Custom SNMP check plugin discovered, but not executing
I have a Modbus to SNMP converter to monitor a power device. I am attemping to write a custom SNMP plugin to poll data and alert based on certain check parameters. When I run cmk -Ivv hostname, it includes my custom plugin, so I believe the detect line in the plugin script is working correctly. However, the output of the debug command shows: + EXECUTING DISCOVERY PLUGINS (0). Why isn’t my plugin getting executed?
The data I am looking for exists in this SNMP tree: 1.3.6.1.4.1.4131
Specifically I am looking for data in this OID: .1.3.6.1.4.1.4131.1.5.1.3.28 it is a fluid level reading stored as an integer.
I used this script as a basis for getting an understanding of how Checkmk works: checkmk-docs/examples/devel_check_plugins_snmp/flintstone_setup_check_bare_minimum.py at master · Checkmk/checkmk-docs · GitHub
I have included the script code, cmk -Ivv output and SNMP walk information below.
CMK version: 2.3 RAW
Docker - Debian 12 Host
** SNMP Check Script **
#!/usr/bin/env python3
# This file is explained in the Checkmk User Guide:
# https://docs.checkmk.com/master/en/devel_check_plugins_snmp.html#scaffold
# Store in your Checkmk site at:
# ~/local/lib/python3/cmk_addons/plugins/flintstone/agent_based/flintstone_setup_check.py
from cmk.agent_based.v2 import (
    CheckPlugin,
    CheckResult,
    startswith,
    DiscoveryResult,
    Result,
    Service,
    SimpleSNMPSection,
    SNMPTree,
    State,
    StringTable,
def parse_flintstone(string_table):
    return {}
def discover_flintstone(section):
    yield Service()
def check_flintstone(section):
    yield Result(state=State.OK, summary="Everything is fine")
snmp_section_flintstone_setup = SimpleSNMPSection(
    name = "flintstone_base_config",
    parse_function = parse_flintstone,
    detect = startswith(".1.3.6.1.2.1.1.1.0", "Tridium"),
    fetch = SNMPTree(base='.1.3.6.1.4.1.4131.1.5.1', oids=['3.28']),
check_plugin__flintstone_setup = CheckPlugin(
    name = "flintstone_setup_check",
    sections = [ "flintstone_base_config" ],
    service_name = "Flintstone setup check",
    discovery_function = discover_flintstone,
    check_function = check_flintstone,
Output of “cmk --debug -Ivv modbus-snmpConverter”:
Discovering services and host labels on: modbus-snmpConverter
modbus-snmpConverter:
+ FETCHING DATA
  Source: SourceInfo(hostname='modbus-snmpConverter', ipaddress='192.168.1.20', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f99e374ccb0]
Read from cache: SNMPFileCache(modbus-snmpConverter, path_template=/omd/sites/cmk/tmp/check_mk/data_source_cache/snmp/{mode}/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=1)
  SNMP scan:
       Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Tridium station"]
b'Tridium station'
       Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.4131.1]
b'.1.3.6.1.4.1.4131.1'
       Using cached OID .1.3.6.1.2.1.1.1.0: 'Tridium station'
       Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.4131.1'
       Getting OID .1.3.6.1.4.1.6302.2.1.1.1.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.4.1.6302.2.1.1.1.0'
ERROR: SNMP error
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: .1.3.6.1.4.1.6302.2.1.1.1.0
failed.
       Getting OID .1.3.6.1.4.1.232.2.2.4.2.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.4.1.232.2.2.4.2.0'
ERROR: SNMP error
Error in packet
Failed object: .1.3.6.1.4.1.232.2.2.4.2.0
failed.
       Using cached OID .1.3.6.1.4.1.232.2.2.4.2.0: None
       Getting OID .1.3.6.1.2.1.105.1.3.1.1.*: Running 'snmpgetnext -Cf -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.105.1.3.1.1'
ERROR: SNMP error
Error in packet.
Failed object: .1.3.6.1.2.1.105.1.3.1.1
failed.
       Using cached OID .1.3.6.1.4.1.6302.2.1.1.1.0: None
       Getting OID .1.3.6.1.2.1.25.1.1.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.25.1.1.0'
ERROR: SNMP error
Error in packet
Failed object: .1.3.6.1.2.1.25.1.1.0
failed.
       Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.2.2.1'
ERROR: SNMP error
Error in packet.
Failed object: .1.3.6.1.2.1.2.2.1
failed.
       Using cached OID .1.3.6.1.4.1.674.*: None
       Getting OID .1.3.6.1.4.1.14848.2.1.1.1.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.4.1.14848.2.1.1.1.0'
ERROR: SNMP error
Error in packet
Failed object: .1.3.6.1.4.1.14848.2.1.1.1.0
failed.
