Cisco_bgp_peer / Error: IndexError('list index out of range',)
I used the latest version cisco_bgp_peer from @thl-cmk from here: Files · 1.6.x · CheckMK / Cisco / BGP peers · GitLab with Checkmk Enterprise 1.6p19.
Configuration under “manual checks”:
I get the error under Status detail:
Error: IndexError(‘list index out of range’,)
Any hints for me?
Regards,
Oliver
Can you run a “cmk --debug -vvn hostname” on the command line to get the complete error?
CPU utilization R0/0 OK - Utilization in the last 5 minutes: 16.0%
File “/omd/sites/TKTest/bin/cmk”, line 100, in
exit_status = modes.call("–check", None, opts, args)
File “/omd/sites/TKTest/lib/python/cmk_base/modes/init.py”, line 72, in call
return mode.handler_function(*handler_args)
File “/omd/sites/TKTest/lib/python/cmk_base/modes/check_mk.py”, line 1579, in mode_check
return checking.do_check(hostname, ipaddress, options.get(“checks”))
File “/omd/sites/TKTest/lib/python/cmk_base/decorator.py”, line 58, in wrapped_check_func
status, infotexts, long_infotexts, perfdata = check_func(hostname, *args, **kwargs)
File “/omd/sites/TKTest/lib/python/cmk_base/checking.py”, line 111, in do_check
_do_all_checks_on_host(sources, host_config, ipaddress, only_check_plugin_names)
File “/omd/sites/TKTest/lib/python/cmk_base/checking.py”, line 247, in _do_all_checks_on_host
service.description)
File “/omd/sites/TKTest/lib/python/cmk_base/checking.py”, line 294, in execute_check
service_description=description)
File “/omd/sites/TKTest/lib/python/cmk_base/data_sources/host_sections.py”, line 142, in get_section_content
nodes_of_clustered_service)
File “/omd/sites/TKTest/lib/python/cmk_base/data_sources/host_sections.py”, line 206, in _get_section_content
section_content = self._update_with_parse_function(section_content, section_name)
File “/omd/sites/TKTest/lib/python/cmk_base/data_sources/host_sections.py”, line 299, in _update_with_parse_function
return parse_function(section_content)
File “/omd/sites/TKTest/local/share/check_mk/checks/cisco_bgp_peer”, line 280, in parse_cisco_bgp_peer
remoteaddr = cisco_bgp_get_peer(entry[0])
File “/omd/sites/TKTest/local/share/check_mk/checks/cisco_bgp_peer”, line 213, in cisco_bgp_get_peer
if int(OID_END[1]) == 4: # length of ip address
IndexError: list index out of range
OMD[TKTest]:~$
@oliverj looks like there is a problem with your snmp data.
can you do an snmpwalk over thes OIDs .1.3.6.1.4.1.9.9.187.1.2.5.1 and .1.3.6.1.4.1.9.9.187.1.2 please?
