On -Ot IP_ADDRESS .1.3.6.1.2.1.25.1.1'
Write data to cache file
/omd/sites/network/tmp/check_mk/data_source_cache/snmp/checking/HOSTNAME
Got lock on
Releasing lock on
Released lock on
[cpu_tracking] Stop [7f5da96b80a0 -
Snapshot(process=posix.times_result(user=0.09000000000000008,
system=0.17000000000000004, children_user=0.02, children_system=0.31,
elapsed=4.200000002980232))]
[cpu_tracking] Start [7f5da96b8700]
[PiggybackFetcher] Fetch with cache settings: NoCache(HOSTNAME,
base_path=/omd/sites/network/tmp/check_mk/data_source_cache/piggyback,
max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True,
No piggyback files for 'HOSTNAME'. Skip processing.
No piggyback files for 'IP_ADDRESS'. Skip processing.
[cpu_tracking] Stop [7f5da96b8700 -
Snapshot(process=posix.times_result(user=0.0, system=0.0,
children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
  -> Add sections: ['cisco_asa_conn', 'cisco_asa_failover',
'cisco_cpu_multiitem', 'cisco_mem_asa64', 'cisco_vpn_sessions',
'entity_sensors', 'if64', 'snmp_info', 'snmp_uptime']
  -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f5da95ec580]
value store: synchronizing
/omd/sites/network/tmp/check_mk/counters/HOSTNAME
Got lock on /omd/sites/network/tmp/check_mk/counters/HOSTNAME
Releasing lock on /omd/sites/network/tmp/check_mk/counters/HOSTNAME
Released lock on /omd/sites/network/tmp/check_mk/counters/HOSTNAME
CPU utilization 1    Utilization in the last 5 minutes: 17.00%
CPU utilization 3    Utilization in the last 5 minutes: 17.00%
CPU utilization Processor 0/0 Utilization in the last 5 minutes: 16.00%
Cluster Status       Device (primary) is the Active unit
Connection 3         Name: inside, IP: IP_ADDRESS, Status: up
Connection 7         Name: folink, IP: 192.168.254.18, Status: up
Connection 8         Name: Outside, IP: 154.14.235.37, Status: up
Fan Sensor Chassis 1 Operational status: OK, Speed: 0 RPM (warn/crit below
2000 RPM/1000 RPM)(!!)
Fan Sensor Chassis 2 Operational status: OK, Speed: 0 RPM (warn/crit below
Fan Sensor Chassis 3 Operational status: OK, Speed: 0 RPM (warn/crit below
Interface 3          [Adaptive Security Appliance 'inside' interface],
(up), MAC: 18:8B:9D:72:E6:CB, Speed: 1 GBit/s, In: 1.28 MB/s (1.03%), Out:
714 kB/s (0.57%)
Interface 8          [Adaptive Security Appliance 'Outside' interface],
(up), MAC: 18:8B:9D:72:E6:CA, Speed: 1 GBit/s, In: 469 kB/s (0.38%), Out:
1.04 MB/s (0.83%)
Interface LAN/STATE Failover Interface [Adaptive Security Appliance
'folink' interface], (up), MAC: 18:8B:9D:72:E6:CD, Speed: 1 GBit/s, In:
148 B/s (<0.01%), Out: 58.9 kB/s (0.05%)
Memory MEMPOOL_DMA   Usage: 76.88% - 125 MiB of 162 MiB
Memory MEMPOOL_GLOBAL_SHARED Usage: 98.99% - 46.6 MiB of 47.1 MiB
(warn/crit at 80.00%/90.00% used)
Memory MEMPOOL_HEAPCACHE_0 Usage: 79.72% - 387 MiB of 486 MiB
Memory System memory Usage: 23.40% - 962 MiB of 4.01 GiB
SNMP Info            Cisco Adaptive Security Appliance Version 9.6(3)1,
HOSTNAME, LOCATION, EMAIL
Temperature Sensor CPU 0/0 Temperature: 0.0°C
Temperature Sensor Chassis Ambient 1 Temperature: 0.0°C
Temperature Sensor Chassis Ambient 2 Temperature: 0.0°C
Temperature Sensor Chassis Ambient 3 Temperature: 0.0°C
Uptime               Up since Feb 16 2022 06:49:42, Uptime: 202 days 8
hours
VPN Sessions AnyConnect SVC Active sessions: 52, Peak count: 87, Overall
system maximum: 250, Cumulative count: 17463
VPN Sessions Summary Active sessions: 52, Overall system maximum: 250,
Cumulative count: 17711
[cpu_tracking] Stop [7f5da95ec580 -
Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0,
