Hi
The monitoring Linux guide states that
a subdirectory in plugins whose name is a numeric: representing a count of seconds
But in WATO - Configuration > Monitoring Agents > Agent files > Linux/Unix Agents - Plugins > README
you can read:
If you want a plugin to be run asynchronously and also in
a larger interval then the normal check interval, then you can
copy it to a subdirectory named after a number of *minutes*,
e.g.:
/usr/lib/check_mk_agent/plugins/60/mk_zypper
In that case the agent will:
- Run this plugin in the background and wait not for it to finish.
- Store the result of the plugin in a cache file below /etc/check_mk/cache.
- Use that file for one hour before running the script again.
Which is undoubtedly wrong. Please correct.
