Hi. We are using the shipped Citrix Farm plugin to monitor our non-persistent VDA’s in Citrix, which pulls in the VDA information from our 2x Delivery Controllers, and then has a dynamic host rule to add the VDA’s it finds and monitor them.
We have always had an issue from day 1, where random VDA’s constantly report that the VMTools are not running - but when I check vSphere, they are very definitely running just fine, and we dont see any issues with them in Citrix Studio either.
Really stuck trying to figure out why they keep reporting back with VMTools not running. I am assuming this is actual data coming back from the plugin script, but why? What is it not seeing that makes it think the tools are off? And why does it fail completely at random in the middle of the day, when nothing has happened to the VDA?
E.g. today, all 64 of our Citrix VDA servers suddenly for no explicable reason started throwing up warnings that VMTools wasnt running - but it is. I can see in vSphere the tools are running and logging on to the VDA’s directly, the services are all running and working just fine.
Any ideas? Detail and host debug output from one of the VDA’s below - although the setup is a bit complex so happy to provide more detail if needed!
CMK version: 2.3p6
OMD[companyname]:~$ cmk --debug -vvn desktop-vda-host
value store: synchronizing
Trying to acquire lock on /omd/sites/companyname/tmp/check_mk/counters/desktop-vda-host
Got lock on /omd/sites/companyname/tmp/check_mk/counters/desktop-vda-host
Releasing lock on /omd/sites/companyname/tmp/check_mk/counters/desktop-vda-host
Released lock on /omd/sites/companyname/tmp/check_mk/counters/desktop-vda-host
Checkmk version 2.3.0p6
+ FETCHING DATA
Source: SourceInfo(hostname='desktop-vda-host', ipaddress=None, ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fe0d0eb8440]
Read from cache: NoCache(desktop-vda-host, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
Piggyback file '/omd/sites/companyname/tmp/check_mk/piggyback/desktop-vda-host/ddc01': Successfully processed from source 'ddc01'
Piggyback file '/omd/sites/companyname/tmp/check_mk/piggyback/desktop-vda-host/ddc02': Successfully processed from source 'ddc02'
Get piggybacked data
[cpu_tracking] Stop [7fe0d0eb8440 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7fe0d0b95a00]
+ PARSE FETCHER RESULTS
<<<citrix_state:cached(1745576806,90)>>> / Transition NOOPParser -> HostSectionParser
<<<citrix_serverload:cached(1745576806,90)>>> / Transition HostSectionParser -> HostSectionParser
<<<citrix_sessions:cached(1745576806,90)>>> / Transition HostSectionParser -> HostSectionParser
<<<citrix_state:cached(1745576765,90)>>> / Transition HostSectionParser -> HostSectionParser
<<<citrix_serverload:cached(1745576765,90)>>> / Transition HostSectionParser -> HostSectionParser
<<<citrix_sessions:cached(1745576765,90)>>> / Transition HostSectionParser -> HostSectionParser
HostKey(hostname='desktop-vda-host', source_type=<SourceType.HOST: 1>) -> Add sections: ['citrix_serverload', 'citrix_sessions', 'citrix_state', 'labels']
Received no piggyback data
Citrix Controller ddc01
Citrix Hosting Server esx-host
Citrix Instance State FaultState None, MaintenanceMode False, PowerState On, RegistrationState Registered, VMToolsState NotStarted(!)
Citrix Serverload Current Citrix Load: 24.54%
Citrix Sessions Total: 6, Active: 6, Inactive: 0
[cpu_tracking] Stop [7fe0d0b95a00 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[piggyback] Successfully processed from source 'ddc01', Successfully processed from source 'ddc02', execution time 0.0 sec | execution_time=0.000 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