/cheers
OMD[TKTest]:~$
OMD[TKTest]:~$ snmpwalk -v2c -c SECRETCOMMUNITY -ObentU 185.XXX.XXX.26 .1.3.6.1.4.1.9.9.187.1.2.5.1
.1.3.6.1.4.1.9.9.187.1.2.5.1.3.1.4.80.XXX.XXX.1 = INTEGER: 6
.1.3.6.1.4.1.9.9.187.1.2.5.1.3.1.4.185.XXX.XXX.24 = INTEGER: 6
.1.3.6.1.4.1.9.9.187.1.2.5.1.3.1.4.185.XXX.XXX.25 = INTEGER: 6
.1.3.6.1.4.1.9.9.187.1.2.5.1.4.1.4.80.XXX.XXX.1 = INTEGER: 2
.1.3.6.1.4.1.9.9.187.1.2.5.1.4.1.4.185.XXX.XXX.24 = INTEGER: 2
.1.3.6.1.4.1.9.9.187.1.2.5.1.4.1.4.185.XXX.XXX.25 = INTEGER: 2
.1.3.6.1.4.1.9.9.187.1.2.5.1.5.1.4.80.XXX.XXX.1 = INTEGER: 4
.1.3.6.1.4.1.9.9.187.1.2.5.1.5.1.4.185.XXX.XXX.24 = INTEGER: 4
.1.3.6.1.4.1.9.9.187.1.2.5.1.5.1.4.185.XXX.XXX.25 = INTEGER: 4
.1.3.6.1.4.1.9.9.187.1.2.5.1.6.1.4.80.XXX.XXX.1 = Hex-STRING: 50 E4 7B 02
.1.3.6.1.4.1.9.9.187.1.2.5.1.6.1.4.185.XXX.XXX.24 = Hex-STRING: B9 85 70 1A
.1.3.6.1.4.1.9.9.187.1.2.5.1.6.1.4.185.XXX.XXX.25 = Hex-STRING: B9 85 70 1A
.1.3.6.1.4.1.9.9.187.1.2.5.1.7.1.4.80.XXX.XXX.1 = Gauge32: 179
.1.3.6.1.4.1.9.9.187.1.2.5.1.7.1.4.185.XXX.XXX.24 = Gauge32: 21272
.1.3.6.1.4.1.9.9.187.1.2.5.1.7.1.4.185.XXX.XXX.25 = Gauge32: 22821
.1.3.6.1.4.1.9.9.187.1.2.5.1.8.1.4.80.XXX.XXX.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.8.1.4.185.XXX.XXX.24 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.8.1.4.185.XXX.XXX.25 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.9.1.4.80.XXX.XXX.1 = IpAddress: 185.XXX.XXX.26
.1.3.6.1.4.1.9.9.187.1.2.5.1.9.1.4.185.XXX.XXX.24 = IpAddress: 185.XXX.XXX.26
.1.3.6.1.4.1.9.9.187.1.2.5.1.9.1.4.185.XXX.XXX.25 = IpAddress: 185.XXX.XXX.26
.1.3.6.1.4.1.9.9.187.1.2.5.1.10.1.4.80.XXX.XXX.1 = Gauge32: 55146
.1.3.6.1.4.1.9.9.187.1.2.5.1.10.1.4.185.XXX.XXX.24 = Gauge32: 179
.1.3.6.1.4.1.9.9.187.1.2.5.1.10.1.4.185.XXX.XXX.25 = Gauge32: 179
.1.3.6.1.4.1.9.9.187.1.2.5.1.11.1.4.80.XXX.XXX.1 = Gauge32: 9145
.1.3.6.1.4.1.9.9.187.1.2.5.1.11.1.4.185.XXX.XXX.24 = Gauge32: 61028
.1.3.6.1.4.1.9.9.187.1.2.5.1.11.1.4.185.XXX.XXX.25 = Gauge32: 61028
.1.3.6.1.4.1.9.9.187.1.2.5.1.12.1.4.80.XXX.XXX.1 = IpAddress: 80.XXX.XXX.1
.1.3.6.1.4.1.9.9.187.1.2.5.1.12.1.4.185.XXX.XXX.24 = IpAddress: 185.XXX.XXX.24
.1.3.6.1.4.1.9.9.187.1.2.5.1.12.1.4.185.XXX.XXX.25 = IpAddress: 185.XXX.XXX.25
.1.3.6.1.4.1.9.9.187.1.2.5.1.13.1.4.80.XXX.XXX.1 = Counter32: 4
.1.3.6.1.4.1.9.9.187.1.2.5.1.13.1.4.185.XXX.XXX.24 = Counter32: 348
.1.3.6.1.4.1.9.9.187.1.2.5.1.13.1.4.185.XXX.XXX.25 = Counter32: 310
.1.3.6.1.4.1.9.9.187.1.2.5.1.14.1.4.80.XXX.XXX.1 = Counter32: 3
.1.3.6.1.4.1.9.9.187.1.2.5.1.14.1.4.185.XXX.XXX.24 = Counter32: 6538
.1.3.6.1.4.1.9.9.187.1.2.5.1.14.1.4.185.XXX.XXX.25 = Counter32: 6534
.1.3.6.1.4.1.9.9.187.1.2.5.1.15.1.4.80.XXX.XXX.1 = Counter32: 383125
.1.3.6.1.4.1.9.9.187.1.2.5.1.15.1.4.185.XXX.XXX.24 = Counter32: 323641
.1.3.6.1.4.1.9.9.187.1.2.5.1.15.1.4.185.XXX.XXX.25 = Counter32: 323587
.1.3.6.1.4.1.9.9.187.1.2.5.1.16.1.4.80.XXX.XXX.1 = Counter32: 400299
.1.3.6.1.4.1.9.9.187.1.2.5.1.16.1.4.185.XXX.XXX.24 = Counter32: 359274
.1.3.6.1.4.1.9.9.187.1.2.5.1.16.1.4.185.XXX.XXX.25 = Counter32: 359307
