I have been working at getting my company to adopt Check_MK as the primary monitoring and reporting system. I’ve been using it to monitor almost 200 hosts for a year and have now been asked to include SLA type reporting once a month of each host, detailing server performance.
I wish to change the look and feel of the PDF reports that get generated. I used to use Thruk but when I didn’t have access to the enterprise edition of Check_MK.
Does anyone know the best way to skin the reports to make them look more attractive?
If you want only to apply your corporate identity then it is very easy. You can start with a white page for reporting and then add some fixed page elements and also your wanted content elements.
At what point do you encountered problems?
