CPU utilization
Hello All,
I’ve enabled per-core monitoring in the CPU utilization rule and set a threshold. This has worked, but the Linux team only wants to receive notifications for total CPU usage, not for individual cores.
Is there any way to keep the core data and graphs visible without triggering notifications?
I also enabled the option “Levels over an extended time period on a single core CPU utilization” but I didn’t see any change.
Thnaks in advance.
Regards,
Vix
Its already enabled with “Graphs for individual cores”. Now you just need to disable “Levels over an extended time period on a single core CPU utilization”.
Hello paulosantanabr, thanks so much.
