Community Call: Improving Azure Monitoring in Checkmk 2.5
Hello Community! :waving_hand:
In the past year, we’ve put a lot of work into improving how Checkmk monitors Azure. We’re looking forward to sharing the results with you and discussing the specific challenges we wanted to solve.
Join us for a community call with our Product Manager, @MSaleh, who has been leading this initiative. We’ll walk through the new features and, importantly, talk about how to migrate to the new version so you can start using the updates straight away.
The call will take place on February 25th, at 3PM Berlin time on Zoom.
We have also prepared an event reminder for you, if you want to be notified about the call 1 day and 1 hour before.
To make sure you feel comfortable sharing your feedback or asking questions, this call will not be recorded.
Looking forward to seeing you!
Update: A Zoom link has changed as the previous link was incorrect.
If you wrote it down somewhere, please change it to the correct link.
I missed most of the session because of this. Is there a way to improve the communication of a changed meeting link in the future?
Hi Brian,
I am sorry this happened.
We generally try to keep the “source of truth” in the Community post for this reason, and link to it – in case there are some changes like that, or, like in this case, human error, for which I am truly sorry. Unfortunately, I saw no other way of announcing it that would be more visible.
What would be a good way for you to be notified in these cases?
Knowing that the relevant forum post will (almost) always have the correct meeting link is quite helpful. I will adjust my process to document not only the Zoom link sent out, but also the related forum post so that if a meeting does not seem to be starting, I can easily get to the post and see if the link has changed. Thanks!
From my side I will do my best to come up with a more robust solution, that will reduce the possibility of links being incorrect, maybe a fixed link.
I will need to take a look at the possible issues, when a link is used for multiple planned meetings and hopefully adapt the process, so this is never needed.
Thank you for understanding.
