We have decided to use Check MK for monitoring. However, we are encountering some practical issues. The most important one is this: we have created two groups based on the OS (Windows and Linux), but we don’t know how to assign hosts to these groups. When adding hosts, we try to add them using labels, but it doesn’t work. Although we try to configure labels from the settings, every host we add belongs to both groups. How can I resolve this confusion?
For example, the host I added (an Ubuntu machine) appears in both groups even though I selected the correct label. How can I fix this issue? Even if I use the same label that I configured when adding the host, I can’t seem to add it to the correct host group, and I can’t establish the link between them.
Thanks .
