Good morning, if you can help me. How can I make that there is only one trap snmp rule? That is, that the alert appears today and tomorrow it comes out again, and only has the most current one? Looking at the settings I only see possible that you have 2 warnings of the same rule. and I would be interested in having only 1 notice. Best regards
Hello @javier and welcome to the Community!
Can you provide some screenshot to clarify what you want to achieve?
Add my config in event console
you can also use a counter on the event. The events will be coungt based on hostname, application an matching groups if you use.
Cheers, Christian
Hello, with the count option now only one event appears.
Thank you all and problem solved.
