**CMK version:**2.0.0p19
**OS version:**Rocky Linux 8.5
OMD[xxx]:~$ omd start
Temporary filesystem already mounted
Starting mkeventd...Already running.
Starting liveproxyd...Already running.
Starting mknotifyd...OK
Starting rrdcached...Already running.
Starting cmc...Failed (Config /omd/sites/xxx/var/check_mk/core/config missing, run "cmk -U" and try again)
Starting apache...(already running: 3853363)...OK
Starting dcd...Already running.
Starting redis...Already running.
Initializing Crontab...OK
OMD[xxx]:~$ cmk -vvU --debug
Trying to acquire lock on /omd/sites/xxx/etc/check_mk/main.mk
Got lock on /omd/sites/xxx/etc/check_mk/main.mk
Generating configuration for core (type cmc)...Trying to acquire lock on /omd/sites/xxx/var/check_mk/core/helper_config/serial.mk
Got lock on /omd/sites/xxx/var/check_mk/core/helper_config/serial.mk
Releasing lock on /omd/sites/xxx/var/check_mk/core/helper_config/serial.mk
Released lock on /omd/sites/xxx/var/check_mk/core/helper_config/serial.mk
Creating helper config...OK
Time needed [<lambda>]: 0.00 sec
Releasing lock on /omd/sites/xxx/etc/check_mk/main.mk
Released lock on /omd/sites/xxx/etc/check_mk/main.mk
Configuration Error: '24X7'
Trying to acquire lock on /omd/sites/xxx/var/check_mk/crashes/base/5f279270-a44d-11ec-bd2a-005056b5330e/crash.info
Got lock on /omd/sites/xxx/var/check_mk/crashes/base/5f279270-a44d-11ec-bd2a-005056b5330e/crash.info
Releasing lock on /omd/sites/xxx/var/check_mk/crashes/base/5f279270-a44d-11ec-bd2a-005056b5330e/crash.info
Released lock on /omd/sites/xxx/var/check_mk/crashes/base/5f279270-a44d-11ec-bd2a-005056b5330e/crash.info
File "/omd/sites/xxx/bin/cmk", line 92, in <module>
File "/omd/sites/xxx/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/xxx/lib/python3/cmk/base/modes/check_mk.py", line 1116, in mode_update
do_create_config(create_core(config.monitoring_core))
File "/omd/sites/xxx/lib/python3/cmk/base/core_config.py", line 336, in do_create_config
_create_core_config(core)
File "/omd/sites/xxx/lib/python3/cmk/base/core_config.py", line 401, in _create_core_config
core.create_config(helper_config.serial)
File "/omd/sites/xxx/lib/python3/cmk/base/cee/core_cmc.py", line 87, in create_config
_create_core_config(serial)
File "/omd/sites/xxx/lib/python3/cmk/base/cee/core_cmc.py", line 148, in _create_core_config
timeperiods_config = _measure_time(cmc_timeperiods)
File "/omd/sites/xxx/lib/python3/cmk/base/cee/core_cmc.py", line 186, in _measure_time
result = func(*args, **kwargs)
File "/omd/sites/xxx/lib/python3/cmk/base/cee/core_cmc.py", line 376, in cmc_timeperiods
serialize_timeperiod(tps_to_do[0], sequences)
File "/omd/sites/xxx/lib/python3/cmk/base/cee/core_cmc.py", line 2006, in serialize_timeperiod
serialize_timeperiod(ex, serialized) # infinite recursion not regarded here
File "/omd/sites/xxx/lib/python3/cmk/base/cee/core_cmc.py", line 2001, in serialize_timeperiod
tp = config.timeperiods[tpname]
KeyError: '24X7'
OMD[xxx]:~$ cmk --debug -vvn vmsrvchkmk01t
Checkmk version 2.0.0p19
Trying to acquire lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Got lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Got lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Released lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Released lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/xxx/var/check_mk/autochecks/vmsrvchkmk01t.mk
+ FETCHING DATA
[cpu_tracking] Start [7fcaed337f40]
Connecting via TCP to x.x.x.23:6556 (5.0s timeout)
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/xxx/tmp/check_mk/cache/vmsrvchkmk01t'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Reading data from agent
Output is not encrypted