.1.3.6.1.4.1.9.9.187.1.2.5.1.17.1.4.80.XXX.XXX.1 = Hex-STRING: 04 00
.1.3.6.1.4.1.9.9.187.1.2.5.1.17.1.4.185.XXX.XXX.24 = Hex-STRING: 04 00
.1.3.6.1.4.1.9.9.187.1.2.5.1.17.1.4.185.XXX.XXX.25 = Hex-STRING: 04 00
.1.3.6.1.4.1.9.9.187.1.2.5.1.18.1.4.80.XXX.XXX.1 = Counter32: 16
.1.3.6.1.4.1.9.9.187.1.2.5.1.18.1.4.185.XXX.XXX.24 = Counter32: 3
.1.3.6.1.4.1.9.9.187.1.2.5.1.18.1.4.185.XXX.XXX.25 = Counter32: 4
.1.3.6.1.4.1.9.9.187.1.2.5.1.19.1.4.80.XXX.XXX.1 = Gauge32: 11011903
.1.3.6.1.4.1.9.9.187.1.2.5.1.19.1.4.185.XXX.XXX.24 = Gauge32: 19402409
.1.3.6.1.4.1.9.9.187.1.2.5.1.19.1.4.185.XXX.XXX.25 = Gauge32: 19401502
.1.3.6.1.4.1.9.9.187.1.2.5.1.20.1.4.80.XXX.XXX.1 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.20.1.4.185.XXX.XXX.24 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.20.1.4.185.XXX.XXX.25 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.21.1.4.80.XXX.XXX.1 = INTEGER: 90
.1.3.6.1.4.1.9.9.187.1.2.5.1.21.1.4.185.XXX.XXX.24 = INTEGER: 180
.1.3.6.1.4.1.9.9.187.1.2.5.1.21.1.4.185.XXX.XXX.25 = INTEGER: 180
.1.3.6.1.4.1.9.9.187.1.2.5.1.22.1.4.80.XXX.XXX.1 = INTEGER: 30
.1.3.6.1.4.1.9.9.187.1.2.5.1.22.1.4.185.XXX.XXX.24 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.22.1.4.185.XXX.XXX.25 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.23.1.4.80.XXX.XXX.1 = INTEGER: 180
.1.3.6.1.4.1.9.9.187.1.2.5.1.23.1.4.185.XXX.XXX.24 = INTEGER: 180
.1.3.6.1.4.1.9.9.187.1.2.5.1.23.1.4.185.XXX.XXX.25 = INTEGER: 180
.1.3.6.1.4.1.9.9.187.1.2.5.1.24.1.4.80.XXX.XXX.1 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.24.1.4.185.XXX.XXX.24 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.24.1.4.185.XXX.XXX.25 = INTEGER: 60
.1.3.6.1.4.1.9.9.187.1.2.5.1.25.1.4.80.XXX.XXX.1 = INTEGER: 30
.1.3.6.1.4.1.9.9.187.1.2.5.1.25.1.4.185.XXX.XXX.24 = INTEGER: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.25.1.4.185.XXX.XXX.25 = INTEGER: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.26.1.4.80.XXX.XXX.1 = INTEGER: 30
.1.3.6.1.4.1.9.9.187.1.2.5.1.26.1.4.185.XXX.XXX.24 = INTEGER: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.26.1.4.185.XXX.XXX.25 = INTEGER: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.27.1.4.80.XXX.XXX.1 = Gauge32: 5800034
.1.3.6.1.4.1.9.9.187.1.2.5.1.27.1.4.185.XXX.XXX.24 = Gauge32: 23748
.1.3.6.1.4.1.9.9.187.1.2.5.1.27.1.4.185.XXX.XXX.25 = Gauge32: 23748
.1.3.6.1.4.1.9.9.187.1.2.5.1.28.1.4.80.XXX.XXX.1 = STRING: "hold time expired"
.1.3.6.1.4.1.9.9.187.1.2.5.1.28.1.4.185.XXX.XXX.24 = STRING: "hold time expired"
.1.3.6.1.4.1.9.9.187.1.2.5.1.28.1.4.185.XXX.XXX.25 = STRING: "hold time expired"
.1.3.6.1.4.1.9.9.187.1.2.5.1.29.1.4.80.XXX.XXX.1 = INTEGER: 5
.1.3.6.1.4.1.9.9.187.1.2.5.1.29.1.4.185.XXX.XXX.24 = INTEGER: 5
.1.3.6.1.4.1.9.9.187.1.2.5.1.29.1.4.185.XXX.XXX.25 = INTEGER: 5
OMD[TKTest]:~$
OMD[TKTest]:~$
OMD[TKTest]:~$
OMD[TKTest]:~$
.1.3.6.1.4.1.9.9.187.1.2.1.1.7.80.XXX.XXX.1 = STRING: "hold time expired"
.1.3.6.1.4.1.9.9.187.1.2.1.1.7.185.XXX.XXX.24 = STRING: "hold time expired"
