Cmk-agent-ctl-daemon fail to start
CMK version: Checkmk Raw Edition 2.3.0
OS version: debian 12 Linux 6.8.4-3-pve
root@pbs:/etc/systemd/system/multi-user.target.wants# systemctl status cmk-agent-ctl-daemon.service
× cmk-agent-ctl-daemon.service - Checkmk agent controller daemon
     Loaded: loaded (/lib/systemd/system/cmk-agent-ctl-daemon.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Thu 2024-05-23 14:10:13 CEST; 2s ago
   Duration: 50ms
       Docs: https://docs.checkmk.com/latest/en/agent_linux.html
    Process: 122589 ExecStart=/usr/bin/cmk-agent-ctl -vv daemon (code=exited, status=203/EXEC)
   Main PID: 122589 (code=exited, status=203/EXEC)
        CPU: 49ms
May 23 14:10:13 pbs systemd[1]: Started cmk-agent-ctl-daemon.service - Checkmk agent controller daemon.
May 23 14:10:13 pbs systemd[1]: cmk-agent-ctl-daemon.service: Main process exited, code=exited, status=203/EXEC
May 23 14:10:13 pbs systemd[1]: cmk-agent-ctl-daemon.service: Failed with result 'exit-code'.
journalctl :
░░ Subject: A start job for unit cmk-agent-ctl-daemon.service has finished successfully
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit cmk-agent-ctl-daemon.service has finished successfully.
░░ The job identifier is 12847.
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit cmk-agent-ctl-daemon.service has exited.
░░ The process' exit code is 'exited' and its exit status is 203.
░░ Subject: Unit failed
░░ The unit cmk-agent-ctl-daemon.service has entered the 'failed' state with result 'exit-code'.
Following a reboot, i can’t restart cmk agent daemon service.
The manual command works well :
root@pbs:/etc/systemd/system/multi-user.target.wants# /usr/bin/cmk-agent-ctl -vv daemon
INFO [cmk_agent_ctl] starting
INFO [cmk_agent_ctl] Loaded config from '"/var/lib/cmk-agent/cmk-agent-ctl.toml"', connection registry from '"/var/lib/cmk-agent/registered_connections.json"'
INFO [cmk_agent_ctl::modes::daemon] Could not load pre-configured connections from "/var/lib/cmk-agent/pre_configured_connections.json": No such file or directory (os error 2)
DEBUG [cmk_agent_ctl::misc] Sleeping 44s to avoid DDOSing of sites
DEBUG [cmk_agent_ctl::misc] Sleeping 41s to avoid DDOSing of sites
INFO [cmk_agent_ctl::modes::pull] Start listening for incoming pull requests
INFO [cmk_agent_ctl::modes::pull] Listening on [::]:6556 for incoming pull connections (IPv6 & IPv4 if activated)
(i tried to launch in debug via -vv in the service)
I don’t understand what happen
root@pbs:/etc/systemd/system/multi-user.target.wants# ss -tulpan | grep 6556
can you help me please ?
Hey,
in /lib/systemd/system/cmk-agent-ctl-daemon.service it says
[Unit]
Description=Checkmk agent controller daemon
After=network.target
Documentation=https://docs.checkmk.com/latest/en/agent_linux.html
[Service]
ExecStart=/usr/bin/cmk-agent-ctl daemon
Type=simple
Restart=on-failure
UMask=0077
User=cmk-agent
Have you tried running it as the cmk-agent user?
For example (as root)
sudo -u cmk-agent cmk-agent-ctl -vv daemon
thanks for your replay, here the result :
root@pbs:~# sudo -u cmk-agent cmk-agent-ctl -vv daemon
DEBUG [cmk_agent_ctl::misc] Sleeping 51s to avoid DDOSing of sites
DEBUG [cmk_agent_ctl::misc] Sleeping 31s to avoid DDOSing of sites
no problem to lunch as cmk user apparently
my /lib/systemd/system/cmk-agent-ctl-daemon.service
root@pbs:~# more /lib/systemd/system/cmk-agent-ctl-daemon.service
[Unit]
[Service]
Type=simple
#Restart=on-failure
UMask=0077
User=cmk-agent
NoNewPrivileges=yes
# added v184
CapabilityBoundingSet=
# added v211
RestrictAddressFamilies=AF_INET AF_INET6 AF_UNIX
# added v214
ProtectHome=yes
ProtectSystem=full
# added v231
RestrictRealtime=yes
# added v232
ProtectControlGroups=yes
ProtectKernelModules=yes
ProtectKernelTunables=yes
RemoveIPC=yes
# added v235
LockPersonality=yes
# added v242
RestrictSUIDSGID=yes
# added v244
ProtectKernelLogs=yes
# added v245
ProtectClock=yes
# added v239
PrivateMounts=yes
# added v242
ProtectHostname=yes
[Install]
WantedBy=multi-user.target
(END)
here is my apt history :
Start-Date: 2024-05-05  21:43:14
Commandline: apt-get upgrade -y
Upgrade: less:amd64 (590-2, 590-2.1~deb12u2), libc6:amd64 (2.36-9+deb12u6, 2.36-9+deb12u7), locales:amd64 (2.36-9+deb12u6, 2.36-9+deb12u7), libc-l10n:amd64 (2.36-9+deb12u6, 2.36-9+deb12u7), libc-b
in:amd64 (2.36-9+deb12u6, 2.36-9+deb12u7)
End-Date: 2024-05-05  21:43:47
Start-Date: 2024-05-06  11:49:22
Commandline: apt-get install -y /tmp/cmk_agent.deb
Upgrade: check-mk-agent:amd64 (2.2.0p17-1, 2.3.0-1)
End-Date: 2024-05-06  11:49:27
Start-Date: 2024-05-13  12:40:47
Upgrade: libglib2.0-data:amd64 (2.74.6-2, 2.74.6-2+deb12u2), libglib2.0-0:amd64 (2.74.6-2, 2.74.6-2+deb12u2)
End-Date: 2024-05-13  12:40:59
Start-Date: 2024-05-14  11:34:23
Commandline: apt-get full-upgrade
Install: proxmox-kernel-6.2.16-20-pve:amd64 (6.2.16-20, automatic), proxmox-kernel-6.8:amd64 (6.8.4-2, automatic), proxmox-kernel-6.8.4-2-pve-signed:amd64 (6.8.4-2, automatic), proxmox-termproxy:a
md64 (1.0.1, automatic)
Upgrade: proxmox-default-kernel:amd64 (1.0.0, 1.1.0), proxmox-kernel-6.2:amd64 (6.2.16-19, 6.2.16-20), pve-xtermjs:amd64 (4.16.0-3, 5.3.0-3)
End-Date: 2024-05-14  11:41:29
Start-Date: 2024-05-19  08:01:07
Upgrade: libproxmox-acme-plugins:amd64 (1.5.0, 1.5.1)
End-Date: 2024-05-19  08:01:14
Start-Date: 2024-05-21  15:15:30
Commandline: apt purge check-mk-agent
Purge: check-mk-agent:amd64 ()
End-Date: 2024-05-21  15:15:31
Start-Date: 2024-05-21  15:18:21
Install: check-mk-agent:amd64 (2.3.0-1)
End-Date: 2024-05-21  15:18:25
Start-Date: 2024-05-23  09:45:37
Commandline: apt upgrade
Install: proxmox-kernel-6.8.4-3-pve-signed:amd64 (6.8.4-3, automatic)
Upgrade: proxmox-kernel-6.8:amd64 (6.8.4-2, 6.8.4-3)
End-Date: 2024-05-23  09:49:49
Start-Date: 2024-05-23  12:12:54
Commandline: apt-get purge -y --auto-remove check-mk-agent
Purge: proxmox-kernel-6.2.16-19-pve:amd64 (6.2.16-19), check-mk-agent:amd64 ()
End-Date: 2024-05-23  12:14:00
Start-Date: 2024-05-23  12:14:27
End-Date: 2024-05-23  12:14:31
hmm, have you looked around in the other logfiles in /var/log or in journalctl around the time of an service restart?
Maybe something else is logging anything useful to get to the root of the problem. Other than that i am currently at a loss too.
journalctl :
journalctl -xleu  cmk-agent-ctl-daemon.service  --since 2024-05-27
May 27 09:44:57 pbs systemd[1]: Started cmk-agent-ctl-daemon.service - Checkmk agent controller daemon.
░░ The job identifier is 31285.
May 27 09:44:57 pbs systemd[1]: cmk-agent-ctl-daemon.service: Main process exited, code=exited, status=203/EXEC
May 27 09:44:57 pbs systemd[1]: cmk-agent-ctl-daemon.service: Failed with result 'exit-code'.
May 27 09:45:38 pbs systemd[1]: Started cmk-agent-ctl-daemon.service - Checkmk agent controller daemon.
