Hello.
I have use checkmk for the first time. i can add host (cisco asr 9k) successfully. But some temperature show above 1000 degree. But on the router the highest temp is about 70 degree.
Can any help. Am i missing something?
check-mk-raw-2.2.0p2_0.kinetic_amd64.deb
@PetraH
Hi @zorrs,
in the most cases, it could be help do a firmware update of the device. Because it looks like this device is sending the wrong values for this OIDs.
Also, your checkmk version is very old, maybe it will be helpful, if you do an update to a newer one.
Regards,
Petra
