ConnectionResetError(104, 'Connection reset by peer')
**CMK version:*2.1.0p40.cee *
**OS version:*Red Hat Enterprise Linux release 8.9 *
**Error message:ConnectionResetError(104, ‘Connection reset by peer’)
OMD[pdc1]:~$ cmk --debug -vvn dinoaccapp22
Checkmk version 2.1.0p40
Trying to acquire lock on /omd/sites/pdc1/var/check_mk/license_usage/next_run
Got lock on /omd/sites/pdc1/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/pdc1/var/check_mk/license_usage/history.json
Got lock on /omd/sites/pdc1/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/pdc1/var/check_mk/license_usage/history.json
Released lock on /omd/sites/pdc1/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/pdc1/var/check_mk/license_usage/next_run
Released lock on /omd/sites/pdc1/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7fe245ded130]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(dinoaccapp22, base_path=/omd/sites/pdc1/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=540, inventory=540), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Connecting via TCP to 10.XX.XX.XX:6556 (180.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Closing TCP connection to 10.XX.XX.XX:6556
[cpu_tracking] Stop [7fe245ded130 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999999776482582))]
[cpu_tracking] Start [7fe245ded9a0]
[PiggybackFetcher] Fetch with cache settings: NoCache(dinoaccapp22, base_path=/omd/sites/pdc1/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=540, inventory=540), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'dinoaccapp22'. Skip processing.
No piggyback files for '10.XX.XX.XX'. Skip processing.
[cpu_tracking] Stop [7fe245ded9a0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
  -> Not adding sections: ConnectionResetError(104, 'Connection reset by peer')
No persisted sections
  -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fe245deda90]
value store: synchronizing
Trying to acquire lock on /omd/sites/pdc1/tmp/check_mk/counters/dinoaccapp22
Got lock on /omd/sites/pdc1/tmp/check_mk/counters/dinoaccapp22
Releasing lock on /omd/sites/pdc1/tmp/check_mk/counters/dinoaccapp22
Released lock on /omd/sites/pdc1/tmp/check_mk/counters/dinoaccapp22
Log Forwarding       PEND - Check plugin received no monitoring data
proc_puppet          PEND - Check plugin received no monitoring data
proc_runpup          PEND - Check plugin received no monitoring data
[cpu_tracking] Stop [7fe245deda90 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[agent] ConnectionResetError(104, 'Connection reset by peer')(!!), Got no information from host(!!), execution time 0.0 sec | execution_time=0.010 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.010
* (If it is a problem with checks or plugins)
We upgraded check_mk from 2.0.0p34 to 2.1.0p40. We registered two hosts manually. But we are getting an Error in check_mk UI Check_MK service is reporting an error:
ConnectionResetError(104, 'Connection reset by peer')**CRIT**, Got no information from host**CRIT**, execution time 0.0 sec
Please advice,
Is there a firewall enabled on the hosts you want to monitor? Checkmk only handles firewall configuration on windows systems. On Linux systems you need to take care of the appropiate settings yourself since there are too many ways to configure such firewall.
RHEL for example comes with a firewall enabled by default.
Ralf
Hello Ralf,
Thanks for the quick reply,
No, we have an enterprise level firewall. I will check with the firewall engineer if there is any restriction to notice.
It was indeed a firewall issue. Solved.