.1.3.6.1.4.1.9.9.187.1.2.1.1.7.185.XXX.XXX.25 = STRING: "hold time expired"
.1.3.6.1.4.1.9.9.187.1.2.1.1.8.80.XXX.XXX.1 = INTEGER: 5
.1.3.6.1.4.1.9.9.187.1.2.1.1.8.185.XXX.XXX.24 = INTEGER: 5
.1.3.6.1.4.1.9.9.187.1.2.1.1.8.185.XXX.XXX.25 = INTEGER: 5
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.80.XXX.XXX.1.1.1 = Hex-STRING: 00 01 01
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.80.XXX.XXX.1.2.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.80.XXX.XXX.1.128.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.24.1.1 = Hex-STRING: 00 01 01
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.24.1.2 = Hex-STRING: 00 02 01
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.24.1.3 = Hex-STRING: 00 01 80
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.24.2.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.24.128.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.25.1.1 = Hex-STRING: 00 01 01
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.25.1.2 = Hex-STRING: 00 02 01
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.25.1.3 = Hex-STRING: 00 01 80
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.25.2.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.2.1.3.185.XXX.XXX.25.128.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.80.XXX.XXX.1.1.1 = STRING: "IPv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.185.XXX.XXX.24.1.1 = STRING: "IPv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.185.XXX.XXX.24.1.128 = STRING: "VPNv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.185.XXX.XXX.24.2.1 = STRING: "IPv6 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.185.XXX.XXX.25.1.1 = STRING: "IPv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.185.XXX.XXX.25.1.128 = STRING: "VPNv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.3.1.3.185.XXX.XXX.25.2.1 = STRING: "IPv6 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.80.XXX.XXX.1.1.1 = Counter32: 6
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.185.XXX.XXX.24.1.1 = Counter32: 6
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.185.XXX.XXX.24.1.128 = Counter32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.185.XXX.XXX.24.2.1 = Counter32: 7
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.185.XXX.XXX.25.1.1 = Counter32: 8
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.185.XXX.XXX.25.1.128 = Counter32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.1.185.XXX.XXX.25.2.1 = Counter32: 7
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.80.XXX.XXX.1.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.185.XXX.XXX.24.1.1 = Gauge32: 54
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.185.XXX.XXX.24.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.185.XXX.XXX.24.2.1 = Gauge32: 1
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.185.XXX.XXX.25.1.1 = Gauge32: 57