░░ The job identifier is 31352.
May 27 09:45:38 pbs systemd[1]: cmk-agent-ctl-daemon.service: Main process exited, code=exited, status=203/EXEC
May 27 09:45:38 pbs systemd[1]: cmk-agent-ctl-daemon.service: Failed with result 'exit-code'.
nothing revelant in dmesg …
[    0.000000] Linux version 6.8.4-3-pve (build@proxmox) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX 6.8.4-3 (2024-05-02T11:55Z) ()
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-6.8.4-3-pve root=ZFS=/ROOT/pbs-1 ro root=ZFS=rpool/ROOT/pbs-1 boot=zfs quiet
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009bfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009c000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bdfaffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bdfb0000-0x00000000bf3affff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bf3b0000-0x00000000bf5dafff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf5db000-0x00000000bf5dcfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bf5dd000-0x00000000bf5eafff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf5eb000-0x00000000bf5eefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bf5ef000-0x00000000bf5effff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf5f0000-0x00000000bf600fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bf601000-0x00000000bf63efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf63f000-0x00000000bf6befff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bf6bf000-0x00000000bf7befff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bf7bf000-0x00000000bf7effff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bf7f0000-0x00000000bf7fffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf800000-0x00000000bfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffc00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000083fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Dell Inc. PowerEdge T110 II/0PM2CW, BIOS 2.8.0 06/24/2014
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3092.724 MHz processor
[    0.001511] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001514] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001525] last_pfn = 0x840000 max_arch_pfn = 0x400000000
[    0.001531] MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
[    0.001534] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001828] last_pfn = 0xbf800 max_arch_pfn = 0x400000000
[    0.011099] found SMP MP-table at [mem 0x000fe1b0-0x000fe1bf]
[    0.012066] RAMDISK: [mem 0x2fa6f000-0x33d2efff]
[    0.012069] ACPI: Early table checksum verification disabled
[    0.012073] ACPI: RSDP 0x00000000000FE020 000024 (v02 DELL  )
[    0.012077] ACPI: XSDT 0x00000000BF7EF170 0000AC (v01 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012084] ACPI: FACP 0x00000000BF7EB000 0000F4 (v04 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012090] ACPI: DSDT 0x00000000BF7E1000 0068FE (v01 DELL   PE_SC3   00000000 DELL 00040000)
[    0.012094] ACPI: FACS 0x00000000BF7B8000 000040
[    0.012097] ACPI: FACS 0x00000000BF7B8000 000040
[    0.012099] ACPI: SPMI 0x00000000BF7EE000 000040 (v05 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012103] ACPI: DMAR 0x00000000BF7ED000 000078 (v01 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012106] ACPI: ASF! 0x00000000BF7EC000 0000A5 (v32 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012110] ACPI: HPET 0x00000000BF7EA000 000038 (v01 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012113] ACPI: APIC 0x00000000BF7E9000 000092 (v02 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012117] ACPI: MCFG 0x00000000BF7E8000 00003C (v01 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012120] ACPI: BOOT 0x00000000BF7DE000 000028 (v01 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012123] ACPI: SSDT 0x00000000BF7DD000 0002F6 (v01 DELL   PE_SC3   00001000 DELL 00040000)
[    0.012127] ACPI: ASPT 0x00000000BF7D9000 000034 (v07 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012130] ACPI: SSDT 0x00000000BF7D8000 0009AA (v01 DELL   PE_SC3   00003000 DELL 00040000)
[    0.012134] ACPI: SSDT 0x00000000BF7D7000 000A92 (v01 DELL   PE_SC3   00003000 DELL 00040000)
[    0.012137] ACPI: SPCR 0x00000000BF7DA000 000050 (v01 DELL   PE_SC3   00000001 DELL 00040000)
[    0.012140] ACPI: HEST 0x00000000BF7D6000 0000A8 (v01 DELL   PE_SC3   00000000 DELL 00040000)
[    0.012144] ACPI: ERST 0x00000000BF7D5000 000230 (v01 DELL   PE_SC3   00000000 DELL 00040000)
[    0.012147] ACPI: BERT 0x00000000BF7D4000 000030 (v01 DELL   PE_SC3   00000000 DELL 00040000)
[    0.012150] ACPI: EINJ 0x00000000BF7D3000 000130 (v01 DELL   PE_SC3   00000000 DELL 00040000)
[    0.012153] ACPI: Reserving FACP table memory at [mem 0xbf7eb000-0xbf7eb0f3]
[    0.012155] ACPI: Reserving DSDT table memory at [mem 0xbf7e1000-0xbf7e78fd]
[    0.012156] ACPI: Reserving FACS table memory at [mem 0xbf7b8000-0xbf7b803f]
[    0.012157] ACPI: Reserving FACS table memory at [mem 0xbf7b8000-0xbf7b803f]
[    0.012158] ACPI: Reserving SPMI table memory at [mem 0xbf7ee000-0xbf7ee03f]
[    0.012159] ACPI: Reserving DMAR table memory at [mem 0xbf7ed000-0xbf7ed077]
[    0.012160] ACPI: Reserving ASF! table memory at [mem 0xbf7ec000-0xbf7ec0a4]
[    0.012160] ACPI: Reserving HPET table memory at [mem 0xbf7ea000-0xbf7ea037]
[    0.012161] ACPI: Reserving APIC table memory at [mem 0xbf7e9000-0xbf7e9091]
[    0.012162] ACPI: Reserving MCFG table memory at [mem 0xbf7e8000-0xbf7e803b]
[    0.012163] ACPI: Reserving BOOT table memory at [mem 0xbf7de000-0xbf7de027]
[    0.012164] ACPI: Reserving SSDT table memory at [mem 0xbf7dd000-0xbf7dd2f5]
[    0.012165] ACPI: Reserving ASPT table memory at [mem 0xbf7d9000-0xbf7d9033]
[    0.012166] ACPI: Reserving SSDT table memory at [mem 0xbf7d8000-0xbf7d89a9]
[    0.012167] ACPI: Reserving SSDT table memory at [mem 0xbf7d7000-0xbf7d7a91]
[    0.012168] ACPI: Reserving SPCR table memory at [mem 0xbf7da000-0xbf7da04f]
[    0.012169] ACPI: Reserving HEST table memory at [mem 0xbf7d6000-0xbf7d60a7]
[    0.012170] ACPI: Reserving ERST table memory at [mem 0xbf7d5000-0xbf7d522f]
[    0.012171] ACPI: Reserving BERT table memory at [mem 0xbf7d4000-0xbf7d402f]
[    0.012172] ACPI: Reserving EINJ table memory at [mem 0xbf7d3000-0xbf7d312f]
[    0.012237] No NUMA configuration found
[    0.012238] Faking a node at [mem 0x0000000000000000-0x000000083fffffff]
[    0.012246] NODE_DATA(0) allocated [mem 0x83ffb9000-0x83ffe3fff]
[    0.012475] Zone ranges:
[    0.012476]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.012478]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.012480]   Normal   [mem 0x0000000100000000-0x000000083fffffff]
[    0.012481]   Device   empty
[    0.012482] Movable zone start for each node
[    0.012485] Early memory node ranges
[    0.012486]   node   0: [mem 0x0000000000001000-0x000000000009bfff]
[    0.012487]   node   0: [mem 0x0000000000100000-0x00000000bdfaffff]
[    0.012489]   node   0: [mem 0x00000000bf3b0000-0x00000000bf5dafff]
[    0.012490]   node   0: [mem 0x00000000bf5dd000-0x00000000bf5eafff]
[    0.012491]   node   0: [mem 0x00000000bf5ef000-0x00000000bf5effff]
[    0.012492]   node   0: [mem 0x00000000bf601000-0x00000000bf63efff]
[    0.012492]   node   0: [mem 0x00000000bf7f0000-0x00000000bf7fffff]
[    0.012493]   node   0: [mem 0x0000000100000000-0x000000083fffffff]
[    0.012498] Initmem setup node 0 [mem 0x0000000000001000-0x000000083fffffff]
[    0.012503] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.012530] On node 0, zone DMA: 100 pages in unavailable ranges
[    0.017502] On node 0, zone DMA32: 5120 pages in unavailable ranges
[    0.017507] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.017507] On node 0, zone DMA32: 4 pages in unavailable ranges
[    0.017509] On node 0, zone DMA32: 17 pages in unavailable ranges
[    0.017515] On node 0, zone DMA32: 433 pages in unavailable ranges
[    0.065747] On node 0, zone Normal: 2048 pages in unavailable ranges
[    0.065868] ACPI: PM-Timer IO Port: 0x408
[    0.065877] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.065888] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[    0.065891] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.065893] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.065897] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.065899] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.065904] ACPI: SPCR: SPCR table version 1
[    0.065905] ACPI: SPCR: console: uart,io,0x2f8,115200
[    0.065907] TSC deadline timer available
[    0.065908] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
[    0.065930] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.065932] PM: hibernation: Registered nosave memory: [mem 0x0009c000-0x0009ffff]
[    0.065933] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.065934] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.065935] PM: hibernation: Registered nosave memory: [mem 0xbdfb0000-0xbf3affff]
[    0.065937] PM: hibernation: Registered nosave memory: [mem 0xbf5db000-0xbf5dcfff]
[    0.065939] PM: hibernation: Registered nosave memory: [mem 0xbf5eb000-0xbf5eefff]
[    0.065941] PM: hibernation: Registered nosave memory: [mem 0xbf5f0000-0xbf600fff]
[    0.065943] PM: hibernation: Registered nosave memory: [mem 0xbf63f000-0xbf6befff]
[    0.065944] PM: hibernation: Registered nosave memory: [mem 0xbf6bf000-0xbf7befff]
[    0.065945] PM: hibernation: Registered nosave memory: [mem 0xbf7bf000-0xbf7effff]
[    0.065946] PM: hibernation: Registered nosave memory: [mem 0xbf800000-0xbfffffff]
[    0.065947] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xdfffffff]
[    0.065948] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.065949] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfeafffff]
[    0.065950] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb03fff]
[    0.065951] PM: hibernation: Registered nosave memory: [mem 0xfeb04000-0xfebfffff]
[    0.065951] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.065952] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[    0.065953] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.065954] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
[    0.065955] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.065956] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.065957] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.065957] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffbfffff]
[    0.065958] PM: hibernation: Registered nosave memory: [mem 0xffc00000-0xffffffff]
[    0.065960] [mem 0xc0000000-0xdfffffff] available for PCI devices
[    0.065961] Booting paravirtualized kernel on bare hardware
[    0.065964] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.065972] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.066574] percpu: Embedded 86 pages/cpu s229376 r8192 d114688 u524288
[    0.066581] pcpu-alloc: s229376 r8192 d114688 u524288 alloc=1*2097152
[    0.066584] pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
[    0.066611] Kernel command line: BOOT_IMAGE=/vmlinuz-6.8.4-3-pve root=ZFS=/ROOT/pbs-1 ro root=ZFS=rpool/ROOT/pbs-1 boot=zfs quiet
[    0.066685] Unknown kernel command line parameters "BOOT_IMAGE=/vmlinuz-6.8.4-3-pve boot=zfs", will be passed to user space.
