CMK version: 2.3.0P10 MSP OS version: Ubuntu 22.04 LTS
We’re trying to write our own SNMP plugin. We’re really struggling with it as we have no Python knokwledge
The issue is that our .py script keeps disappearing at random times from the following location:
/local/lib/python3/cmk_addons/plugins/fortiweb_memory_check/agent_based
My colleague was working on it, he had a meeting for about an hour, logged back in and the script was gone again. Our CheckMK is a distributed setup. The server he’s creating this script on is not the main server. Are we doing something wrong?
I would recommend to create a dev instance on the satellite server and create your plugin there. Some times it is complicated to reach the devices directly from the central site (firewall, ACL and so on).
After you finished your work transfer the crates files or the build map to the central instance and let it distribute to the worker sites.
the synchronization happens when you activate the changes, so its not “random”
I recommend having a small dev/sandbox environment where you do your testing. you can actually. break things, especially if working with SNMP based checks. (we one had one check crash on all our snmp devices, and we have thousands…)
No - synchronization can also happen if you create a new rule on the master site or if you start a discovery inside the GUI. That is more “random” than. All without activation.
This was new to me, what kind of rules does this? Can you decide that when you write your own checks using the API? What files are synced to the other sites?
I assume the microcore/nagios needs to be reloaded on the sites?
