We have an internal API that handles event notifications. Is it possible to perform an HTTP POST with JSON body for an alert action?
Thanks
Thanks
Yes it is. You can simply using python requests for this.
Get context from environment:
def sendmsg(url, data, verify=False):
headers = {'Content-Type': 'application/json'}
try:
r = requests.post(url, data=data, headers=headers, verify=verify_cert)
is_success = True
except:
is_success = False
return is_success
context = dict([(var[7:], value.decode("utf-8"))
for (var, value) in os.environ.items()
if var.startswith("NOTIFY_")])
data = json.dumps(context)
sendmsg(url, data, verify=verify_cert)
I hope it helps.
Cheers,
Christian
This is great to hear. Looking at a new notification rule I don’t see an option to do this under the notification method dropdown box. Is this possible within the interface to configure?
Looks like the available options are based on the scripts in the applicable scripts directory.
Here is the doc that touches on it -
Thanks for your response!