       Getting OID .1.3.6.1.4.1.30155.2.1.1.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.4.1.30155.2.1.1.0'
ERROR: SNMP error
Error in packet
Failed object: .1.3.6.1.4.1.30155.2.1.1.0
failed.
       Using cached OID .1.3.6.1.2.1.2.2.1.*: None
       Getting OID .1.3.6.1.4.1.2036.2.1.1.4.0: Running 'snmpget -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.4.1.2036.2.1.1.4.0'
ERROR: SNMP error
Error in packet
Failed object: .1.3.6.1.4.1.2036.2.1.1.4.0
failed.
       Getting OID .1.3.6.1.2.1.47.1.1.1.1.*: Running 'snmpgetnext -Cf -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.47.1.1.1.1'
ERROR: SNMP error
Error in packet.
Failed object: .1.3.6.1.2.1.47.1.1.1.1
failed.
       Getting OID .1.3.6.1.2.1.31.1.1.1.6.*: Running 'snmpgetnext -Cf -v1 -c public -m "" -M "" -On -OQ -Oe -Ot 192.168.1.20 .1.3.6.1.2.1.31.1.1.1.6'
ERROR: SNMP error
Error in packet.
Failed object: .1.3.6.1.2.1.31.1.1.1.6
failed.
       Using cached OID .1.3.6.1.2.1.25.1.1.0: None
   SNMP scan found                    flintstone_base_config hr_mem snmp_info snmp_uptime
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/snmp_scan_cache/modbus-snmpConverter.192.168.1.20
Got lock on /omd/sites/cmk/tmp/check_mk/snmp_scan_cache/modbus-snmpConverter.192.168.1.20
Releasing lock on /omd/sites/cmk/tmp/check_mk/snmp_scan_cache/modbus-snmpConverter.192.168.1.20
Released lock on /omd/sites/cmk/tmp/check_mk/snmp_scan_cache/modbus-snmpConverter.192.168.1.20
flintstone_base_config: Fetching data (SNMP walk cache cleared)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.4.1.4131.1.5.1.3.28'
hr_mem: Fetching data (SNMP walk cache cleared)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.25.2.3.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.25.2.3.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.25.2.3.1.4'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.25.2.3.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.25.2.3.1.6'
snmp_info: Fetching data (SNMP walk cache cleared)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.1.1'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.1.2'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.1.4'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.1.5'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.1.6'
snmp_uptime: Fetching data (SNMP walk cache cleared)
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.1.3'
Running 'snmpwalk -v1 -c public -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.20 .1.3.6.1.2.1.25.1.1'
[cpu_tracking] Stop [7f99e374ccb0 - Snapshot(process=posix.times_result(user=0.08000000000000007, system=0.04000000000000001, children_user=0.06, children_system=0.05, elapsed=0.5900000035762787))]
  Source: SourceInfo(hostname='modbus-snmpConverter', ipaddress='192.168.1.20', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f99e3a9b260]
Read from cache: NoCache(modbus-snmpConverter, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'modbus-snmpConverter'. Skip processing.
No piggyback files for '192.168.1.20'. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7f99e3a9b260 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
  HostKey(hostname='modbus-snmpConverter', source_type=<SourceType.HOST: 1>)  -> Add sections: []
Received no piggyback data
+ ANALYSE DISCOVERED HOST LABELS
Trying host label discovery with:
SUCCESS - Found no new host labels
+ ANALYSE DISCOVERED SERVICES
  Trying discovery with:
SUCCESS - Found no new services
SMNP Walk Output
.1.3.6.1.4.1.4131.1.5.1.3.1 = "470.0"
.1.3.6.1.4.1.4131.1.5.1.3.2 = "469.0"
.1.3.6.1.4.1.4131.1.5.1.3.3 = "473.0"
.1.3.6.1.4.1.4131.1.5.1.3.4 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.5 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.6 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.7 = "59.98"
.1.3.6.1.4.1.4131.1.5.1.3.8 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.9 = "true"
.1.3.6.1.4.1.4131.1.5.1.3.10 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.11 = "true"
.1.3.6.1.4.1.4131.1.5.1.3.12 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.13 = "272.0"
.1.3.6.1.4.1.4131.1.5.1.3.14 = "271.0"
.1.3.6.1.4.1.4131.1.5.1.3.15 = "272.0"
.1.3.6.1.4.1.4131.1.5.1.3.16 = "471.0"
.1.3.6.1.4.1.4131.1.5.1.3.17 = "470.0"
.1.3.6.1.4.1.4131.1.5.1.3.18 = "473.0"
.1.3.6.1.4.1.4131.1.5.1.3.19 = "68.0"
.1.3.6.1.4.1.4131.1.5.1.3.20 = "70.0"
.1.3.6.1.4.1.4131.1.5.1.3.21 = "68.0"
.1.3.6.1.4.1.4131.1.5.1.3.22 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.23 = "47.0"
.1.3.6.1.4.1.4131.1.5.1.3.24 = "30.0"
.1.3.6.1.4.1.4131.1.5.1.3.25 = "55.0"
.1.3.6.1.4.1.4131.1.5.1.3.26 = "84.0"
.1.3.6.1.4.1.4131.1.5.1.3.27 = "59.98"
.1.3.6.1.4.1.4131.1.5.1.3.28 = "42.0"
.1.3.6.1.4.1.4131.1.5.1.3.29 = "136.0"
.1.3.6.1.4.1.4131.1.5.1.3.30 = "4.0"
.1.3.6.1.4.1.4131.1.5.1.3.31 = "82.3"
.1.3.6.1.4.1.4131.1.5.1.3.32 = "26.38"