Write data to cache file /omd/sites/xxx/tmp/check_mk/cache/vmsrvchkmk01t
Trying to acquire lock on /omd/sites/xxx/tmp/check_mk/cache/vmsrvchkmk01t
Got lock on /omd/sites/xxx/tmp/check_mk/cache/vmsrvchkmk01t
Releasing lock on /omd/sites/xxx/tmp/check_mk/cache/vmsrvchkmk01t
Released lock on /omd/sites/xxx/tmp/check_mk/cache/vmsrvchkmk01t
Closing TCP connection to x.x.x.23:6556
[cpu_tracking] Stop [7fcaed337f40 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=3.6200000001117587))]
[cpu_tracking] Start [7fcaed348220]
Piggyback file '/omd/sites/xxx/tmp/check_mk/piggyback/vmsrvchkmk01t/vmsrvvc01p.hw.nets.lan' is outdated (Piggyback file too old: 21 d). Skip processing.
No piggyback files for 'x.x.x.23'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/xxx/tmp/check_mk/data_source_cache/piggyback/vmsrvchkmk01t'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7fcaed348220 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7fcaed337e50]
+ PARSE FETCHER RESULTS
No persisted sections loaded
-> Add sections: ['check_mk', 'chrony', 'cifsmounts', 'cmk_site_statistics', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'livestatus_ssl_certs', 'livestatus_status', 'lnx_if', 'local', 'md', 'mem', 'mkeventd_status', 'mknotifyd', 'mounts', 'nfsmounts', 'omd_apache', 'omd_info', 'omd_status', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest']
-> Add sections: ['labels']
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/xxx/tmp/check_mk/counters/vmsrvchkmk01t
Got lock on /omd/sites/xxx/tmp/check_mk/counters/vmsrvchkmk01t
Releasing lock on /omd/sites/xxx/tmp/check_mk/counters/vmsrvchkmk01t
Released lock on /omd/sites/xxx/tmp/check_mk/counters/vmsrvchkmk01t
CPU load 15 min load: 0.34 at 2 cores (0.17 per core)
CPU utilization Total CPU: 7.15%
Disk IO SUMMARY PEND - Initializing counters
Filesystem / 28.6% used (13.25 of 46.33 GB), trend: 0.00 B / 24 hours
Filesystem /boot 29.56% used (299.73 of 1014.00 MB), trend: 0.00 B / 24 hours
Filesystem /boot/efi 0.96% used (5.76 of 598.81 MB), trend: 0.00 B / 24 hours
Interface 2 [ens192], (up), MAC: 00:50:56:B5:33:0E, Speed: 10 GBit/s
Kernel Performance Process Creations: 0.00/s, Context Switches: 0.00/s, Major Page Faults: 0.00/s, Page Swap in: 0.00/s, Page Swap Out: 0.00/s
Memory Total virtual memory: 32.85% - 1.87 GB of 5.71 GB
Mount options of / Mount options exactly as expected
Mount options of /boot Mount options exactly as expected
Mount options of /boot/efi Mount options exactly as expected
NTP Time Offset: 0.0137 ms, Stratum: 2, Time since last sync: 10 minutes 22 seconds
Number of threads Count: 643 threads, Usage: 2.17%
OMD xxx Event Console Current events: 0, Virtual memory: 411.48 MB, Overall event limit inactive, No hosts event limit active, No rules event limit active, Received messages: 0.00/s, Rule hits: 0.00/s, Rule tries: 0.00/s, Message drops: 0.00/s, Created events: 0.00/s, Client connects: 0.00/s, Rule hit ratio: -, Processing time per message: -, Time per client request: -
OMD xxx Notification Spooler Version: 2.0.0p19, Spooler running
OMD xxx apache 0.00 Requests/s, 0.00 Seconds serving/s, 0.00 B Sent/s
OMD xxx performance Item not found in monitoring data
OMD xxx status partially running, stopped services: cmc
OMD SCPMS Event Console Current events: 0, Virtual memory: 411.44 MB, Overall event limit inactive, No hosts event limit active, No rules event limit active, Received messages: 0.00/s, Rule hits: 0.00/s, Rule tries: 0.00/s, Message drops: 0.00/s, Created events: 0.00/s, Client connects: 0.00/s, Rule hit ratio: -, Processing time per message: -, Time per client request: 0.29 ms
