I have Cisco UCS C220 M6S servers. SNMP checkm only pulls Interface eth0 and SNMP Info. On UCS C220 M5 servers, it pulls all the data. Test connection shows everything is OK. Does anyone know the problem?
Thank You
Thank You
Please check the configuration of your servers CIMC. In the SNMP configuration there is a point to define if you get full or restricted access. You need to set this to full access.
Regards
Udo
Thank you for your reply,
On the server SNMP configuration it’s set to full, I have same servers m5 all working fine.
thank You
Hi @Eli.Ezra,
did you manage to solve the problem?
I am facing the exact same issue. Both server types (M5 and M6) have the same SNMP configuration, still CheckMK cant fetch any data like CPU, temperature, etc. from the M6 servers.
Please check with the Redfish integration as this should work with booth versions of CIMC interfaces.
https://exchange.checkmk.com/p/redfish
Hi @andreas-doehler,
i have implemented your Redfish API and it works way better/ fetches more data than SNMP on both server types.
Thank you very much for your work on the MKP and the suggestion.