children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[snmp] Success, execution time 4.2 sec | execution_time=4.210
user_time=0.100 system_time=0.170 children_user_time=0.020
children_system_time=0.310 cmk_time_snmp=3.610 cmk_time_agent=0.000
can you do a snmpwalk over this OIDs please:
The results for the first OID is:
07/09/2022 07:37:15 (20 ms) : Walk 1.3.6.1.2.1.47.1.1.1.1.7
07/09/2022 07:37:16 (81 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.1 = "Chassis" [ASN_OCTET_STR]
07/09/2022 07:37:16 (154 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.2 = "Processor 0/0" [ASN_OCTET_STR]
07/09/2022 07:37:16 (215 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.3 = "Processor 0/1" [ASN_OCTET_STR]
07/09/2022 07:37:16 (271 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.4 = "Processor 0/2" [ASN_OCTET_STR]
07/09/2022 07:37:16 (321 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.5 = "ASA5515 Slot for Removable Drive 0" [ASN_OCTET_STR]
07/09/2022 07:37:16 (437 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.6 = "Micron_M550_MTFDDAK128MAY Removable Drive in Slot 0" [ASN_OCTET_STR]
07/09/2022 07:37:16 (512 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.7 = "Chassis Cooling Fan 1" [ASN_OCTET_STR]
07/09/2022 07:37:16 (572 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.8 = "Chassis Fan Sensor 1" [ASN_OCTET_STR]
07/09/2022 07:37:16 (632 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.9 = "Chassis Cooling Fan 2" [ASN_OCTET_STR]
07/09/2022 07:37:16 (695 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.10 = "Chassis Fan Sensor 2" [ASN_OCTET_STR]
07/09/2022 07:37:16 (758 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.11 = "Chassis Cooling Fan 3" [ASN_OCTET_STR]
07/09/2022 07:37:16 (813 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.12 = "Chassis Fan Sensor 3" [ASN_OCTET_STR]
07/09/2022 07:37:16 (873 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.13 = "CPU Temperature Sensor 0/0" [ASN_OCTET_STR]
07/09/2022 07:37:16 (917 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.14 = "Chassis Ambient Temperature Sensor 1" [ASN_OCTET_STR]
07/09/2022 07:37:16 (967 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.15 = "Chassis Ambient Temperature Sensor 2" [ASN_OCTET_STR]
07/09/2022 07:37:16 (1014 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.16 = "Chassis Ambient Temperature Sensor 3" [ASN_OCTET_STR]
07/09/2022 07:37:16 (1061 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.17 = "Gi0/0" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1105 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.18 = "Gi0/1" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1149 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.19 = "Gi0/2" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1206 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.20 = "Gi0/3" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1265 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.21 = "Gi0/4" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1315 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.22 = "Gi0/5" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1380 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.23 = "In0/0" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1425 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.24 = "In0/1" [ASN_OCTET_STR]
07/09/2022 07:37:17 (1469 ms) : 1.3.6.1.2.1.47.1.1.1.1.7.25 = "Ma0/0" [ASN_OCTET_STR]
And the second one:
07/09/2022 07:37:28 (30 ms) : Walk 1.3.6.1.2.1.99.1.1.1
07/09/2022 07:37:28 (85 ms) : 1.3.6.1.2.1.99.1.1.1.1.8 = "10" [ASN_INTEGER]
07/09/2022 07:37:28 (135 ms) : 1.3.6.1.2.1.99.1.1.1.1.10 = "10" [ASN_INTEGER]
