CMK version:
2.1.0p9.cee
OS version:
Appliance v1.5.4
Title: 404 Not Found
Body:
# Not Found
The requested URL was not found on this server.
omd status Maincopy
agent-receiver: running
liveproxyd: running
mknotifyd: running
rrdcached: running
cmc: running
apache: running
dcd: running
redis: running
crontab: running
Overall state: running
The Problem seems to be a wrong Port in the Config File /omd/apache/Maincopy.conf
In omd config Maincopy the Apache Port is 5005 and in the File it is 5000
When I change the Port everything seems to be working.
The difference to the site that i copied is that the original Site has split the Config in 3 files and this site has just one.
/omd/apache/Maincopy.conf content
# version: 2
# This file is managed by 'omd' and will automatically be overwritten. Better do not edit manually
# Make sure that symlink /omd does not make problems
<Directory />
Options +FollowSymlinks
</Directory>
<IfModule mod_proxy_http.c>
ProxyRequests Off
ProxyPreserveHost On
<Proxy http://127.0.0.1:5000/Maincopy>
Order allow,deny
allow from all
</Proxy>
<Location /Maincopy>
# Setting "retry=0" to prevent 60 second caching of problem states e.g. when
# the site apache is down and someone tries to access the page.
# "disablereuse=On" prevents the apache from keeping the connection which leads to
# wrong devlivered pages sometimes
ProxyPass http://127.0.0.1:5000/Maincopy retry=0 disablereuse=On timeout=120
ProxyPassReverse http://127.0.0.1:5000/Maincopy
</Location>
</IfModule>
<IfModule !mod_proxy_http.c>
Alias /Maincopy /omd/sites/Maincopy
<Directory /omd/sites/Maincopy>
Deny from all
ErrorDocument 403 "<h1>Checkmk: Incomplete Apache Installation</h1>You need mod_proxy and
mod_proxy_http in order to run the web interface of Checkmk."
</Directory>
</IfModule>
ErrorDocument 503 "<meta http-equiv='refresh' content='60'><h1>Checkmk: Site Not Started</h1>You need to start this site in order to access the web interface.<!-- IE shows its own short useless error message otherwise: placeholder -->"
</Location
The /omd/apache/Main.conf contains:
Include /omd/sites/Main/etc/apache/mode.conf
/omd/sites/Main/etc/apache/mode.conf contains:
# This file is read in by the global Apache. It is
# owned by OMD. Do not add anything here. Rather
# create your own files in conf.d/
<Directory />
</Directory>
ProxyRequests Off
# Include file created by 'omd config', which
# sets the TCP port of the site local webserver
Include /omd/sites/Main/etc/apache/proxy-port.conf
</IfModule>
Alias /Main /omd/sites/Main
<Directory /omd/sites/Main>
Deny from all
ErrorDocument 403 "<h1>OMD: Incomplete Apache2 Installation</h1>You need mod_proxy and mod_proxy_http in order to run the web interface of OMD."
</Directory>
</IfModule>
<Location /Main>
ErrorDocument 503 "<meta http-equiv='refresh' content='60'><h1>OMD: Site Not Started</h1>You need to start this site in order to access the web interface.<!-- IE shows its own short useless error message otherwise: placeholder -->"
</Location>
# Set site specific environment
SetEnv OMD_SITE Main
SetEnv OMD_ROOT /omd/sites/Main
SetEnv OMD_MODE own
/omd/sites/Main/etc/apache/proxy-port.conf contains:
# This file is created by 'omd config set APACHE_TCP_PORT'.
# Better do not edit manually
<Proxy http://127.0.0.1:5000/Main>
Order allow,deny
allow from all
</Proxy>
<Location /Main>
ProxyPass http://127.0.0.1:5000/Main retry=0 disablereuse=On timeout=120
</Location