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.185.XXX.XXX.25.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.2.185.XXX.XXX.25.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.3.185.XXX.XXX.24.1.1 = Gauge32: 100
.1.3.6.1.4.1.9.9.187.1.2.4.1.3.185.XXX.XXX.24.1.128 = Gauge32: 1000
.1.3.6.1.4.1.9.9.187.1.2.4.1.3.185.XXX.XXX.25.1.1 = Gauge32: 100
.1.3.6.1.4.1.9.9.187.1.2.4.1.3.185.XXX.XXX.25.1.128 = Gauge32: 1000
.1.3.6.1.4.1.9.9.187.1.2.4.1.4.185.XXX.XXX.24.1.1 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.4.1.4.185.XXX.XXX.24.1.128 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.4.1.4.185.XXX.XXX.25.1.1 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.4.1.4.185.XXX.XXX.25.1.128 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.4.1.5.185.XXX.XXX.24.1.1 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.4.1.5.185.XXX.XXX.24.1.128 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.4.1.5.185.XXX.XXX.25.1.1 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.4.1.5.185.XXX.XXX.25.1.128 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.80.XXX.XXX.1.1.1 = Gauge32: 4
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.185.XXX.XXX.24.1.1 = Gauge32: 142
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.185.XXX.XXX.24.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.185.XXX.XXX.24.2.1 = Gauge32: 36469
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.185.XXX.XXX.25.1.1 = Gauge32: 142
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.185.XXX.XXX.25.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.6.185.XXX.XXX.25.2.1 = Gauge32: 36469
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.80.XXX.XXX.1.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.185.XXX.XXX.24.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.185.XXX.XXX.24.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.185.XXX.XXX.24.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.185.XXX.XXX.25.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.185.XXX.XXX.25.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.7.185.XXX.XXX.25.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.80.XXX.XXX.1.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.185.XXX.XXX.24.1.1 = Gauge32: 112
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.185.XXX.XXX.24.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.185.XXX.XXX.24.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.185.XXX.XXX.25.1.1 = Gauge32: 112
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.185.XXX.XXX.25.1.128 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.4.1.8.185.XXX.XXX.25.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.5.1.15.1.4.80.XXX.XXX.1 = Counter32: 383126
.1.3.6.1.4.1.9.9.187.1.2.5.1.15.1.4.185.XXX.XXX.24 = Counter32: 323642
.1.3.6.1.4.1.9.9.187.1.2.5.1.15.1.4.185.XXX.XXX.25 = Counter32: 323588
.1.3.6.1.4.1.9.9.187.1.2.5.1.16.1.4.80.XXX.XXX.1 = Counter32: 400300
.1.3.6.1.4.1.9.9.187.1.2.5.1.16.1.4.185.XXX.XXX.24 = Counter32: 359275
.1.3.6.1.4.1.9.9.187.1.2.5.1.19.1.4.80.XXX.XXX.1 = Gauge32: 11011934
