Hi!
I have setup Checkmk in a docker container and most everything is working well. I want to be able to receive notifications through email and I am experimenting on how to get this working with Postfix. I have a postfix docker container GitHub - juanluisbaptiste/docker-postfix: Simple SMTP relay docker image. running with the following options:
359ff65a2503 juanluisbaptiste/postfix “/run.sh” 19 hours ago Up 19 hours 0.0.0.0:49153->25/tcp, :::49153->25/tcp postfix
I want to use this as a email relay for the checkmk instance, but have not figured out completely how to get this configured. I create my docker container using the following command:
sudo docker container run -dit -p 8180:5000 -e MAIL_RELAY_HOST='192.168.1.47:25' --ulimit nofile=1024 --tmpfs /opt/omd/sites/cmk/tmp:uid=1000,gid=1000 -v monitoring:/omd/sites --name monitoring -v /etc/localtime:/etc/localtime:ro --restart always checkmk/check-mk-raw:2.0.0-latest
The 192.168.1.47 is the docker host, so not completely sure how to reference the postfix docker container to make this work. Has anyone set this up so they can guide me in the right direction?
