CRITICAL - Cannot make SSL connection when checking Certificate age
CMK version:
2.2.0p22.cre
OS version:
Debian Buster
Checkmk version 2.2.0p22
  • FETCHING DATA
Source: SourceInfo(hostname=‘host’, ipaddress=‘10.10.10.10’, ident=‘piggyback’, fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fa85b4a8a10]
Read from cache: NoCache(host, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for ‘host’. Skip processing.
No piggyback files for ‘10.10.10.10’. Skip processing.
[cpu_tracking] Stop [7fa85b4a8a10 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
  • PARSE FETCHER RESULTS
HostKey(hostname=‘host’, source_type=<SourceType.HOST: 1>) → Add sections:
Received no piggyback data
[cpu_tracking] Start [7fa85b9668d0]
value store: synchronizing
Trying to acquire lock on /omd/sites/P13000/tmp/check_mk/counters/host
Got lock on /omd/sites/P13000/tmp/check_mk/counters/host
Releasing lock on /omd/sites/P13000/tmp/check_mk/counters/host
Released lock on /omd/sites/P13000/tmp/check_mk/counters/host
[cpu_tracking] Stop [7fa85b9668d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[piggyback] Success (but no data found for this host), execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
rule:
Service name: cert
Host settings:
TCP Port: 443
Virtual host: $HOSTADDRESS$
Mode of the Check: Check SSL Certificate Age,
Age: 90 days, 60 days
Advanced: Disable SSL/TLS hostname extension support (SNI):
Site is behind nginx reverse proxy
Any direction on how to solve this, highly appreciated
A little bit better description of your problem would be good. I don’t see any error message or useful information.
The agent output is not relevant if you have a problem with an active check like HTTP/HTTPS. But this output would be very interesting.
Reverse proxies often provide a number of webservices available under one external ip. For this to work, you must make usage of SNI.
So with the few bits of information that you have given us, I suggest to enable SNI and replace $HOSTADDRESS$ with $HOSTNAME$ where hostname would be the FQDN that’s also in the CN of the certificate or at least in the SAN entry.
Regards
Simon
Helloooooo
That indeed did the trick, many thanks for this very fast and professional answer.
Best,
rene
You’re welcome.
Happy monitoring!
Hello Rene.
If Simon’s reply resolved your question, could I please ask you to mark it as a solution? It helps everyone else to see the question is resolved and in a way it says thank you to Simon :slight_smile:
