Hi everyone,
I’m new to Checkmk and I’m trying to create a custom notification plugin that will later connect to our ticket system.
Right now I just want to get the parameter form working in the GUI.
No matter what I do, I only see this generic text:
So my parameters are not detected
Im currently using 2.4.0p13 (CRE)
My current filestructure:
Notification plugin
/omd/sites/monitoring/local/lib/python3/cmk/notification_plugins/tbs_ticket.py
#!/usr/bin/env python3
from __future__ import annotations
import json, urllib.request
from cmk.utils.notify_types import PluginNotificationContext
from cmk.notification_plugins.utils import process_by_status_code
def _build_payload(ctx: PluginNotificationContext) -> dict:
return {
"type": ctx.get("PARAMETER_ticket_art"),
"host": ctx.get("HOSTNAME"),
"state": ctx.get("HOSTSTATE"),
def main() -> int:
def _send(ctx: PluginNotificationContext) -> int:
api_url = ctx.get("PARAMETER_api_url")
token = ctx.get("PARAMETER_api_token")
req = urllib.request.Request(
url=f"{api_url.rstrip('/')}/tickets",
method="POST",
data=json.dumps(_build_payload(ctx)).encode("utf-8"),
headers={"Content-Type": "application/json", "Authorization": f"Bearer {token}"},
with urllib.request.urlopen(req, timeout=10) as r:
return r.getcode()
return process_by_status_code(lambda *_: _send, (200, 201, 202))
Wrapper (is executable)
/omd/sites/monitoring/local/share/check_mk/notifications/tbs_ticket
import sys
from cmk.notification_plugins.tbs_ticket import main
if __name__ == "__main__":
sys.exit(main())
Ruleset
/omd/sites/monitoring/local/lib/python3/cmk_addons/plugins/tbs_ticket/rulesets/notifications_tbs_ticket.py
# -*- coding: utf-8 -*-
from cmk.rulesets.v1 import Title
from cmk.rulesets.v1.form_specs import Dictionary, String, Boolean, DropdownChoice, DefaultValue
from cmk.rulesets.v1.rule_specs import NotificationParameters
from cmk.rulesets.v1.form_specs import validators
def _params_form():
return Dictionary(elements=[
("ticket_art", DropdownChoice(
title=Title("Ticket Type"),
elements=[("incident", Title("Incident")),
("service_request", Title("Service Request"))],
prefill=DefaultValue("incident"),
("api_url", String(title=Title("API URL"), validators=[validators.Url()])),
("api_token", String(title=Title("API Token"), allow_empty=False)),
("send_links", Boolean(title=Title("Send Links"), prefill=DefaultValue(True))),
rule_spec_tbs_ticket = NotificationParameters(
name="tbs_ticket",
title=Title("TBS Ticket – Parameters"),
parameter_form=_params_form,
I restarted the site using omd restartand activated the changes (but as i remeber there were none). The plugin appears correctly as a method under Setup → Events → Notifications, but I still don’t see any custom parameter fields, only the generic section that says “Parameters… Call with the following parameters”.
What am I missing? Are my paths or filenames wrong, or did something change in version 2.4? Is there maybe a simple working example of a custom notification plugin with parameters that I can compare mine against?
Thanks in advance and best regards ![]()