OMD SCPMS Notification Spooler Version: 2.0.0p21, Spooler running
OMD SCPMS apache 0.00 Requests/s, 0.00 Seconds serving/s, 0.00 B Sent/s
OMD SCPMS performance PEND - Initialized: 'host_checks'
OMD SCPMS status running
Site xxx statistics Item not found in monitoring data
Site SCPMS statistics Total hosts: 0, Problem hosts: 0, Total services: 0, Problem services: 0
Systemd Service Summary Total: 93, Disabled: 6, Failed: 0
TCP Connections Established: 7
Uptime Up since Mar 01 2022 07:17:13, Uptime: 14 days 4 hours
+ EXECUTING INVENTORY PLUGINS
hp_proliant_mem: skipped (no data)
ipmi_firmware: skipped (no data)
inventory_checkmk: ok
inventory_checkmk: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
inventory_oracle_tablespaces: skipped (no data)
dmidecode: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
juniper_info: skipped (no data)
mem: ok
mem_used: skipped (no data)
snmp_info: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
allnet_ip_sensoric: skipped (no data)
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkpoint_inv_tunnels: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_container_node_name: skipped (no data)
docker_node_images: skipped (no data)
docker_node_info: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_job_container: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_roles: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_if: ok
lnx_if: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_uname: skipped (no data)
lnx_video: skipped (no data)
lparstat_aix: skipped (no data)
mssql_clusters: skipped (no data)
mssql_versions: skipped (no data)
netapp_api_disk: skipped (no data)
netapp_api_info: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_systemparameter: skipped (no data)
perle_chassis: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
prtconf: skipped (no data)
snmp_extended_info: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_routes: skipped (no data)
solaris_uname: skipped (no data)
statgrab_net: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_os: skipped (no data)
win_reg_uninstall: skipped (no data)
win_system: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
winperf_if: skipped (no data)
Trying to acquire lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t
Got lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t
Releasing lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t
Released lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t
Trying to acquire lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t.gz
Got lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t.gz
Releasing lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t.gz
Released lock on /omd/sites/xxx/tmp/check_mk/status_data/vmsrvchkmk01t.gz
Trying to acquire lock on /omd/sites/xxx/tmp/check_mk/status_data/.last
Got lock on /omd/sites/xxx/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/xxx/tmp/check_mk/status_data/.last
Released lock on /omd/sites/xxx/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7fcaed337e50 - Snapshot(process=posix.times_result(user=0.050000000000000044, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.11999999918043613))]
[agent] Version: 2.0.0p19, OS: linux, [piggyback] Failed sources: Piggyback file too old: 21 d, Missing monitoring data for check plugins: esx_vsphere_vm_cpu, esx_vsphere_vm_datastores, esx_vsphere_vm_guest_tools, esx_vsphere_vm_heartbeat, esx_vsphere_vm_mem_usage, esx_vsphere_vm_mounted_devices, esx_vsphere_vm_name, esx_vsphere_vm_running_on, esx_vsphere_vm_snapshots(!), execution time 3.7 sec | execution_time=3.740 user_time=0.050 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=3.620
