khozy
November 13, 2020, 8:00am
1
Hello, lately, I notice jibberish characters output in CMK agent output. Is all good with my config ??
99yÛÑ#µíüÃ:ý;·Exæã@
K)ZâøöìÑwµ§ÇÛ&« 5IÝ2®pEqGEaÙ4¶I)L´+ëVS+¤^÷Êxò»
óXríÈÙ¢$9äΦV=7ªºï´TÙ§EMôÆ/çØÚüWþp~îßlêç;ÜDØ[:¢á®xnØe4bøÖä5yf x³ ²ë"ØzKä*ÿ%
*)¬áRè®^Q7ά¨dì%¼®áé®%!øJâ)/.
]}Å^¬»ÚsÝÈÀú\X$ÎãÈ{F6Ã?S"þåÿúâ|1±#à
nºlb0¥ìAj¼Þ¢J!R°¹Jʹ°ÐÊ\¼>ÌáÖ(æíÓ°`½½ú¿ù®NdÜ»öWhqlDö¸.}nÅóÐr¨Ý]±DÃÿ¼öã5¡ÂóAéÓ¹
é
ªÂûsÇK1´il.ÿ(3Z÷µd
brm
November 13, 2020, 8:17am
2
Looks weird.
Have you tried to execute the cmk agent locally? Same result? Which sections are executed successfully resp. when does this pattern occur? Did you modify anything within the agent? How was the agent installed?
Dirk
November 13, 2020, 8:34am
3
Did you configure your agent to return encrypted output? This can be done with the file /etc/check_mk/encryption.cfg
khozy
November 13, 2020, 9:01am
4
running .\check_mk_agent.exe test locally on the monitored host shows readable text as expected. It only behaves this way in CMK portal.
system
(system)
Closed
November 13, 2021, 9:01am
5