.1.3.6.1.4.1.4131.1.5.1.3.33 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.34 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.35 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.36 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.37 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.38 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.39 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.40 = "1.0"
.1.3.6.1.4.1.4131.1.5.1.3.41 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.42 = "0.0"
.1.3.6.1.4.1.4131.1.5.1.3.43 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.44 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.45 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.46 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.47 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.48 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.49 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.50 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.51 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.52 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.53 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.54 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.55 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.56 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.57 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.58 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.59 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.60 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.61 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.62 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.63 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.64 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.65 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.66 = "true"
.1.3.6.1.4.1.4131.1.5.1.3.67 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.68 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.69 = "true"
.1.3.6.1.4.1.4131.1.5.1.3.70 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.71 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.72 = "true"
.1.3.6.1.4.1.4131.1.5.1.3.73 = "false"
.1.3.6.1.4.1.4131.1.5.1.3.74 = "false"
End of MIB
looking at your Code I dont understand, where this is coming from.
This seems to be from the Vendor Vertiv.
Do you have other agent_based tests with the same flintstone name in the same site?
What happens when you run cmk --debug -vI --detect-plugins flintstone_setup_check <Hostname> ?
For simple debugging you can add print() entries in every function to see the output eg
print(section) in the discovery function.
Maybe try a cmk -R to Reload the config.
Thanks for your reply. I forgot to run cmk -R. I think that was my problem. I now have the OID returning a value and I have logic to set OK, WARN or CRIT statuses.
I have Vertiv devices in my list. But no other devices are named fintstone. I was wondering how that could happen as well.
I have another question. Is it possible to set this custom check/service as a metric and have Checkmk graph it over time?
Sure, this is quite simple:
So I am running into an issue with my changed code:
# ~/local/lib/python3/cmk_addons/plugins/snmpcoverter/agent_based/snmpcoverter_setup_check.py
    CheckPlugin,
    CheckResult,
    startswith,
    DiscoveryResult,
    Result,
    Service,
    SimpleSNMPSection,
    SNMPTree,
    State,
    StringTable,
    Metric,
    check_levels,
def parse_snmpcoverter(string_table):
    print("**parse**")
    #print(string_table)
    parsed = {}
    for line in string_table:
        #Clean up attributes from SNMP device
        attribute_name=line[0].replace("$20", " ").replace("$25", "%").replace("$28", "(").replace("$29", ")").replace("$2d","-")
        parsed.setdefault(attribute_name, {"value": line[1]})
    return parsed
def discover_snmpcoverter(section):
    print("**discover**")
    for item in section.keys():
        print(item)
        yield Service(item=item)
def check_snmpcoverter(item, section):
snmp_section_snmpcoverter_setup = SimpleSNMPSection(
    name = "snmpconverter_section_config",
    parse_function = parse_snmpcoverter,
    fetch = SNMPTree(
        base = '.1.3.6.1.4.1.4131.1.5.1',
        oids = [
            '2', # all names
            '3', # all states
check_plugin__snmpcoverter_setup = CheckPlugin(
    name = "snmpcoverter_services_check",
    sections = [ "snmpconverter_section_config" ],
    service_name = "service_%s",
    discovery_function = discover_snmpcoverter,
    check_function = check_snmpcoverter
When I run: cmk --debug -vI --detect-plugins snmpcoverter_services_check mysnmpdevice
Everything runs fine.
I am receiving the following error: TypeError: check_snmpcoverter() missing 1 required positional argument: ‘item’
This is my first plugin, so I am unsure of what to do here. I defined item as a parameter in the check method, but none of the examples I see of calling it show it being passed. Any ideas?
Sorry I meant to edit the second command:
When I run: cmk --debug -v --detect-plugins snmpcoverter_services_check mysnmpdevice
Still trying to figure out this parameter issue. Does it have to do with the modules I am importing?