[    0.066705] random: crng init done
[    0.070094] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.071816] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.071945] Fallback order for Node 0: 0
[    0.071949] Built 1 zonelists, mobility grouping on.  Total pages: 8249775
[    0.071951] Policy zone: Normal
[    0.071959] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.071968] software IO TLB: area num 8.
[    0.169426] Memory: 32762168K/33523532K available (20480K kernel code, 3638K rwdata, 13412K rodata, 4804K init, 5708K bss, 761104K reserved, 0K cma-reserved)
[    0.170422] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.170438] Kernel/User page tables isolation: enabled
[    0.170474] ftrace: allocating 55248 entries in 216 pages
[    0.179461] ftrace: allocated 216 pages with 4 groups
[    0.180262] Dynamic Preempt: voluntary
[    0.180333] rcu: Preemptible hierarchical RCU implementation.
[    0.180334] rcu:     RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[    0.180336]  Trampoline variant of Tasks RCU enabled.
[    0.180336]  Rude variant of Tasks RCU enabled.
[    0.180337]  Tracing variant of Tasks RCU enabled.
[    0.180338] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.180339] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.183398] NR_IRQS: 524544, nr_irqs: 488, preallocated irqs: 16
[    0.183607] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.188323] Console: colour VGA+ 80x25
[    0.188326] printk: legacy console [tty0] enabled
[    0.188375] ACPI: Core revision 20230628
[    0.188486] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.188503] APIC: Switch to symmetric I/O mode setup
[    0.188506] DMAR: Host address width 36
[    0.188507] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[    0.188514] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c9008020660262 ecap f010da
[    0.188517] DMAR: RMRR base: 0x00000000000000 end: 0x00000000000fff
[    0.188521] DMAR-IR: IOAPIC id 0 under DRHD base  0xfed90000 IOMMU 0
[    0.188523] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[    0.188524] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.188818] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.188821] x2apic enabled
[    0.188884] APIC: Switched APIC routing to: cluster x2apic
[    0.189339] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.193503] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2c946df8306, max_idle_ns: 440795231736 ns
[    0.193510] Calibrating delay loop (skipped), value calculated using timer frequency.. 6185.44 BogoMIPS (lpj=3092724)
[    0.193554] process: using mwait in idle threads
[    0.193557] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.193558] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.193562] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.193564] Spectre V2 : Mitigation: Retpolines
[    0.193565] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.193565] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.193566] Speculative Store Bypass: Vulnerable
[    0.193568] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[    0.193569] MMIO Stale Data: Unknown: No mitigations
[    0.193570] SRBDS: Vulnerable: No microcode
[    0.193575] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.193576] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.193577] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.193578] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.193580] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.216313] Freeing SMP alternatives memory: 48K
[    0.216319] pid_max: default: 32768 minimum: 301
[    0.216382] LSM: initializing lsm=lockdown,capability,yama,apparmor,integrity
[    0.216406] Yama: becoming mindful.
[    0.216438] AppArmor: AppArmor initialized
[    0.216510] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.216541] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.217574] smpboot: CPU0: Intel(R) Xeon(R) CPU E3-1220 V2 @ 3.10GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[    0.217755] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.217774] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.217792] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.217808] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.217826] ... version:                3
[    0.217827] ... bit width:              48
[    0.217827] ... generic registers:      8
[    0.217828] ... value mask:             0000ffffffffffff
[    0.217829] ... max period:             00007fffffffffff
[    0.217830] ... fixed-purpose events:   3
[    0.217831] ... event mask:             00000007000000ff
[    0.217970] signal: max sigframe size: 1776
[    0.217986] Estimated ratio of average max frequency by base frequency (times 1024): 1090
[    0.218020] rcu: Hierarchical SRCU implementation.
[    0.218022] rcu:     Max phase no-delay instances is 400.
[    0.218582] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.218668] smp: Bringing up secondary CPUs ...
[    0.218794] smpboot: x86: Booting SMP configuration:
[    0.218795] .... node  #0, CPUs:      #1 #2 #3
[    0.221550] smp: Brought up 1 node, 4 CPUs
[    0.221550] smpboot: Max logical packages: 2
[    0.221550] smpboot: Total of 4 processors activated (24741.79 BogoMIPS)
[    0.223524] devtmpfs: initialized
[    0.223561] x86/mm: Memory block size: 128MB
[    0.225535] ACPI: PM: Registering ACPI NVS region [mem 0xbf6bf000-0xbf7befff] (1048576 bytes)
[    0.225598] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.225609] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.225707] pinctrl core: initialized pinctrl subsystem
[    0.226509] PM: RTC time: 08:24:00, date: 2024-05-23
[    0.226961] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.227279] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.227498] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.227717] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.227727] audit: initializing netlink subsys (disabled)
[    0.227740] audit: type=2000 audit(1716452640.039:1): state=initialized audit_enabled=0 res=1
[    0.227740] thermal_sys: Registered thermal governor 'fair_share'
[    0.227740] thermal_sys: Registered thermal governor 'bang_bang'
[    0.227740] thermal_sys: Registered thermal governor 'step_wise'
[    0.227740] thermal_sys: Registered thermal governor 'user_space'
[    0.227740] thermal_sys: Registered thermal governor 'power_allocator'
[    0.227740] EISA bus registered
[    0.227740] cpuidle: using governor ladder
[    0.227740] cpuidle: using governor menu
[    0.227740] Simple Boot Flag at 0x44 set to 0x80
[    0.227740] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.227740] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.227740] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.227740] PCI: ECAM [mem 0xe0000000-0xefffffff] reserved as E820 entry
[    0.227740] PCI: Using configuration type 1 for base access
[    0.227761] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.227764] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.227765] mtrr: probably your BIOS does not setup all CPUs.
[    0.227765] mtrr: corrected configuration.
[    0.227840] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.227847] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.227847] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.228638] ACPI: Added _OSI(Module Device)
[    0.228640] ACPI: Added _OSI(Processor Device)
[    0.228641] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.228642] ACPI: Added _OSI(Processor Aggregator Device)
[    0.233026] ACPI: 4 ACPI AML tables successfully acquired and loaded
[    0.258998] ACPI: Dynamic OEM Table Load:
[    0.259008] ACPI: SSDT 0xFFFF93900171A000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20080729)
[    0.259629] ACPI: Dynamic OEM Table Load:
[    0.259635] ACPI: SSDT 0xFFFF939000E57400 000303 (v01 PmRef  ApIst    00003000 INTL 20080729)
[    0.260097] ACPI: Dynamic OEM Table Load:
[    0.260103] ACPI: SSDT 0xFFFF939001664C00 000119 (v01 PmRef  ApCst    00003000 INTL 20080729)
[    0.260940] ACPI: _OSC evaluated successfully for all CPUs
[    0.261061] ACPI: Interpreter enabled
[    0.261079] ACPI: PM: (supports S0 S4 S5)
[    0.261081] ACPI: Using IOAPIC for interrupt routing
[    0.261570] HEST: Table parsing has been initialized.
[    0.261727] GHES: APEI firmware first mode is enabled by APEI bit and WHEA _OSC.
[    0.261731] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.261732] PCI: Using E820 reservations for host bridge windows
[    0.261903] ACPI: Enabled 9 GPEs in block 00 to 3F
[    0.268892] ACPI: \_TZ_.FN00: New power resource
[    0.268971] ACPI: \_TZ_.FN01: New power resource
[    0.269045] ACPI: \_TZ_.FN02: New power resource
[    0.269121] ACPI: \_TZ_.FN03: New power resource
[    0.269195] ACPI: \_TZ_.FN04: New power resource
[    0.269825] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.269832] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.270393] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.270395] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.271007] PCI host bridge to bus 0000:00
[    0.271009] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.271012] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.271013] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.271015] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfeafffff window]
[    0.271017] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.271032] pci 0000:00:00.0: [8086:0158] type 00 class 0x060000 conventional PCI endpoint
[    0.271131] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320 conventional PCI endpoint
[    0.272646] pci 0000:00:1a.0: BAR 0 [mem 0xc1306000-0xc13063ff]
[    0.274217] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.274324] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400 PCIe Root Port
[    0.274375] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.274499] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.274535] pci 0000:00:1c.0: Enabling MPC IRBNCE
[    0.274538] pci 0000:00:1c.0: Intel PCH root port ACS workaround enabled
[    0.274642] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400 PCIe Root Port
[    0.274672] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.274679] pci 0000:00:1c.4:   bridge window [mem 0xc1200000-0xc12fffff]
[    0.274747] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.274770] pci 0000:00:1c.4: Enabling MPC IRBNCE
[    0.274773] pci 0000:00:1c.4: Intel PCH root port ACS workaround enabled
[    0.274857] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400 PCIe Root Port
[    0.274887] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.274892] pci 0000:00:1c.5:   bridge window [io  0x2000-0x2fff]
[    0.274896] pci 0000:00:1c.5:   bridge window [mem 0xc1100000-0xc11fffff]
[    0.274963] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.274985] pci 0000:00:1c.5: Enabling MPC IRBNCE
[    0.274988] pci 0000:00:1c.5: Intel PCH root port ACS workaround enabled
[    0.275074] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320 conventional PCI endpoint
[    0.275508] pci 0000:00:1d.0: BAR 0 [mem 0xc1305000-0xc13053ff]
[    0.277078] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.277165] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401 conventional PCI bridge
[    0.277190] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[    0.277196] pci 0000:00:1e.0:   bridge window [mem 0xc0800000-0xc10fffff]
[    0.277206] pci 0000:00:1e.0:   bridge window [mem 0xc0000000-0xc07fffff 64bit pref]
[    0.277300] pci 0000:00:1f.0: [8086:1c52] type 00 class 0x060100 conventional PCI endpoint
[    0.277489] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601 conventional PCI endpoint
[    0.277502] pci 0000:00:1f.2: BAR 0 [io  0x3048-0x304f]
[    0.277511] pci 0000:00:1f.2: BAR 1 [io  0x3054-0x3057]
[    0.277519] pci 0000:00:1f.2: BAR 2 [io  0x3040-0x3047]
[    0.277527] pci 0000:00:1f.2: BAR 3 [io  0x3050-0x3053]
[    0.277533] pci 0000:00:1f.2: BAR 4 [io  0x3020-0x303f]
[    0.277541] pci 0000:00:1f.2: BAR 5 [mem 0xc1304000-0xc13047ff]
[    0.277581] pci 0000:00:1f.2: PME# supported from D3hot
[    0.277651] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500 conventional PCI endpoint
[    0.277668] pci 0000:00:1f.3: BAR 0 [mem 0xc1302000-0xc13020ff 64bit]
[    0.277688] pci 0000:00:1f.3: BAR 4 [io  0x3000-0x301f]
[    0.277829] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.277921] pci 0000:02:00.0: [14e4:165a] type 00 class 0x020000 PCIe Endpoint
[    0.277955] pci 0000:02:00.0: BAR 0 [mem 0xc1200000-0xc120ffff 64bit]
[    0.278030] pci 0000:02:00.0: enabling Extended Tags
[    0.278155] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.278366] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.278448] pci 0000:03:00.0: [1b21:0612] type 00 class 0x010601 PCIe Legacy Endpoint
[    0.278472] pci 0000:03:00.0: BAR 0 [io  0x2028-0x202f]
[    0.278485] pci 0000:03:00.0: BAR 1 [io  0x2034-0x2037]
[    0.278498] pci 0000:03:00.0: BAR 2 [io  0x2020-0x2027]
[    0.278512] pci 0000:03:00.0: BAR 3 [io  0x2030-0x2033]
[    0.278525] pci 0000:03:00.0: BAR 4 [io  0x2000-0x201f]
[    0.278538] pci 0000:03:00.0: BAR 5 [mem 0xc1100000-0xc11001ff]
[    0.278551] pci 0000:03:00.0: ROM [mem 0xffff0000-0xffffffff pref]
[    0.278734] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.278760] pci_bus 0000:04: extended config space not accessible
[    0.278784] pci 0000:04:03.0: [102b:0532] type 00 class 0x030000 conventional PCI endpoint
[    0.278800] pci 0000:04:03.0: BAR 0 [mem 0xc0000000-0xc07fffff pref]
[    0.278810] pci 0000:04:03.0: BAR 1 [mem 0xc1000000-0xc1003fff]
[    0.278819] pci 0000:04:03.0: BAR 2 [mem 0xc0800000-0xc0ffffff]
[    0.278850] pci 0000:04:03.0: ROM [mem 0xffff0000-0xffffffff pref]
[    0.278863] pci 0000:04:03.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.278948] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[    0.278958] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.278960] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.278961] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.278963] pci 0000:00:1e.0:   bridge window [mem 0xc0000000-0xfeafffff window] (subtractive decode)
[    0.279789] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
[    0.279851] ACPI: PCI: Interrupt link LNKB configured for IRQ 11
[    0.279909] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.279910] ACPI: PCI: Interrupt link LNKC disabled
[    0.279967] ACPI: PCI: Interrupt link LNKD configured for IRQ 6
[    0.280025] ACPI: PCI: Interrupt link LNKE configured for IRQ 14
[    0.280083] ACPI: PCI: Interrupt link LNKF configured for IRQ 6
[    0.280141] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.280143] ACPI: PCI: Interrupt link LNKG disabled
[    0.280200] ACPI: PCI: Interrupt link LNKH configured for IRQ 15
[    0.280534] iommu: Default domain type: Translated
[    0.280534] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.280686] SCSI subsystem initialized
[    0.280695] libata version 3.00 loaded.