.1.3.6.1.4.1.9.9.187.1.2.5.1.19.1.4.185.XXX.XXX.24 = Gauge32: 19402440
.1.3.6.1.4.1.9.9.187.1.2.5.1.19.1.4.185.XXX.XXX.25 = Gauge32: 19401533
.1.3.6.1.4.1.9.9.187.1.2.5.1.27.1.4.80.XXX.XXX.1 = Gauge32: 5800066
.1.3.6.1.4.1.9.9.187.1.2.5.1.27.1.4.185.XXX.XXX.24 = Gauge32: 23780
.1.3.6.1.4.1.9.9.187.1.2.5.1.27.1.4.185.XXX.XXX.25 = Gauge32: 23780
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.80.XXX.XXX.1.1.1 = Hex-STRING: 00 01 01 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.80.XXX.XXX.1.2.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.80.XXX.XXX.1.65.1 = Hex-STRING: 00 00 EE 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.80.XXX.XXX.1.128.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.24.1.1 = Hex-STRING: 00 01 01 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.24.1.2 = Hex-STRING: 00 02 01 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.24.1.3 = Hex-STRING: 00 01 80 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.24.2.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.24.65.1 = Hex-STRING: 00 00 EE 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.24.128.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.25.1.1 = Hex-STRING: 00 01 01 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.25.1.2 = Hex-STRING: 00 02 01 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.25.1.3 = Hex-STRING: 00 01 80 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.25.2.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.25.65.1 = Hex-STRING: 00 00 EE 64
.1.3.6.1.4.1.9.9.187.1.2.6.1.3.1.4.185.XXX.XXX.25.128.1 = ""
.1.3.6.1.4.1.9.9.187.1.2.7.1.3.1.4.80.XXX.XXX.1.1.1 = STRING: "IPv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.7.1.3.1.4.185.XXX.XXX.24.1.1 = STRING: "IPv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.7.1.3.1.4.185.XXX.XXX.24.2.1 = STRING: "IPv6 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.7.1.3.1.4.185.XXX.XXX.25.1.1 = STRING: "IPv4 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.7.1.3.1.4.185.XXX.XXX.25.2.1 = STRING: "IPv6 Unicast"
.1.3.6.1.4.1.9.9.187.1.2.8.1.1.1.4.80.XXX.XXX.1.1.1 = Counter32: 6
.1.3.6.1.4.1.9.9.187.1.2.8.1.1.1.4.185.XXX.XXX.24.1.1 = Counter32: 6
.1.3.6.1.4.1.9.9.187.1.2.8.1.1.1.4.185.XXX.XXX.24.2.1 = Counter32: 7
.1.3.6.1.4.1.9.9.187.1.2.8.1.1.1.4.185.XXX.XXX.25.1.1 = Counter32: 8
.1.3.6.1.4.1.9.9.187.1.2.8.1.1.1.4.185.XXX.XXX.25.2.1 = Counter32: 7
.1.3.6.1.4.1.9.9.187.1.2.8.1.2.1.4.80.XXX.XXX.1.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.2.1.4.185.XXX.XXX.24.1.1 = Gauge32: 54
.1.3.6.1.4.1.9.9.187.1.2.8.1.2.1.4.185.XXX.XXX.24.2.1 = Gauge32: 1
.1.3.6.1.4.1.9.9.187.1.2.8.1.2.1.4.185.XXX.XXX.25.1.1 = Gauge32: 57
.1.3.6.1.4.1.9.9.187.1.2.8.1.2.1.4.185.XXX.XXX.25.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.3.1.4.185.XXX.XXX.24.1.1 = Gauge32: 100
.1.3.6.1.4.1.9.9.187.1.2.8.1.3.1.4.185.XXX.XXX.24.1.128 = Gauge32: 1000
.1.3.6.1.4.1.9.9.187.1.2.8.1.3.1.4.185.XXX.XXX.25.1.1 = Gauge32: 100
.1.3.6.1.4.1.9.9.187.1.2.8.1.3.1.4.185.XXX.XXX.25.1.128 = Gauge32: 1000
