HI,
Does checkmk provide an option to display CPU usage specific to services, similar to the functionality of the top command in Linux?
Thank you
HI,
Thank you
It is possible to monitor discovered processes on a host. As soon as a process is discovered, its CPU usage, memory usage and number of instances is monitored.
HI,
I couldn’t see any option to monitor the process like top command, and like the memory and RAM usage of the MySQL
Thank you
You need monitor the individual processes through service discovery as “Heacy” stated. For monitoring MySQL this can be useful for you: Monitoring MySQL
I’m not insisting on using MySQL; I just provided it as an example. In a Linux system, there are various services such as a web server, SSH, mail, etc. Unfortunately, not all of them can be automatically discovered through the Checkmk agent. What I’m looking to achieve is monitoring the top resources using processes, similar to how we use the “top” command. Is it not feasible in Checkmk, and do I need to monitor individual processes?