[    0.280695] ACPI: bus type USB registered
[    0.280695] usbcore: registered new interface driver usbfs
[    0.280695] usbcore: registered new interface driver hub
[    0.280695] usbcore: registered new device driver usb
[    0.280695] pps_core: LinuxPPS API ver. 1 registered
[    0.280695] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.280695] PTP clock support registered
[    0.280695] EDAC MC: Ver: 3.0.0
[    0.280715] NetLabel: Initializing
[    0.280717] NetLabel:  domain hash size = 128
[    0.280718] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.280736] NetLabel:  unlabeled traffic allowed by default
[    0.280752] mctp: management component transport protocol core
[    0.280752] NET: Registered PF_MCTP protocol family
[    0.280752] PCI: Using ACPI for IRQ routing
[    0.287427] PCI: pci_cache_line_size set to 64 bytes
[    0.287466] e820: reserve RAM buffer [mem 0x0009c000-0x0009ffff]
[    0.287468] e820: reserve RAM buffer [mem 0xbdfb0000-0xbfffffff]
[    0.287470] e820: reserve RAM buffer [mem 0xbf5db000-0xbfffffff]
[    0.287472] e820: reserve RAM buffer [mem 0xbf5eb000-0xbfffffff]
[    0.287473] e820: reserve RAM buffer [mem 0xbf5f0000-0xbfffffff]
[    0.287475] e820: reserve RAM buffer [mem 0xbf63f000-0xbfffffff]
[    0.287476] e820: reserve RAM buffer [mem 0xbf800000-0xbfffffff]
[    0.287491] pci 0000:04:03.0: vgaarb: setting as boot VGA device
[    0.287491] pci 0000:04:03.0: vgaarb: bridge control possible
[    0.287491] pci 0000:04:03.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.287508] vgaarb: loaded
[    0.287547] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.287555] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.289531] clocksource: Switched to clocksource tsc-early
[    0.290089] VFS: Disk quotas dquot_6.6.0
[    0.290102] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.290220] AppArmor: AppArmor Filesystem Enabled
[    0.290235] pnp: PnP ACPI init
[    0.290349] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.290353] system 00:00: [io  0x1000-0x100f] has been reserved
[    0.290355] system 00:00: [io  0x1010-0x1013] has been reserved
[    0.290356] system 00:00: [io  0xffff] has been reserved
[    0.290358] system 00:00: [io  0x0400-0x0453] has been reserved
[    0.290359] system 00:00: [io  0x0458-0x047f] has been reserved
[    0.290361] system 00:00: [io  0x0500-0x057f] has been reserved
[    0.290362] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.290430] system 00:02: [io  0x0454-0x0457] has been reserved
[    0.290874] system 00:05: [mem 0xfed90000-0xfed91fff] could not be reserved
[    0.291051] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.291054] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.291056] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.291058] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.291059] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.291061] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.291062] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.291064] system 00:06: [mem 0xff000000-0xffffffff] could not be reserved
[    0.291066] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.291067] system 00:06: [mem 0xc1400000-0xc1400fff] has been reserved
[    0.291237] pnp: PnP ACPI: found 7 devices
[    0.297061] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.297126] NET: Registered PF_INET protocol family
[    0.297256] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.313788] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.313828] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.313930] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.314214] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.314454] TCP: Hash tables configured (established 262144 bind 65536)
[    0.314576] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[    0.314667] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.314754] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.314850] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.314860] NET: Registered PF_XDP protocol family
[    0.314865] pci 0000:03:00.0: ROM [mem 0xffff0000-0xffffffff pref]: can't claim; no compatible bridge window
[    0.314876] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.314895] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.314900] pci 0000:00:1c.4:   bridge window [mem 0xc1200000-0xc12fffff]
[    0.314911] pci 0000:03:00.0: ROM [mem 0xc1110000-0xc111ffff pref]: assigned
[    0.314913] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.314916] pci 0000:00:1c.5:   bridge window [io  0x2000-0x2fff]
[    0.314921] pci 0000:00:1c.5:   bridge window [mem 0xc1100000-0xc11fffff]
[    0.314930] pci 0000:00:1e.0: PCI bridge to [bus 04]
[    0.314935] pci 0000:00:1e.0:   bridge window [mem 0xc0800000-0xc10fffff]
[    0.314939] pci 0000:00:1e.0:   bridge window [mem 0xc0000000-0xc07fffff 64bit pref]
[    0.314945] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.314947] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.314949] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.314950] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfeafffff window]
[    0.314952] pci_bus 0000:02: resource 1 [mem 0xc1200000-0xc12fffff]
[    0.314954] pci_bus 0000:03: resource 0 [io  0x2000-0x2fff]
[    0.314955] pci_bus 0000:03: resource 1 [mem 0xc1100000-0xc11fffff]
[    0.314956] pci_bus 0000:04: resource 1 [mem 0xc0800000-0xc10fffff]
[    0.314958] pci_bus 0000:04: resource 2 [mem 0xc0000000-0xc07fffff 64bit pref]
[    0.314959] pci_bus 0000:04: resource 4 [io  0x0000-0x0cf7 window]
[    0.314961] pci_bus 0000:04: resource 5 [io  0x0d00-0xffff window]
[    0.314962] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.314964] pci_bus 0000:04: resource 7 [mem 0xc0000000-0xfeafffff window]
[    0.326601] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x780 took 11295 usecs
[    0.338594] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x780 took 11689 usecs
[    0.338622] PCI: CLS 64 bytes, default 64
[    0.338636] DMAR: No ATSR found
[    0.338637] DMAR: No SATC found
[    0.338638] DMAR: dmar0: Using Queued invalidation
[    0.338677] Trying to unpack rootfs image as initramfs...
[    0.338691] pci 0000:00:00.0: Adding to iommu group 0
[    0.338701] pci 0000:00:1a.0: Adding to iommu group 1
[    0.338710] pci 0000:00:1c.0: Adding to iommu group 2
[    0.338719] pci 0000:00:1c.4: Adding to iommu group 3
[    0.338727] pci 0000:00:1c.5: Adding to iommu group 4
[    0.338734] pci 0000:00:1d.0: Adding to iommu group 5
[    0.338742] pci 0000:00:1e.0: Adding to iommu group 6
[    0.338758] pci 0000:00:1f.0: Adding to iommu group 7
[    0.338766] pci 0000:00:1f.2: Adding to iommu group 7
[    0.338773] pci 0000:00:1f.3: Adding to iommu group 7
[    0.338781] pci 0000:02:00.0: Adding to iommu group 8
[    0.338789] pci 0000:03:00.0: Adding to iommu group 9
[    0.338794] pci 0000:04:03.0: Adding to iommu group 6
[    0.339540] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    0.339542] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.339543] software IO TLB: mapped [mem 0x00000000b9fb0000-0x00000000bdfb0000] (64MB)
[    0.340137] Initialise system trusted keyrings
[    0.340147] Key type blacklist registered
[    0.340181] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[    0.340193] zbud: loaded
[    0.340417] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.340497] fuse: init (API version 7.39)
[    0.340617] integrity: Platform Keyring initialized
[    0.340621] integrity: Machine keyring initialized
[    0.352902] Key type asymmetric registered
[    0.352904] Asymmetric key parser 'x509' registered
[    0.352918] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.352956] io scheduler mq-deadline registered
[    0.355923] pcieport 0000:00:1c.0: PME: Signaling with IRQ 25
[    0.356117] pcieport 0000:00:1c.4: PME: Signaling with IRQ 26
[    0.356286] pcieport 0000:00:1c.5: PME: Signaling with IRQ 27
[    0.356358] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.356725] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[    0.356896] ACPI: button: Power Button [PWRF]
[    0.357701] thermal LNXTHERM:00: registered as thermal_zone0
[    0.357704] ACPI: thermal: Thermal Zone [TZ01] (30 C)
[    0.357768] ERST: Error Record Serialization Table (ERST) support is initialized.
[    0.357794] pstore: Using crash dump compression: deflate
[    0.357796] pstore: Registered erst as persistent store backend
[    0.357939] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.378697] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.399870] 00:04: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    0.402370] Linux agpgart interface v0.103
[    0.403867] loop: module loaded
[    0.404086] ACPI: bus type drm_connector registered
[    0.404319] tun: Universal TUN/TAP device driver, 1.6
[    0.404353] PPP generic driver version 2.4.2
[    0.404409] i8042: PNP: No PS/2 controller found.
[    0.404452] mousedev: PS/2 mouse device common for all mice
[    0.404521] rtc_cmos 00:01: RTC can wake from S4
[    0.404751] rtc_cmos 00:01: registered as rtc0
[    0.404783] rtc_cmos 00:01: setting system clock to 2024-05-23T08:24:00 UTC (1716452640)
[    0.404812] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.404822] i2c_dev: i2c /dev entries driver
[    0.404841] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    0.404851] device-mapper: uevent: version 1.0.3
[    0.404890] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    0.404908] platform eisa.0: Probing EISA bus 0
[    0.404910] platform eisa.0: EISA: Cannot allocate resource for mainboard
[    0.404912] platform eisa.0: Cannot allocate resource for EISA slot 1
[    0.404913] platform eisa.0: Cannot allocate resource for EISA slot 2
[    0.404915] platform eisa.0: Cannot allocate resource for EISA slot 3
[    0.404916] platform eisa.0: Cannot allocate resource for EISA slot 4
[    0.404917] platform eisa.0: Cannot allocate resource for EISA slot 5
[    0.404918] platform eisa.0: Cannot allocate resource for EISA slot 6
[    0.404919] platform eisa.0: Cannot allocate resource for EISA slot 7
[    0.404921] platform eisa.0: Cannot allocate resource for EISA slot 8
[    0.404922] platform eisa.0: EISA: Detected 0 cards
[    0.404928] intel_pstate: Intel P-state driver initializing
[    0.405199] ledtrig-cpu: registered to indicate activity on CPUs
[    0.405250] drop_monitor: Initializing network drop monitor service
[    0.405338] NET: Registered PF_INET6 protocol family
[    1.129770] Freeing initrd memory: 68352K
[    1.136899] Segment Routing with IPv6
[    1.136917] In-situ OAM (IOAM) with IPv6
[    1.136947] NET: Registered PF_PACKET protocol family
[    1.136970] Bridge firewalling registered
[    1.137067] Key type dns_resolver registered
[    1.137394] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    1.137425] microcode: Current revision: 0x0000001b
[    1.137498] IPI shorthand broadcast: enabled
[    1.138955] sched_clock: Marking stable (1133639772, 4868261)->(1153935754, -15427721)
[    1.139156] registered taskstats version 1
[    1.139340] Loading compiled-in X.509 certificates
[    1.139954] Loaded X.509 cert 'Build time autogenerated kernel key: 262680cf1cda5f3a17783fd7d6c5f2d870f4880b'
[    1.143184] Key type .fscrypt registered
[    1.143185] Key type fscrypt-provisioning registered
[    1.158950] Key type encrypted registered
[    1.158955] AppArmor: AppArmor sha256 policy hashing enabled
[    1.158964] ima: No TPM chip found, activating TPM-bypass!
