Crontab Permission denied for site user
Hey everybody :upside_down_face:
CMK version: Check_MK version 2.1.0p19 CRE
OS version: Ubuntu 20.04.5 LTS (Hyper-V Guest)
Description of the problem: (Site) user is not allowed to use crontab command/program
root@machine:~# omd start test
Temporary filesystem already mounted
Starting agent-receiver...OK
Starting mkeventd...OK
Starting rrdcached...OK
Starting npcd...OK
Starting nagios...OK
Starting apache...OK
Starting redis...OK
Initializing Crontab.../etc/cron.allow: Permission denied
You (test) are not allowed to use this program (crontab)
See crontab(1) for more information
Exception ignored in: <_io.TextIOWrapper name='<stdout>' mode='w' encoding='utf-8'>
BrokenPipeError: [Errno 32] Broken pipe
ERROR
root@machine:~# omd stop test
Removing Crontab.../etc/cron.allow: Permission denied
Stopping redis...killing 55241...OK
Stopping apache...killing 55230.................OK
Stopping nagios....OK
Stopping npcd...OK
Stopping rrdcached...waiting for termination...OK
Stopping mkeventd...killing 55140....OK
Stopping agent-receiver...killing 55132...OK
Stopping 1 remaining site processes...OK
I have seen similiar problems here but nothing helped. I tried changing the rights of /etc/crontab and dpkg-reconfigure cron. Some more outputs which might help:
First steps for Troubleshooting:
  • The user is in the /etc/cron.allow, there is no /etc/cron.deny.
  • I have manually created a user which was also not able to use crontab. So there is a good chance, it has nothing to do directly with the user created during the creation of the site.
  • root is allowed to use crontab. If I use sudo with a normal user the user is also allowed to use crontab.
root@machine:~# stat /etc/crontab
  File: /etc/crontab
  Size: 1042            Blocks: 8          IO Block: 4096   regular file
Device: fd00h/64768d    Inode: 524974      Links: 1
Access: (0700/-rwx------)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2023-01-21 17:47:42.858087500 +0300
Modify: 2023-01-16 23:46:12.331254158 +0300
Change: 2023-01-21 16:26:09.258753718 +0300
 Birth: -
It is worth mentioning that I had to implement some CIS Benchmarks during setup of the machine itself. Even though I don’t think that they are connected with my problem, here are the relevant ones:
# CIS 5.1.2
chown root:root /etc/crontab
chmod og-rwx /etc/crontab
# CIS 5.1.3
chown root:root /etc/cron.hourly
chmod og-rwx /etc/cron.hourly
# CIS 5.1.4
chown root:root /etc/cron.daily
chmod og-rwx /etc/cron.daily
# CIS 5.1.5
chown root:root /etc/cron.weekly
chmod og-rwx /etc/cron.weekly
# CIS 5.1.6
chown root:root /etc/cron.monthly
chmod og-rwx /etc/cron.monthly
# CIS 5.1.7
# Prevent blacklist behavior
rm /etc/cron.deny
rm /etc/at.deny
# Force whitelist behavior
touch /etc/cron.allow
touch /etc/at.allow
# Customize file permissions
chmod o-rwx /etc/cron.allow
chmod g-wx /etc/cron.allow
chmod o-rwx /etc/at.allow
chmod g-wx /etc/at.allow
chown root:root /etc/cron.allow
chown root:root /etc/at.allow
I don’t think that checkmk eg. changes the permissions of system files and as it also happens to normal users. Hopefully somebody has an idea where to look for.
I really appreciate your help! :pray:
It is part of a specification I had to implement to comply with company rules and basically limits who can use crontab. But, as I have written, my monitoring user is in that file.
With your user listed in /etc/cron.allow, I am just as surprised as you.
Can you run crontab manually (instead of through the omd script) as that user?
Perhaps strace -f a failing command for a hint to where exactly it stumbles?
I think /etc/cron.allow has to be readable.
From crontab(1):
The files /etc/cron.allow and /etc/cron.deny if, they exist, must be either world-readable, or readable by group crontab. If they are not, then cron will deny access to all users until the permissions are fixed.
Even strace gave me an ā€˜operation not permitted’… It must have something to do with the safety regulations. I will start over and install from scratch, this time by installing checkmk first and regulary trying to start the site up to that point where it fails.
Thanks for now, I really apreciate your effort.
@r.sander
Thanks for the advice. I already reverted to an early snapshot I had. crontab was working even after I set the file permissions which I instantly did to check if this was the problem.
Security is a nice thing, but too often this leads to weird behaviour…
As for now it looks like some of the security related configurations I had to made dont’t work with each other and I have to report that internally.
As soon as I created the cron.allow file no user except root was able to use crontab. I started over with the old snapshot and now everything is working fine.
Thanks everybody!