07/09/2022 07:37:28 (198 ms) : 1.3.6.1.2.1.99.1.1.1.1.12 = "10" [ASN_INTEGER]
07/09/2022 07:37:28 (261 ms) : 1.3.6.1.2.1.99.1.1.1.1.13 = "8" [ASN_INTEGER]
07/09/2022 07:37:28 (309 ms) : 1.3.6.1.2.1.99.1.1.1.1.14 = "8" [ASN_INTEGER]
07/09/2022 07:37:28 (364 ms) : 1.3.6.1.2.1.99.1.1.1.1.15 = "8" [ASN_INTEGER]
07/09/2022 07:37:28 (427 ms) : 1.3.6.1.2.1.99.1.1.1.1.16 = "8" [ASN_INTEGER]
07/09/2022 07:37:28 (481 ms) : 1.3.6.1.2.1.99.1.1.1.2.8 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (540 ms) : 1.3.6.1.2.1.99.1.1.1.2.10 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (614 ms) : 1.3.6.1.2.1.99.1.1.1.2.12 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (677 ms) : 1.3.6.1.2.1.99.1.1.1.2.13 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (726 ms) : 1.3.6.1.2.1.99.1.1.1.2.14 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (777 ms) : 1.3.6.1.2.1.99.1.1.1.2.15 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (834 ms) : 1.3.6.1.2.1.99.1.1.1.2.16 = "1" [ASN_INTEGER]
07/09/2022 07:37:29 (886 ms) : 1.3.6.1.2.1.99.1.1.1.3.8 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (945 ms) : 1.3.6.1.2.1.99.1.1.1.3.10 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (1002 ms) : 1.3.6.1.2.1.99.1.1.1.3.12 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (1056 ms) : 1.3.6.1.2.1.99.1.1.1.3.13 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (1108 ms) : 1.3.6.1.2.1.99.1.1.1.3.14 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (1164 ms) : 1.3.6.1.2.1.99.1.1.1.3.15 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (1224 ms) : 1.3.6.1.2.1.99.1.1.1.3.16 = "0" [ASN_INTEGER]
07/09/2022 07:37:29 (1278 ms) : 1.3.6.1.2.1.99.1.1.1.4.8 = "6656" [ASN_INTEGER]
07/09/2022 07:37:29 (1336 ms) : 1.3.6.1.2.1.99.1.1.1.4.10 = "6656" [ASN_INTEGER]
07/09/2022 07:37:29 (1397 ms) : 1.3.6.1.2.1.99.1.1.1.4.12 = "6912" [ASN_INTEGER]
07/09/2022 07:37:29 (1469 ms) : 1.3.6.1.2.1.99.1.1.1.4.13 = "34" [ASN_INTEGER]
07/09/2022 07:37:30 (1524 ms) : 1.3.6.1.2.1.99.1.1.1.4.14 = "30" [ASN_INTEGER]
07/09/2022 07:37:30 (1582 ms) : 1.3.6.1.2.1.99.1.1.1.4.15 = "27" [ASN_INTEGER]
07/09/2022 07:37:30 (1653 ms) : 1.3.6.1.2.1.99.1.1.1.4.16 = "30" [ASN_INTEGER]
07/09/2022 07:37:30 (1707 ms) : 1.3.6.1.2.1.99.1.1.1.5.8 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (1750 ms) : 1.3.6.1.2.1.99.1.1.1.5.10 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (1803 ms) : 1.3.6.1.2.1.99.1.1.1.5.12 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (1854 ms) : 1.3.6.1.2.1.99.1.1.1.5.13 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (1909 ms) : 1.3.6.1.2.1.99.1.1.1.5.14 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (1958 ms) : 1.3.6.1.2.1.99.1.1.1.5.15 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (2010 ms) : 1.3.6.1.2.1.99.1.1.1.5.16 = "1" [ASN_INTEGER]
07/09/2022 07:37:30 (2056 ms) : 1.3.6.1.2.1.99.1.1.1.6.8 = "rpm" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2103 ms) : 1.3.6.1.2.1.99.1.1.1.6.10 = "rpm" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2159 ms) : 1.3.6.1.2.1.99.1.1.1.6.12 = "rpm" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2218 ms) : 1.3.6.1.2.1.99.1.1.1.6.13 = "celsius" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2263 ms) : 1.3.6.1.2.1.99.1.1.1.6.14 = "celsius" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2313 ms) : 1.3.6.1.2.1.99.1.1.1.6.15 = "celsius" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2358 ms) : 1.3.6.1.2.1.99.1.1.1.6.16 = "celsius" [ASN_OCTET_STR]
07/09/2022 07:37:30 (2407 ms) : 1.3.6.1.2.1.99.1.1.1.7.8 = "1753846567" [ASN_TIMETICKS]
07/09/2022 07:37:30 (2463 ms) : 1.3.6.1.2.1.99.1.1.1.7.10 = "1753846573" [ASN_TIMETICKS]
07/09/2022 07:37:31 (2521 ms) : 1.3.6.1.2.1.99.1.1.1.7.12 = "1753846579" [ASN_TIMETICKS]
07/09/2022 07:37:31 (2567 ms) : 1.3.6.1.2.1.99.1.1.1.7.13 = "1753846584" [ASN_TIMETICKS]
07/09/2022 07:37:31 (2617 ms) : 1.3.6.1.2.1.99.1.1.1.7.14 = "1753846588" [ASN_TIMETICKS]
07/09/2022 07:37:31 (2670 ms) : 1.3.6.1.2.1.99.1.1.1.7.15 = "1753846594" [ASN_TIMETICKS]
07/09/2022 07:37:31 (2721 ms) : 1.3.6.1.2.1.99.1.1.1.7.16 = "1753846599" [ASN_TIMETICKS]
07/09/2022 07:37:31 (2814 ms) : 1.3.6.1.2.1.99.1.1.1.8.8 = "0" [ASN_UNSIGNED]
07/09/2022 07:37:31 (2881 ms) : 1.3.6.1.2.1.99.1.1.1.8.10 = "0" [ASN_UNSIGNED]
07/09/2022 07:37:31 (2937 ms) : 1.3.6.1.2.1.99.1.1.1.8.12 = "0" [ASN_UNSIGNED]
07/09/2022 07:37:31 (2986 ms) : 1.3.6.1.2.1.99.1.1.1.8.13 = "0" [ASN_UNSIGNED]
07/09/2022 07:37:31 (3042 ms) : 1.3.6.1.2.1.99.1.1.1.8.14 = "0" [ASN_UNSIGNED]
07/09/2022 07:37:31 (3091 ms) : 1.3.6.1.2.1.99.1.1.1.8.15 = "0" [ASN_UNSIGNED]
07/09/2022 07:37:31 (3143 ms) : 1.3.6.1.2.1.99.1.1.1.8.16 = "0" [ASN_UNSIGNED]
Thank you for looking into this!
this are the relevant data for the fan check:
for one fan this is:
1.3.6.1.2.1.47.1.1.1.1.7.8 = "Chassis Fan Sensor 1" --> entPhysicalName
1.3.6.1.2.1.99.1.1.1.1.8 = "10" --> entPhySensorType -> Fan
1.3.6.1.2.1.99.1.1.1.2.8 = "1" --> entPhySensorScale -> 10 ** (-24)
1.3.6.1.2.1.99.1.1.1.4.8 = "6656" --> entPhySensorValue
1.3.6.1.2.1.99.1.1.1.5.8 = "1" --> entPhySensorOperStatus -> Ok
1.3.6.1.2.1.99.1.1.1.6.8 = "rpm" --> entPhySensorUnitsDisplay
Acording to this data you have a very very slow fan :slight_smile: (entPhySensorValue * entPhySensorScale = very very slow fan, 6656 ** (-24) = 1.749365193275369e-92)
The issue is the entPhySensorScale, Cisco is reporting a wrong value (needs to be 9 not 1).
From the MIB description:
The exponent to apply to values returned by the associated
entPhySensorValue object. This object SHOULD be set by the agent during entry
creation, and the value SHOULD NOT change during operation
EntitySensorDataScale
	1:yocto
	2:zepto
	3:atto
	4:femto
	5:pico
	6:nano
	7:micro
	8:milli
	9:units
	10:kilo
	11:mega
	12:giga
	13:tera
	14:exa
	15:peta
	16:zetta
	17:yotta
So you can try a different OS version, open a case by Cisco or ask tripe29 to add a workaround for this.
Thank you for looking into this! Is this like a known bug?
I will check whether we can open a case for this.
Are you aware of something similar for the temperature sensors? It reports 0.0°C as well.
Thanks again!
You mean ofrom the site of Cisco? I don’t know.
not jet. But if You look in at the data you provided its the same Issue. The all have the wrong scaling value.
Ok great, thank you! I will see what we can do about this.
Apparently we are not able to create a case at Cisco anymore for this device.
I will check whether we have the option to upgrade the OS now.
The upgrade doesn’t seem to have any effect on the scaling value.
Is there anyway we adjust in CheckMK ourselves (by that I mean, change the check CheckMK uses for this)?
You can (as long as you have no sensors with such low values).
you need to copy ~/lib/check_mk/base/plugins/agent_based/utils/entity_sensors.py to your local site directory ~/local/lib/check_mk/base/plugins/agent_based/utils/entity_sensors.py. Here you have 2 options:
in ENTITY_SENSOR_SCALING change the value for 1 from 10 ** (-24) to 1
or you can in def parse_entity_sensors change the value for scaling_nr from 1 to 9. like
if scaling_nr == "1":
    scaling_nr = "9"
Ok great, thank you for your help on this topic!
It works perfectly! I will mark your reply as the solution for this topic.