[    1.158968] Loading compiled-in module X.509 certificates
[    1.159520] Loaded X.509 cert 'Build time autogenerated kernel key: 262680cf1cda5f3a17783fd7d6c5f2d870f4880b'
[    1.159531] ima: Allocated hash algorithm: sha256
[    1.159554] ima: No architecture policies found
[    1.159566] evm: Initialising EVM extended attributes:
[    1.159567] evm: security.selinux
[    1.159567] evm: security.SMACK64
[    1.159568] evm: security.SMACK64EXEC
[    1.159569] evm: security.SMACK64TRANSMUTE
[    1.159569] evm: security.SMACK64MMAP
[    1.159570] evm: security.apparmor
[    1.159571] evm: security.ima
[    1.159571] evm: security.capability
[    1.159572] evm: HMAC attrs: 0x1
[    1.159913] PM:   Magic number: 8:942:422
[    1.163519] RAS: Correctable Errors collector initialized.
[    1.163588] clk: Disabling unused clocks
[    1.164634] Freeing unused decrypted memory: 2028K
[    1.165079] Freeing unused kernel image (initmem) memory: 4804K
[    1.165113] Write protecting the kernel read-only data: 34816k
[    1.165371] Freeing unused kernel image (rodata/data gap) memory: 924K
[    1.206246] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.206248] x86/mm: Checking user space page tables
[    1.244237] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.244241] Run /init as init process
[    1.244243]   with arguments:
[    1.244244]     /init
[    1.244245]   with environment:
[    1.244246]     HOME=/
[    1.244246]     TERM=linux
[    1.244247]     BOOT_IMAGE=/vmlinuz-6.8.4-3-pve
[    1.244248]     boot=zfs
[    1.371886] tsc: Refined TSC clocksource calibration: 3092.972 MHz
[    1.371904] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c955856658, max_idle_ns: 440795256416 ns
[    1.371932] clocksource: Switched to clocksource tsc
[    1.414492] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20230628/utaddress-204)
[    1.414501] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    1.414505] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[    1.414508] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    1.414509] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[    1.414512] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    1.414513] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[    1.414516] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    1.414516] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    1.419238] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    1.419245] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.419257] ehci-pci 0000:00:1a.0: debug port 2
[    1.423388] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.423430] ehci-pci 0000:00:1a.0: irq 20, io mem 0xc1306000
[    1.424927] i2c i2c-0: 4/4 memory slots populated (from DMI)
[    1.425268] i2c i2c-0: Successfully instantiated SPD at 0x50
[    1.425578] i2c i2c-0: Successfully instantiated SPD at 0x51
[    1.425895] i2c i2c-0: Successfully instantiated SPD at 0x52
[    1.426216] i2c i2c-0: Successfully instantiated SPD at 0x53
[    1.426958] tg3 0000:02:00.0 eth0: Tigon3 [partno(BCM95722) rev a200] (PCI Express) MAC address f8:db:88:fe:03:e8
[    1.426962] tg3 0000:02:00.0 eth0: attached PHY is 5722/5756 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[    1.426964] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[    1.426966] tg3 0000:02:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[    1.429880] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.430329] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    1.430332] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.430334] usb usb1: Product: EHCI Host Controller
[    1.430336] usb usb1: Manufacturer: Linux 6.8.4-3-pve ehci_hcd
[    1.430337] usb usb1: SerialNumber: 0000:00:1a.0
[    1.430459] hub 1-0:1.0: USB hub found
[    1.430466] hub 1-0:1.0: 2 ports detected
[    1.430662] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    1.430668] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.430680] ehci-pci 0000:00:1d.0: debug port 2
[    1.434637] ehci-pci 0000:00:1d.0: irq 23, io mem 0xc1305000
[    1.440880] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    1.440948] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    1.440952] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.440953] usb usb2: Product: EHCI Host Controller
[    1.440955] usb usb2: Manufacturer: Linux 6.8.4-3-pve ehci_hcd
[    1.440956] usb usb2: SerialNumber: 0000:00:1d.0
[    1.441095] hub 2-0:1.0: USB hub found
[    1.441103] hub 2-0:1.0: 2 ports detected
[    1.442568] ahci 0000:00:1f.2: version 3.0
[    1.442812] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[    1.449964] tg3 0000:02:00.0 eno1: renamed from eth0
[    1.452912] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[    1.452918] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs apst
[    1.472437] scsi host0: ahci
[    1.472638] scsi host1: ahci
[    1.472738] scsi host2: ahci
[    1.472848] scsi host3: ahci
[    1.472954] scsi host4: ahci
[    1.473058] scsi host5: ahci
[    1.473110] ata1: SATA max UDMA/133 abar m2048@0xc1304000 port 0xc1304100 irq 28 lpm-pol 0
[    1.473114] ata2: SATA max UDMA/133 abar m2048@0xc1304000 port 0xc1304180 irq 28 lpm-pol 0
[    1.473117] ata3: SATA max UDMA/133 abar m2048@0xc1304000 port 0xc1304200 irq 28 lpm-pol 0
[    1.473119] ata4: SATA max UDMA/133 abar m2048@0xc1304000 port 0xc1304280 irq 28 lpm-pol 0
[    1.473122] ata5: SATA max UDMA/133 abar m2048@0xc1304000 port 0xc1304300 irq 28 lpm-pol 0
[    1.473124] ata6: SATA max UDMA/133 abar m2048@0xc1304000 port 0xc1304380 irq 28 lpm-pol 0
[    1.473276] ahci 0000:03:00.0: SSS flag set, parallel bus scan disabled
[    1.473316] ahci 0000:03:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    1.473319] ahci 0000:03:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[    1.473549] scsi host6: ahci
[    1.473635] scsi host7: ahci
[    1.473670] ata7: SATA max UDMA/133 abar m512@0xc1100000 port 0xc1100100 irq 29 lpm-pol 0
[    1.473674] ata8: SATA max UDMA/133 abar m512@0xc1100000 port 0xc1100180 irq 29 lpm-pol 0
[    1.669912] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.677900] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    1.777587] ata7: SATA link down (SStatus 0 SControl 300)
[    1.777597] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.778107] ata1.00: ATA-9: WDC WD20EZRZ-00Z5HB0, 80.00A80, max UDMA/133
[    1.778425] ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    1.779018] ata1.00: configured for UDMA/133
[    1.779187] scsi 0:0:0:0: Direct-Access     ATA      WDC WD20EZRZ-00Z 0A80 PQ: 0 ANSI: 5
[    1.779482] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.779505] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    1.779517] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.779526] sd 0:0:0:0: [sda] Write Protect is off
[    1.779536] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.779547] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.779572] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    1.798678] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.798682] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.799123] hub 1-1:1.0: USB hub found
[    1.799282] hub 1-1:1.0: 6 ports detected
[    1.807290] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.807294] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.807732] hub 2-1:1.0: USB hub found
[    1.807892] hub 2-1:1.0: 6 ports detected
[    2.089602] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.090256] ata2.00: ATA-9: WDC WD20EURX-14T0FY0, 80.00A80, max UDMA/133
[    2.090677] ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    2.091556] ata2.00: configured for UDMA/133
[    2.091668] scsi 1:0:0:0: Direct-Access     ATA      WDC WD20EURX-14T 0A80 PQ: 0 ANSI: 5
[    2.091875] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    2.091958] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.091961] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    2.091968] sd 1:0:0:0: [sdb] Write Protect is off
[    2.091970] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.091989] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.092003] sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[    2.177641]  sdb: sdb1 sdb9
[    2.177853] sd 1:0:0:0: [sdb] Attached SCSI disk
[    2.372594]  sda: sda1 sda9
[    2.372793] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.401594] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.402199] ata3.00: ATA-9: WDC WD20EURX-63T0FY0, 80.00A80, max UDMA/133
[    2.402579] ata3.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    2.403347] ata3.00: configured for UDMA/133
[    2.403454] scsi 2:0:0:0: Direct-Access     ATA      WDC WD20EURX-63T 0A80 PQ: 0 ANSI: 5
[    2.403729] sd 2:0:0:0: Attached scsi generic sg2 type 0
[    2.403766] sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.403770] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[    2.403780] sd 2:0:0:0: [sdc] Write Protect is off
[    2.403783] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    2.403794] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.403825] sd 2:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[    2.492446]  sdc: sdc1 sdc9
[    2.492659] sd 2:0:0:0: [sdc] Attached SCSI disk
[    2.713614] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.714249] ata4.00: ATA-9: WDC WD20EZRX-22D8PB0, 80.00A80, max UDMA/133
[    2.714647] ata4.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    2.715483] ata4.00: configured for UDMA/133
[    2.715586] scsi 3:0:0:0: Direct-Access     ATA      WDC WD20EZRX-22D 0A80 PQ: 0 ANSI: 5
[    2.715806] sd 3:0:0:0: Attached scsi generic sg3 type 0
[    2.715886] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    2.715889] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[    2.715898] sd 3:0:0:0: [sdd] Write Protect is off
[    2.715899] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    2.715918] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.715933] sd 3:0:0:0: [sdd] Preferred minimum I/O size 4096 bytes
[    2.803060]  sdd: sdd1 sdd9
[    2.803286] sd 3:0:0:0: [sdd] Attached SCSI disk