.1.3.6.1.4.1.9.9.187.1.2.8.1.4.1.4.185.XXX.XXX.24.1.1 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.8.1.4.1.4.185.XXX.XXX.24.1.128 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.8.1.4.1.4.185.XXX.XXX.25.1.1 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.8.1.4.1.4.185.XXX.XXX.25.1.128 = Gauge32: 75
.1.3.6.1.4.1.9.9.187.1.2.8.1.5.1.4.185.XXX.XXX.24.1.1 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.8.1.5.1.4.185.XXX.XXX.24.1.128 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.8.1.5.1.4.185.XXX.XXX.25.1.1 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.8.1.5.1.4.185.XXX.XXX.25.1.128 = Gauge32: 70
.1.3.6.1.4.1.9.9.187.1.2.8.1.6.1.4.80.XXX.XXX.1.1.1 = Gauge32: 4
.1.3.6.1.4.1.9.9.187.1.2.8.1.6.1.4.185.XXX.XXX.24.1.1 = Gauge32: 142
.1.3.6.1.4.1.9.9.187.1.2.8.1.6.1.4.185.XXX.XXX.24.2.1 = Gauge32: 36469
.1.3.6.1.4.1.9.9.187.1.2.8.1.6.1.4.185.XXX.XXX.25.1.1 = Gauge32: 142
.1.3.6.1.4.1.9.9.187.1.2.8.1.6.1.4.185.XXX.XXX.25.2.1 = Gauge32: 36469
.1.3.6.1.4.1.9.9.187.1.2.8.1.7.1.4.80.XXX.XXX.1.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.7.1.4.185.XXX.XXX.24.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.7.1.4.185.XXX.XXX.24.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.7.1.4.185.XXX.XXX.25.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.7.1.4.185.XXX.XXX.25.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.8.1.4.80.XXX.XXX.1.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.8.1.4.185.XXX.XXX.24.1.1 = Gauge32: 112
.1.3.6.1.4.1.9.9.187.1.2.8.1.8.1.4.185.XXX.XXX.24.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.187.1.2.8.1.8.1.4.185.XXX.XXX.25.1.1 = Gauge32: 112
.1.3.6.1.4.1.9.9.187.1.2.8.1.8.1.4.185.XXX.XXX.25.2.1 = Gauge32: 0
OMD[TKTest]:~$
OMD[TKTest]:~$
@oliverj thanks for the walk, I have put his in my simulator. It looks like there are some additional entrys I have never seen before.
[‘1.4.80.10.10.1.1.1’, ‘IPv4 Unicast’, ‘6’, ‘0’, ‘’, ‘’, ‘’, ‘4’, ‘0’, ‘0’],
[‘1.4.185.10.10.24.1.1’, ‘IPv4 Unicast’, ‘6’, ‘54’, ‘100’, ‘75’, ‘70’, ‘142’, ‘0’, ‘112’],
[’’, ‘’, ‘’, ‘’, ‘1000’, ‘75’, ‘70’, ‘’, ‘’, ‘’],
[‘1.4.185.10.10.24.2.1’, ‘IPv6 Unicast’, ‘7’, ‘1’, ‘’, ‘’, ‘’, ‘36469’, ‘0’, ‘0’],
[‘1.4.185.10.10.25.1.1’, ‘IPv4 Unicast’, ‘8’, ‘57’, ‘100’, ‘75’, ‘70’, ‘142’, ‘0’, ‘112’],
[‘1.4.185.10.10.25.2.1’, ‘IPv6 Unicast’, ‘7’, ‘0’, ‘’, ‘’, ‘’, ‘36469’, ‘0’, ‘0’]
this comes from this stuff:
can you tell me what system/software you are running?
/cheers
(ASR-920-24SZ-M)
.1.3.6.1.2.1.1.1.0 = STRING: Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 19-Jan-17 09:45 by mcpre
Ok, strange… I have made a quick fix. Looks good for me now.
unfortunately I have no CMK 1.6 at hand right now, so I an can not compile a mkp file. You need to donload the check file direcktly an ditribute it on your system.
The changes are in lines 280 and 321.
please let me kno if it works for you.
/cheers
Thomas
Hi Thomas,
thank you for your support! It works for me!
Regards,
Oliver
