CMK version: 2.1p6
OS version: current Appliance
After upgrading to 2.1 I see that cluster checks are crashing after I changed the mode to best or failover. I see it for all my mrpe-checks and interestingly one Apache-Cluster check.
OMD[checkmk]:~$ cmk --debug -vvn clusterhost
Checkmk version 2.1.0p6
Trying to acquire lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
Got lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Got lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Released lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
Released lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
+ FETCHING DATA
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7f4de8bbc0a0]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(host1.fqdn, base_path=/omd/sites/checkmk/tmp/check_mk/cache, max_age=MaxAge(checking=90, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Using data from cache file /omd/sites/checkmk/tmp/check_mk/cache/host1.fqdn
Got 71391 bytes data from cache
[ProgramFetcher] Use cached data
[cpu_tracking] Stop [7f4de8bbc0a0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f4de8832580]
[PiggybackFetcher] Fetch with cache settings: NoCache(host1.fqdn, base_path=/omd/sites/checkmk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=90, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'host1.fqdn'. Skip processing.
No piggyback files for 'www.xxx.yyy.zzz'. Skip processing.
[cpu_tracking] Stop [7f4de8832580 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f4de87cd160]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(host2.fqdn, base_path=/omd/sites/checkmk/tmp/check_mk/cache, max_age=MaxAge(checking=90, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Using data from cache file /omd/sites/checkmk/tmp/check_mk/cache/host2.fqdn
Got 71295 bytes data from cache
[cpu_tracking] Stop [7f4de87cd160 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f4de87cd340]
[PiggybackFetcher] Fetch with cache settings: NoCache(host2.fqdn, base_path=/omd/sites/checkmk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=90, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'host2.fqdn'. Skip processing.
No piggyback files for '84.23.226.58'. Skip processing.
[cpu_tracking] Stop [7f4de87cd340 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<ntp:cached(1657650408,120)>>> / Transition HostSectionParser -> HostSectionParser
<<<mrpe>>> / Transition HostSectionParser -> HostSectionParser
<<<yum:cached(1657614511,129600)>>> / Transition HostSectionParser -> HostSectionParser
<<<check_mk:cached(1657647346,3600)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'lnx_if', 'local', 'md', 'mem', 'mounts', 'mrpe', 'nfsmounts', 'ntp', 'postfix_mailq', 'postfix_mailq_status', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest', 'yum']
-> Add sections: []
<<<ntp:cached(1657650415,120)>>> / Transition HostSectionParser -> HostSectionParser
<<<yum:cached(1657617359,129600)>>> / Transition HostSectionParser -> HostSectionParser
<<<check_mk:cached(1657650155,3600)>>> / Transition HostSectionParser -> HostSectionParser
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f4de87dc700]
value store: synchronizing
Trying to acquire lock on /omd/sites/checkmk/tmp/check_mk/counters/clusterhost
Got lock on /omd/sites/checkmk/tmp/check_mk/counters/clusterhost
Releasing lock on /omd/sites/checkmk/tmp/check_mk/counters/clusterhost
Released lock on /omd/sites/checkmk/tmp/check_mk/counters/clusterhost
[cpu_tracking] Stop [7f4de87dc700 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
Trying to acquire lock on /omd/sites/checkmk/var/check_mk/crashes/base/6ab8d45c-0210-11ed-a013-e63601754f21/crash.info
Got lock on /omd/sites/checkmk/var/check_mk/crashes/base/6ab8d45c-0210-11ed-a013-e63601754f21/crash.info
Releasing lock on /omd/sites/checkmk/var/check_mk/crashes/base/6ab8d45c-0210-11ed-a013-e63601754f21/crash.info
Released lock on /omd/sites/checkmk/var/check_mk/crashes/base/6ab8d45c-0210-11ed-a013-e63601754f21/crash.info
File "/omd/sites/checkmk/bin/cmk", line 98, in <module>
exit_status = modes.call("--check", None, opts, args)
File "/omd/sites/checkmk/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/checkmk/lib/python3/cmk/base/modes/check_mk.py", line 1804, in mode_check
checking.commandline_checking(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/decorator.py", line 43, in wrapped_check_func
status, output_text = _combine_texts(check_func(hostname, *args, **kwargs))
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 121, in commandline_checking
return _execute_checkmk_checks(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 174, in _execute_checkmk_checks
num_success, plugins_missing_data = check_host_services(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 322, in check_host_services
success = _execute_check(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 382, in _execute_check
submittable = get_aggregated_result(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 470, in get_aggregated_result
result = _aggregate_results(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 578, in _aggregate_results
perfdata, results = _consume_and_dispatch_result_types(subresults)
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/__init__.py", line 622, in _consume_and_dispatch_result_types
for subr in subresults:
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/_cluster_modes.py", line 145, in _cluster_check
yield from summarizer.secondary_results(
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/_cluster_modes.py", line 225, in secondary_results
yield from (
File "/omd/sites/checkmk/lib/python3/cmk/base/agent_based/checking/_cluster_modes.py", line 226, in <genexpr>
Result(
File "/omd/sites/checkmk/lib/python3/cmk/base/api/agent_based/checking_classes.py", line 367, in __new__
state, summary, details = _create_result_fields(**kwargs)
File "/omd/sites/checkmk/lib/python3/cmk/base/api/agent_based/checking_classes.py", line 405, in _create_result_fields
raise ValueError(f"'{name}' must be non-empty str or None, got {var}")
ValueError: 'notice' must be non-empty str or None, got