[    3.025614] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    3.026841] ata5.00: ATA-7: Hitachi HTS541040G9SA00, MB2OC60R, max UDMA/100
[    3.027161] ata5.00: 78140160 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    3.028984] ata5.00: configured for UDMA/100
[    3.029089] scsi 4:0:0:0: Direct-Access     ATA      Hitachi HTS54104 C60R PQ: 0 ANSI: 5
[    3.029380] sd 4:0:0:0: Attached scsi generic sg4 type 0
[    3.029399] sd 4:0:0:0: [sde] 78140160 512-byte logical blocks: (40.0 GB/37.3 GiB)
[    3.029417] sd 4:0:0:0: [sde] Write Protect is off
[    3.029419] sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
[    3.029439] sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.029480] sd 4:0:0:0: [sde] Preferred minimum I/O size 512 bytes
[    3.337618] ata6: SATA link down (SStatus 0 SControl 300)
[    3.404751]  sde: sde1 sde2 sde3
[    3.405056] sd 4:0:0:0: [sde] Attached SCSI disk
[    3.795936] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.796544] ata8.00: ATA-9: WDC WD30EZRZ-22Z5HB0, 80.00A80, max UDMA/133
[    3.796935] ata8.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    3.797765] ata8.00: configured for UDMA/133
[    3.797893] scsi 7:0:0:0: Direct-Access     ATA      WDC WD30EZRZ-22Z 0A80 PQ: 0 ANSI: 5
[    3.798171] sd 7:0:0:0: Attached scsi generic sg5 type 0
[    3.798191] sd 7:0:0:0: [sdf] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[    3.798203] sd 7:0:0:0: [sdf] 4096-byte physical blocks
[    3.798210] sd 7:0:0:0: [sdf] Write Protect is off
[    3.798212] sd 7:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[    3.798231] sd 7:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.798264] sd 7:0:0:0: [sdf] Preferred minimum I/O size 4096 bytes
[    4.418773]  sdf: sdf1 sdf9
[    4.419012] sd 7:0:0:0: [sdf] Attached SCSI disk
[    4.906871] raid6: sse2x4   gen() 16694 MB/s
[    4.923871] raid6: sse2x2   gen() 17362 MB/s
[    4.940871] raid6: sse2x1   gen() 14717 MB/s
[    4.940872] raid6: using algorithm sse2x2 gen() 17362 MB/s
[    4.957871] raid6: .... xor() 9300 MB/s, rmw enabled
[    4.957872] raid6: using ssse3x2 recovery algorithm
[    4.958812] xor: automatically using best checksumming function   avx
[    5.055298] Btrfs loaded, zoned=yes, fsverity=yes
[    5.256213] spl: loading out-of-tree module taints kernel.
[    5.286738] zfs: module license 'CDDL' taints kernel.
[    5.286743] Disabling lock debugging due to kernel taint
[    5.286764] zfs: module license taints kernel.
[    6.797803] ZFS: Loaded module v2.2.3-pve2, ZFS pool version 5000, ZFS filesystem version 5
[   13.362888] systemd[1]: Inserted module 'autofs4'
[   13.737710] systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   13.737732] systemd[1]: Detected architecture x86-64.
[   13.791239] systemd[1]: Hostname set to <pbs>.
[   19.398430] systemd[1]: Configuration file /lib/systemd/system/agent_4445.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[   19.460929] systemd[1]: Queued start job for default target graphical.target.
[   19.469745] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[   19.470087] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   19.470345] systemd[1]: Created slice system-postfix.slice - Slice /system/postfix.
[   19.470555] systemd[1]: Created slice user.slice - User and Session Slice.
[   19.470618] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[   19.470668] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   19.470846] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   19.470887] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   19.470909] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   19.470951] systemd[1]: Reached target slices.target - Slice Units.
[   19.470969] systemd[1]: Reached target swap.target - Swaps.
[   19.470981] systemd[1]: Reached target time-set.target - System Time Set.
[   19.471017] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   19.471145] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
[   19.471281] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
[   19.474165] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[   19.474257] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   19.474543] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[   19.474668] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   19.474787] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   19.474990] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   19.475086] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   19.475798] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   19.476505] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   19.477244] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   19.477951] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   19.478040] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[   19.499147] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   19.499949] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   19.500633] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   19.501437] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   19.502232] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   19.503013] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   19.503849] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   19.504629] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   19.505399] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   19.506903] systemd[1]: Starting systemd-journald.service - Journal Service...
[   19.635088] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   19.635941] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   19.636685] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   19.638065] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   19.638184] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   19.638269] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   19.638351] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   19.638587] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   19.638954] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   19.639088] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   19.639352] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   19.639474] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   19.639719] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   19.639837] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   19.640090] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   19.640210] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   19.640442] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   19.640556] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   19.640793] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   19.640916] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   19.641849] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   19.642530] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   19.642632] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   19.643445] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   19.643993] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   19.693787] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   19.693975] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   19.694016] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   19.704057] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
[   19.704873] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[   19.799321] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   19.812496] systemd[1]: Started systemd-journald.service - Journal Service.
[   19.875279] systemd-journald[438]: Received client request to flush runtime journal.
[   24.990042] IPMI message handler: version 39.2
[   25.020855] ipmi device interface
[   25.156168] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[   25.156173] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[   25.156174] RAPL PMU: hw unit of domain package 2^-16 Joules
[   25.194688] ipmi_si: IPMI System Interface driver
[   25.194708] ipmi_si dmi-ipmi-si.0: ipmi_platform: probing via SMBIOS
[   25.194711] ipmi_platform: ipmi_si: SMBIOS: io 0xca8 regsize 1 spacing 4 irq 0
[   25.194713] ipmi_si: Adding SMBIOS-specified kcs state machine
[   25.194767] ipmi_si IPI0001:00: ipmi_platform: probing via ACPI
[   25.194954] ipmi_si IPI0001:00: ipmi_platform: [io  0x0ca8] regsize 1 spacing 4 irq 0
[   25.195113] ipmi_si dmi-ipmi-si.0: Removing SMBIOS-specified kcs state machine in favor of ACPI
[   25.195115] ipmi_si: Adding ACPI-specified kcs state machine
[   25.195176] ipmi_si: Trying ACPI-specified kcs state machine at i/o address 0xca8, slave address 0x20, irq 0
[   25.288555] ipmi_si IPI0001:00: IPMI message handler: Found new BMC (man_id: 0x0002a2, prod_id: 0x0100, dev_id: 0x20)
[   25.340822] ipmi_si IPI0001:00: IPMI kcs interface initialized
[   25.408422] input: PC Speaker as /devices/platform/pcspkr/input/input1
[   25.563103] ipmi_ssif: IPMI SSIF Interface driver
[   25.581880] EDAC MC0: Giving out device to module ie31200_edac controller IE31200: DEV 0000:00:00.0 (POLLED)
[   25.655739] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[   25.714635] cryptd: max_cpu_qlen set to 1000
[   25.839519] mgag200 0000:04:03.0: vgaarb: deactivate vga console
[   25.840902] Console: switching to colour dummy device 80x25
[   25.843894] [drm] Initialized mgag200 1.0.0 20110418 for 0000:04:03.0 on minor 0
[   25.845439] fbcon: mgag200drmfb (fb0) is primary device
[   25.963737] at24 0-0050: supply vcc not found, using dummy regulator
[   25.965337] at24 0-0050: 256 byte spd EEPROM, read-only
[   25.965362] at24 0-0051: supply vcc not found, using dummy regulator
[   25.966937] at24 0-0051: 256 byte spd EEPROM, read-only
[   25.966960] at24 0-0052: supply vcc not found, using dummy regulator
[   25.968529] at24 0-0052: 256 byte spd EEPROM, read-only
[   25.968550] at24 0-0053: supply vcc not found, using dummy regulator
[   25.970101] at24 0-0053: 256 byte spd EEPROM, read-only
[   26.108913] AVX version of gcm_enc/dec engaged.
[   26.109148] AES CTR mode by8 optimization enabled
[   26.209309] Console: switching to colour frame buffer device 128x48
[   26.255743] mgag200 0000:04:03.0: [drm] fb0: mgag200drmfb frame buffer device
[   27.577569] intel_rapl_common: Found RAPL domain package
[   27.577574] intel_rapl_common: Found RAPL domain core
[   27.577580] intel_rapl_common: package-0:package:long_term locked by BIOS
[   27.577582] intel_rapl_common: package-0:package:short_term locked by BIOS
[   37.602789]  zd0: p1 p2 p3 p4
[   37.707613]  zd32: p1 p2 p3 p4
[   42.616313] RPC: Registered named UNIX socket transport module.
[   42.616318] RPC: Registered udp transport module.
[   42.616319] RPC: Registered tcp transport module.
[   42.616319] RPC: Registered tcp-with-tls transport module.
[   42.616320] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   56.222499] tg3 0000:02:00.0 eno1: Link is up at 1000 Mbps, full duplex
[   56.222507] tg3 0000:02:00.0 eno1: Flow control is off for TX and off for RX
[35870.880962] perf: interrupt took too long (2501 > 2500), lowering kernel.perf_event_max_sample_rate to 79000
[41556.808303] perf: interrupt took too long (3130 > 3126), lowering kernel.perf_event_max_sample_rate to 63000
[52837.312999] perf: interrupt took too long (3958 > 3912), lowering kernel.perf_event_max_sample_rate to 50000
[205299.941435]  zd0: p1 p2 p3 p4
[206381.695981]  zd32: p1 p2 p3 p4
[209833.865288]  zd0: p1 p2 p3 p4
in var log :
with debian 12, there isn’t any useful files for my problem :
root@pbs:/var/log# ll
total 167
drwxr-x---  2 root    adm                  2 May 24  2023 samba
-rw-r--r--  1 root    root                 0 Jun 27  2023 faillog
drwxr-xr-x  3 root    root                 3 Nov 23  2023 runit
lrwxrwxrwx  1 root    root                39 Nov 23  2023 README -> ../../usr/share/doc/systemd/README.logs
drwx------  2 root    root                 2 Nov 23  2023 private
drwxr-sr-x  3 root    systemd-journal      3 Nov 23  2023 journal
drwxr-x---  2 _chrony _chrony              2 Nov 23  2023 chrony
drwxr-xr-x  4 root    root                 4 Nov 23  2023 proxmox-backup
-rw-r--r--  1 root    root              1357 Nov 23  2023 fontconfig.log
-rw-r--r--  1 root    root              2013 Nov 23  2023 alternatives.log.4.gz
-rw-r--r--  1 root    root             29834 Nov 23  2023 dpkg.log.6.gz
-rw-r--r--  1 root    root              4701 Dec 31 00:21 dpkg.log.5.gz
-rw-r--r--  1 root    root               363 Jan 28 03:12 dpkg.log.4.gz
-rw-r--r--  1 root    root               134 Feb 11 01:26 alternatives.log.3.gz
-rw-r--r--  1 root    root              2325 Feb 18 02:04 dpkg.log.3.gz
-rw-r--r--  1 root    root              1286 Mar 24 03:40 dpkg.log.2.gz
-rw-rw----  1 root    utmp                 0 Apr  1 00:00 btmp.1
-rw-r--r--  1 root    root               135 Apr 14 21:02 alternatives.log.2.gz
-rw-r--r--  1 root    root             30633 Apr 28 01:22 dpkg.log.1
-rw-rw----  1 root    utmp                 0 May  1 00:00 btmp
-rw-r--r--  1 root    root               186 May  5 21:43 alternatives.log.1
-rw-r--r--  1 root    root                 0 May  6 00:00 alternatives.log
drwxr-xr-x  2 root    root                 3 May 10 22:37 js7
drwxr-xr-x 45 root    root                45 May 23 10:24 ifupdown2
drwxr-xr-x  2 root    root                17 May 23 12:14 apt
-rw-r--r--  1 root    root             15562 May 23 12:14 dpkg.log
drwxr-xr-x  2 root    adm                 20 May 27 00:00 nginx
-rw-rw-r--  1 root    utmp            162816 May 27 09:43 wtmp
-rw-rw-r--  1 root    utmp               292 May 27 09:43 lastlog
ah yeah, i still have them. I guess because i also use rsyslogd.
I meant looking throught journalctl without specifying the unit so restart the cmk-agent-ctl-daemon and immediatly after it fails run journalctl -f -n 100 for example to get last 100 entries for all units.
here the result after a few minutes of following :
May 27 13:24:17 pbs systemd[1]: Started cmk-agent-ctl-daemon.service - Checkmk agent controller daemon.
May 27 13:24:17 pbs systemd[1]: cmk-agent-ctl-daemon.service: Main process exited, code=exited, status=203/EXEC
May 27 13:24:17 pbs systemd[1]: cmk-agent-ctl-daemon.service: Failed with result 'exit-code'.
May 27 13:24:47 pbs smartd[1045]: Device: /dev/sda [SAT], SMART Usage Attribute: 7 Seek_Error_Rate changed from 200 to 100
May 27 13:24:48 pbs smartd[1045]: Device: /dev/sdd [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 116 to 115
May 27 13:26:01 pbs proxmox-backup-proxy[1655]: write rrd data back to disk
May 27 13:26:01 pbs proxmox-backup-proxy[1655]: starting rrd data sync
May 27 13:26:02 pbs proxmox-backup-proxy[1655]: rrd journal successfully committed (57 files in 0.199 seconds)
May 27 13:54:47 pbs smartd[1045]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 115 to 114
May 27 13:56:02 pbs proxmox-backup-proxy[1655]: write rrd data back to disk
May 27 13:56:02 pbs proxmox-backup-proxy[1655]: starting rrd data sync
May 27 13:56:02 pbs proxmox-backup-proxy[1655]: rrd journal successfully committed (57 files in 0.142 seconds)
May 27 13:59:56 pbs dhclient[1300]: DHCPREQUEST for 10.0.0.2 on eno1 to 10.0.0.254 port 67
May 27 13:59:56 pbs dhclient[1300]: DHCPACK of 10.0.0.2 from 10.0.0.254
May 27 13:59:56 pbs dhclient[1300]: bound to 10.0.0.2 -- renewal in 2893 seconds.
May 27 14:17:01 pbs CRON[874441]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
May 27 14:17:01 pbs CRON[874442]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
May 27 14:17:01 pbs CRON[874441]: pam_unix(cron:session): session closed for user root
May 27 14:24:47 pbs smartd[1045]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 117 to 116
May 27 14:24:47 pbs smartd[1045]: Device: /dev/sdc [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 115 to 114
May 27 14:26:02 pbs proxmox-backup-proxy[1655]: write rrd data back to disk
May 27 14:26:02 pbs proxmox-backup-proxy[1655]: starting rrd data sync
May 27 14:26:02 pbs proxmox-backup-proxy[1655]: rrd journal successfully committed (57 files in 0.161 seconds)
Well if anything pops up it would be either right before or after it. Sorry i am out of ideas right now what could cause this. Hope someone else has any idea.
lines before are :
May 27 13:00:08 pbs proxmox-backup-proxy[1655]: syncing filesystem
May 27 13:00:08 pbs proxmox-backup-proxy[1655]: successfully finished backup
May 27 13:00:08 pbs proxmox-backup-proxy[1655]: backup finished successfully
May 27 13:00:08 pbs proxmox-backup-proxy[1655]: TASK OK
May 27 13:02:52 pbs dhclient[1300]: DHCPREQUEST for 10.0.0.2 on eno1 to 10.0.0.254 port 67
May 27 13:02:52 pbs dhclient[1300]: DHCPACK of 10.0.0.2 from 10.0.0.254
May 27 13:02:53 pbs dhclient[1300]: bound to 10.0.0.2 -- renewal in 3424 seconds.
May 27 13:17:01 pbs CRON[841526]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
May 27 13:17:01 pbs CRON[841527]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
May 27 13:17:01 pbs CRON[841526]: pam_unix(cron:session): session closed for user root
anyway thanks you
no other help ? :frowning: i can’t start my service anymore
