I am suddenly having problems bringing my custom plugins to work.
Interestingly do they work sometimes, but not always and not on all involved systems.
They also worked before, but stopped working today after doing some changes.
Reverting these changes however did not make it work again.
What I did so far:
- Checking my host plugin for errors (none)
- Checking the python plugin on my CheckMK server for errors (none? at least not syntactical and cmk gave no errors either)
- Rebooting the CheckMK services
- Rebooting the whole server
- Rebooting the client
- Deleting everything in
/var/lib/check_mk_agent/cache/
The host plugins are located in /usr/lib/check_mk_agent/plugins
The server plugins in ~/local/lib/check_mk/base/plugins/agent_based
These are the plugins:
Plugins
zeek_remote_connections.sh
#!/bin/sh
echo '<<<zeek_remote_connections>>>'
docker exec zeek zeekctl doctor check_local_connections | awk '/%/'
Python script: zeek_remote_connections.py · GitHub
zeek_packet_loss.sh
#!/bin/sh
echo '<<<zeek_packet_loss>>>'
docker exec zeek zeekctl doctor check_capture_loss_conn_pct | awk '/%/'
Python script: zeek_packet_loss.py · GitHub
zeek_halfduplex_connections.sh
#!/bin/sh
echo '<<<zeek_halfduplex_connections>>>'
docker exec zeek zeekctl doctor check_SAD_connections | awk '/%/'
Python script: zeek_halfduplex_connections.py · GitHub
The output of these scripts are included in the agent and I checked with cmk -d if they arrive at the server. They do.
I am out of ideas. Does anyone know what else I can check?
Best regards,
Niklas
CMK version: 2.0.0p22 (CRE)
OS version: Ubuntu 20.04 LTS (both, client and server)
Error message: No specific error message.
Output
OMD[REDACTED-SITE]:~/local/lib/check_mk/base/plugins/agent_based$ cmk --debug -vvn REDACTED-HOSTNAME
Checkmk version 2.0.0p22
Trying to acquire lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/next_run
Got lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/history.json
Got lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/history.json
Released lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/next_run
Released lock on /omd/sites/REDACTED-SITE/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f1695942dc0]
Connecting via TCP to REDACTED-HOSTNAME.REDACTED-DOMAIN:6556 (5.0s timeout)
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/REDACTED-SITE/tmp/check_mk/cache/REDACTED-HOSTNAME'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 26 sec, allowed is 0 sec)
Reading data from agent
Output is not encrypted
Write data to cache file /omd/sites/REDACTED-SITE/tmp/check_mk/cache/REDACTED-HOSTNAME
Trying to acquire lock on /omd/sites/REDACTED-SITE/tmp/check_mk/cache/REDACTED-HOSTNAME
Got lock on /omd/sites/REDACTED-SITE/tmp/check_mk/cache/REDACTED-HOSTNAME
Releasing lock on /omd/sites/REDACTED-SITE/tmp/check_mk/cache/REDACTED-HOSTNAME
Released lock on /omd/sites/REDACTED-SITE/tmp/check_mk/cache/REDACTED-HOSTNAME
Closing TCP connection to REDACTED-HOSTNAME.REDACTED-DOMAIN:6556
[cpu_tracking] Stop [7f1695942dc0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=4.78999999910593))]
[cpu_tracking] Start [7f1695942eb0]
No piggyback files for 'REDACTED-HOSTNAME'. Skip processing.
No piggyback files for 'REDACTED-HOSTNAME.REDACTED-DOMAIN'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/REDACTED-SITE/tmp/check_mk/data_source_cache/piggyback/REDACTED-HOSTNAME'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f1695942eb0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections loaded
-> Add sections: ['check_mk', 'cifsmounts', 'common_os_version', 'cpu', 'df', 'diskstat', 'docker_node_info', 'docker_node_network', 'job', 'kernel', 'lnx_if', 'lnx_thermal', 'local', 'md', 'mem', 'mounts', 'multipath', 'nfsmounts', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'timesyncd', 'uptime', 'vbox_guest', 'zeek_halfduplex_connections', 'zeek_packet_loss', 'zeek_remote_connections']
-> Add sections: []
Storing piggyback data for: zeek
Trying to acquire lock on /omd/sites/REDACTED-SITE/tmp/check_mk/piggyback/zeek/REDACTED-HOSTNAME
Got lock on /omd/sites/REDACTED-SITE/tmp/check_mk/piggyback/zeek/REDACTED-HOSTNAME
Releasing lock on /omd/sites/REDACTED-SITE/tmp/check_mk/piggyback/zeek/REDACTED-HOSTNAME
Released lock on /omd/sites/REDACTED-SITE/tmp/check_mk/piggyback/zeek/REDACTED-HOSTNAME
Received piggyback data for 1 hosts
Loading item states
Trying to acquire lock on /omd/sites/REDACTED-SITE/tmp/check_mk/counters/REDACTED-HOSTNAME
Got lock on /omd/sites/REDACTED-SITE/tmp/check_mk/counters/REDACTED-HOSTNAME
Releasing lock on /omd/sites/REDACTED-SITE/tmp/check_mk/counters/REDACTED-HOSTNAME
Released lock on /omd/sites/REDACTED-SITE/tmp/check_mk/counters/REDACTED-HOSTNAME
+ EXECUTING INVENTORY PLUGINS
hp_proliant_mem: skipped (no data)
ipmi_firmware: skipped (no data)
inventory_checkmk: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
inventory_oracle_tablespaces: skipped (no data)
dmidecode: skipped (no data)
docker_node_network: ok
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
juniper_info: skipped (no data)
mem: ok
mem_used: skipped (no data)
snmp_info: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
allnet_ip_sensoric: skipped (no data)
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkpoint_inv_tunnels: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_container_node_name: skipped (no data)
docker_node_images: skipped (no data)
docker_node_info: ok
docker_node_info: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_job_container: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_roles: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_if: ok
lnx_if: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_uname: skipped (no data)
lnx_video: skipped (no data)
lparstat_aix: skipped (no data)
mssql_clusters: skipped (no data)
mssql_versions: skipped (no data)
netapp_api_disk: skipped (no data)
netapp_api_info: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_systemparameter: skipped (no data)
perle_chassis: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
prtconf: skipped (no data)
snmp_extended_info: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_routes: skipped (no data)
solaris_uname: skipped (no data)
statgrab_net: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_os: skipped (no data)
win_reg_uninstall: skipped (no data)
win_system: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
winperf_if: skipped (no data)
Trying to acquire lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME
Got lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME
Releasing lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME
Released lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME
Trying to acquire lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME.gz
Got lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME.gz
Releasing lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME.gz
Released lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/REDACTED-HOSTNAME.gz
Trying to acquire lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/.last
Got lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/.last
Released lock on /omd/sites/REDACTED-SITE/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7f1695942eb0 - Snapshot(process=posix.times_result(user=0.07000000000000006, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.07999999821186066))]
[agent] Version: 2.0.0p22, OS: linux, execution time 4.9 sec | execution_time=4.870 user_time=0.080 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=4.780
