TL;DR - Cannot get cmk-agent-ctl register
to connect to a site running in a Docker container and using a different port ( -p 8010:8000
Edit: Smashed it! The command that works for my instance is
cmk-agent-ctl register --hostname oak --server oak:8010 --site cmk --user cmkadmin
The hint in the docs was at https://docs.checkmk.com/latest/en/managing_docker.html " 2.3. Setting your own site ID"
… the ID of the site created in the container will be
cmk
That’s the site name to use when registering, not the container name.
============ original query ============
Thank you for help resolving this.
CMK version:
check-mk-raw:2.1.0p19
OS version:
Debian Bullseye X86_64,
root@oak:~# uname -a
Linux oak 5.10.0-19-amd64 #1 SMP Debian 5.10.149-2 (2022-10-21) x86_64 GNU/Linux
root@oak:~# docker version
Client: Docker Engine - Community
Version: 20.10.22
API version: 1.41
Go version: go1.18.9
Git commit: 3a2c30b
Built: Thu Dec 15 22:28:22 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.22
API version: 1.41 (minimum version 1.12)
Git commit: 42c8b31
Built: Thu Dec 15 22:26:14 2022
Experimental: false
containerd:
Version: 1.6.13
GitCommit: 78f51771157abb6c9ed224c22013cdf09962315d
runc:
Version: 1.1.4
GitCommit: v1.1.4-0-g5fd4c4d
docker-init:
Version: 0.19.0
GitCommit: de40ad0
root@oak:~#
Docker command to start - note that port 8000 is already in use so I have mapped that to 8010. The site is running and I can connect/login using http://oak
docker container run \
-dit -p 80:5000 -p 8010:8000 \
--tmpfs /opt/omd/sites/cmk/tmp:uid=1000,gid=1000 \
-v checkmkmon:/omd/sites --name checkmkmon \
-v /etc/localtime:/etc/localtime:ro \
--restart always checkmk/check-mk-raw:2.1.0p19
root@oak:~# cmk-agent-ctl register --hostname oak --server oak:8010 --site checkmk --user cmkadmin
Attempting to register at oak:8010/checkmk. Server certificate details:
PEM-encoded certificate:
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
Issued by:
Site 'cmk' local CA
Issued to:
cmk
Validity:
From Mon, 16 Jan 2023 21:15:32 +0000
To Sat, 19 May 3021 21:15:32 +0000
> y
Please enter password for 'cmkadmin'
ERROR [cmk_agent_ctl] Error pairing with oak:8010/checkmk
Caused by:
Request failed with code 404 Not Found: Not Found
root@oak:~#
Port seems to be active:
root@oak:~# telnet oak 8010
Trying 192.168.1.80...
Connected to oak.localdomain.
Escape character is '^]'.
telnet> close
Connection closed.
root@oak:~# ss -tulpn | grep 8010
tcp LISTEN 0 4096 0.0.0.0:8010 0.0.0.0:* users:(("docker-proxy",pid=4097273,fd=4))
tcp LISTEN 0 4096 0.0.0.0:8000 0.0.0.0:* users:(("docker-proxy",pid=1880101,fd=4))
tcp LISTEN 0 4096 [::]:8010 [::]:* users:(("docker-proxy",pid=4097280,fd=4))
root@oak:~#
root@oak:~# docker ps --last 1
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
06f2c63e7d85 checkmk/check-mk-raw:2.1.0p19 "/docker-entrypoint.…" About an hour ago Up About an hour (healthy) 6557/tcp, 0.0.0.0:80->5000/tcp, :::80->5000/tcp, 0.0.0.0:8010->8000/tcp, :::8010->8000/tcp checkmkmon
root@oak:~#
